PDF Viewer DLL?
Steed
Re: PDF Viewer DLL?
Post by Steed »
Thanks a lot, every time this tool is more usefull
KDJ
Re: PDF Viewer DLL?
Post by KDJ »
PdfView version 2017-11-27 released.
Added:
- ability to translate of selected text in PDF document using Google (MainMenu -> Document -> Translate selected text).
Added in SumatraPDF.prg library:
- function Sumatra_SelectAll,
- function Sumatra_GetSelText.
PdfView.zip
(8.42 MiB) Downloaded 960 times
Re: PDF Viewer DLL?
Dzięki Krzysztof.
Re: PDF Viewer DLL?
Thank you Krzysztof
quartz565
Re: PDF Viewer DLL?
Post by quartz565 »
Thank you Krzysztof !
Nikos.
os: Windows Server 2019 - 64
KDJ
Re: PDF Viewer DLL?
Post by KDJ »
PdfView version 2018-05-02 released.
Added:
- show/hide files panel (Main menu -> View -> Files panel),
- opening file(s) via GetFile() function (Main menu -> File -> Open in ...),
- terminate all SumatraPDF child processes when an error occurs (PdfView_ErrorSys.prg),
- "Options" dialog (Main menu -> Settings -> Options),
- ability to set maximum tabs width,
- ability to drag and drop the tabs,
- ability to close all documents (Main menu -> Document -> Close all).
Fixed minor bugs.
Translations into Spanish and Portuguese are implemented only in about 30 percent (by Pablo César).
Can anyone translate the remaining 70 percent of the strings?
In the opposite case, I will have to remove Spanish and Portuguese translations from the project.
PdfView.zip
(8.54 MiB) Downloaded 840 times
Re: PDF Viewer DLL?
Thanks Edward, great job!
Re: PDF Viewer DLL?
serge_girard wrote: Wed May 02, 2018 5:12 pm Thanks Edward, great job!
Serge, you mean Krzysztof rather than Edward. ;)
KDJ = Krzysztof
edk = Edward
@ Krzysztof.
Wspaniale, dzięki. :D
Re: PDF Viewer DLL?
Of course! Sorry!!!
