HMGSCRIPT 2012: Programming For The Web in The Right Way :)
Re: HMGSCRIPT 2012: Programming For The Web in The Right Way
rathinagiri wrote:Hi Roberto,
I could compile and run the websocket server with GUI after enabling -mt in HMG build.bat and manually calling from the project folder. :)
I have attached the whole project folder along with the executable. Everything is working fine but when I press the disconnect button the following error is fired. ( I think this one is not captured in console mode?)
And.. stopping server generates an error too.
I'm cleaning the (R013) server code (eliminating unneeded things) to make it easier to handle it and then eventually create a GUI.
Another thing to clarify is the error handling.
That's cool Roberto. I will wait. :)
HMGSRIPT R014
Now, the server starts as a 'minimized to tray' GUI mode application.
I've added two new server functions, cleaned a little the code and modified server demo.
APPEND: (Server Function)
Appends a record.
Syntax:
	Append( cTable , aColumns , aValues )
ERASE: (Server Function)
Erases a record.
Syntax:
	function Erase( cTable , cForExpr )
Enjoy!
hmgs014.zip
(837.92 KiB) Downloaded 308 times
Thanks a lot Roberto. It is nice improvement.
Hola estimados,
les dejo mi clase tabla.
Con ella pueden mostrar registros en una tabla, mostrarlos por pagina, agrega, modificar, borrar registros.
Espero sea de utilidad.
Saludos cordiales,
Luis Vasquez.
tabla.zip
(21.45 KiB) Downloaded 301 times
Nice nice ! congratulations !!! Very very good !
Muy bueno ! Genial !
Muchas gracias por compartir, Luis Vasquez !
luisvasquezcl wrote:Hola estimados,
Saludos cordiales,
Luis Vasquez.
Very interesting.
Could be very good if you could create server side functions for it, to handle dbf tables.
Roberto,
tengo un demo con php y dbf, voy a ver como implementarlo.
aun me queda por implementar para leer json y podría ser la
alternativa.
saludos cordiales,
luisvasquezcl wrote:Roberto,
alternativa.
saludos cordiales,
Sería una muy buena contribución para el proyecto.
Muchas Gracias.
