Page 15 of 21
Re: HMG 3.1.5 (Test)
Posted: Sat Nov 02, 2013 5:19 am
by andyglezl
con MsgInfo( STR( VolSerial( "C:" ) ) obtengo "2696837951".
Entonces no me queda claro porque HDGETSERIAL me da otro
numero diferente ???. Creo que tendre que cambiar de todos modos.
Gracias
with MsgInfo( STR (VolSerial("C:") ) I get "2696837951".
So I'm not clear because HDGETSERIAL gives me another
different number???. I think I'll have to change anyway.
thanks
Posted: Sat Nov 02, 2013 8:37 am
andyglezl wrote: with MsgInfo( STR (VolSerial("C:") ) I get "2696837951".
It's impossible to know why it gives a different number, without seeing source code of HDGETSERIAL :(
Posted: Sat Nov 02, 2013 9:47 am
andyglezl wrote:con MsgInfo( STR( VolSerial( "C:" ) ) obtengo "2696837951".
Gracias
thanks
Andy :
probaste con el ejemplo que indique anteriormente ?
Getserial.rar
(7.63 KiB) Downloaded 294 times
Posted: Sun Nov 03, 2013 4:20 am
by andyglezl
OK, Ya me funciona el ejecutable. ( quite la funcion MAKELAYER )
La funcion HDGETSERIAL("c:\") la he estado utilizando desde hace años pero no recuerdo
de donde la obtuve, ademas esta en C y siempre despliega el "warning" al compilar.
OK, I already runs the executable. (Remove the function MAKELAYER)
The function HDGETSERIAL ("c: \") I've been using for years but can not remember
where I got it, also is in C and always displays the "warning" to compile.
Harbour 3.2.0dev (r1307180024)
Copyright (c) 1999-2013, http ://harbour-project.org/
conad.prg: In function 'HB_FUN_HDGETSERIAL':
conad.prg:8007:5: warning: passing argument 1 of 'Get_SerialNumber' discards 'const' qualifier from pointer target type [enabled by default]
conad.prg:7998:19: note: expected 'char *' but argument is of type 'const char *'
conad.prg: In function 'HB_FUN_MAKELAYER':
conad.prg:8239:9: warning: implicit declaration of function 'SetLayeredWindowAttributes' [-Wimplicit-function-declaration]
Warning: resolving _SetLayeredWindowAttributes by linking to _SetLayeredWindowAttributes@16
Use --enable-stdcall-fixup to disable these warnings
Use --disable-stdcall-fixup to disable these fixups
resumiendo.
summarizing.
HDGETSERIAL()                              // -1598129345
VOL en D.O.S.                                        // A0BE7B3F
NTOC (VolSerial ("C:"), 16)                          // A0BE7B3F
STR( VolSerial( "C:" ) )                            // 2696837951
NTOC( 2696837951, 16 ) )                             // A0BE7B3F
NumToHex( VolSerial( "C:" ) )                     // A0BE7B3F
NumToHex( HDGETSERIAL("c:\") )                    // FFFFFFFFA0BE7B3F
Las pruebas anteriores indican que:    A0BE7B3F = 2696837951 = -1598129345
Previous tests indicated that:
A fin de cuentas, llegue al mismo resultado. Gracias.
After all, reach the same result.Thanks.
Ahora me falta resolver la funcion MAKELAYER()
Now I need to solve MAKELAYER() function
Posted: Sun Nov 03, 2013 10:08 am
andyglezl wrote: Ahora me falta resolver la funcion MAKELAYER()
Que hace esa funcion Andy ?.
Posted: Sun Nov 03, 2013 10:47 am
Hola Andres
andyglezl wrote:Previous tests indicate that: A0BE7B3F = 2696837951 = -1598129345
I'm not a mathematician, but I know :
is correct, but
not !
If your function(s) are in binary format ( .lib or anything else ) it's difficult to help you, I think :(
Posted: Sun Nov 03, 2013 2:32 pm
by srvet_claudio
andyglezl wrote:OK, Ya me funciona el ejecutable. ( quite la funcion MAKELAYER )
Hi Andres,
display lines numbers 8007, 7998 and 8239 (+/- 10 lines) of file conad.prg
Posted: Sun Nov 03, 2013 3:28 pm
by andyglezl
Yo reprobé matematicas, asumo que es igual en base al resutado obtenido.
I failed in mathematics, I assume it's just based on the result set obtained.
La funcion MAKELAYER() hace transparente la ventana, aqui están la rutinas en "C":
The MAKELAYER() function makes the window transparent,Here are the routines in "C":
    unsigned long Get_SerialNumber(char* RootPathName)
    unsigned long SerialNumber;
    GetVolumeInformation(RootPathName, NULL, 0, &SerialNumber, NULL, NULL, NULL, 0);
    return SerialNumber;
    HB_FUNC( HDGETSERIAL)
    hb_retnl( Get_SerialNumber(hb_parc(1)) );
    #define WS_EX_LAYERED 0x80000
    #define LWA_COLORKEY 1
    #define LWA_ALPHA 2
    WINUSERAPI
    BOOL
    WINAPI
    SetLayeredWindowAttributes(
        HWND hwnd,
        COLORREF crKey,
        BYTE bAlpha,
        DWORD dwFlags);
    HB_FUNC ( GETWINDOWLONG )
       hb_retnl( ( LONG ) GetWindowLong( ( HWND ) hb_parnl( 1 ), hb_parni( 2 ) ) );
    HB_FUNC ( SETWINDOWPOS )
        HWND hwnd           = (HWND) hb_parnl(1);    // handle to window or control
        HWND hWndInsertAfter= (HWND) hb_parnl(2);    // placement-order handle
        int X               =        hb_parni(3);    // horizontal position
        int Y               =        hb_parni(4);    // vertical position
        int cx              =        hb_parni(5);    // width
        int cy              =        hb_parni(6);    // height
        UINT uFlags         = (UINT) hb_parni(7);    // window-positioning options
        hb_retl( (BOOL) SetWindowPos( hwnd, hWndInsertAfter, X, Y, cx, cy, uFlags ) );
    HB_FUNC ( SETLAYEREDWINDOWATTRIBUTES )
    COLORREF crKey        = (COLORREF) hb_parnl(2);
    BYTE bAlpha           = (BYTE)     hb_parni(3);
    DWORD dwFlags         = (DWORD)    hb_parni(4);
    hb_retl( (BOOL) SetLayeredWindowAttributes(hwnd, crKey, bAlpha,  dwFlags) );
    HB_FUNC (MAKELAYER)
        SetWindowLong (hwnd , GWL_EXSTYLE ,
        GetWindowLong (hwnd , GWL_EXSTYLE ) | WS_EX_LAYERED ) ;
        SetLayeredWindowAttributes(hwnd, 0, crKey, LWA_ALPHA);
Gracias. Thanks.
Posted: Sun Nov 03, 2013 5:55 pm
esgici wrote: It's impossible to know why it gives a different number, without seeing source code of HDGETSERIAL :(
While digging my moldy archives, found two HDGETSERIAL functions :o
No any neat and useful hint but as far as I see ;
if function used by Andres is the same and
function invoked from other than current drive and
no parameter ( drive code ) specified
than it returns a negative value.
Screen shoot of comparison HD Serial number functions
HDSerComp.zip
Source files of comparison HD Serial number functions
(1.27 KiB) Downloaded 257 times
Posted: Sun Nov 03, 2013 6:23 pm
by srvet_claudio
Para:
andyglezl wrote: conad.prg: In function 'HB_FUN_HDGETSERIAL':
cambia:
por:
    hb_retnl( Get_SerialNumber((char *) hb_parc(1)) );
Para el error:
andyglezl wrote:conad.prg: In function 'HB_FUN_MAKELAYER':
Agrega al inicio enseguida del #pragma BEGINDUMP
#define _WIN32_WINNT 0x0500
Con HMG.3.1.5 para hacer una ventana transparente tenes:
SET WINDOW <cFormName> TRANSPARENT TO COLOR <aColor>
