HMG 3.1.1
Re: HMG 3.1.1
danielmaximiliano wrote:
srvet_claudio wrote:
srvet_claudio wrote:Hi All.
I attached a patch for source code of HMG.3.1.1
Claudio.
Hola Claudio: Como siempre muchas gracias por su esfuerzo en las contribuciones para con HMG.
este segundo patch contiene el 1° patch ? sino es asi puede ser un nuevo topico acerca del mismo( Patch para HMG.3.1.1)
Hi Daniel.
Yes, this 2nd patch includes first patch.
Un abrazo,
Claudio.
Re: HMG 3.1.1
srvet_claudio wrote: ...
This is a new patch for HMG.3.1.1
Hi Dr
- re-installed HMG_3.1.1 to a new folder ( clean install )
- Open hmg.3.1.1_patch2.rar to this folder by overwrite
- run buildlib.bat
- open MENU_Dynamic_Demo\demo.hbp by HMG_IDE
- build and run
C:/hmg/lib/libhmg.a(c_winapimisc.o):c_winapimisc.c:(.text+0xac): undefined reference to `HMG_WCHAR_TO_CHAR'
C:/hmg/lib/libhmg.a(c_dialogs.o):c_dialogs.c:(.text+0x840): undefined reference to `HMG_CHAR_TO_WCHAR
- add
#include "HMG_UNICODE.h"
line to (top of) C:\hmg_3.1.1\INCLUDE\minigui.ch
- run buildlib.bat
- build and run
C:\hmg_3.1.1\include\HMG_UNICODE.h(51) Error F0029 Can't open #include file 'tchar.h'
Where I'm wrong :cry: :?:
Note : there are multiple notes in harbour\changelog.txt such as:
2012-11-27 21:23 UTC+0100 Przemyslaw Czerpak (druzus/at/poczta.onet.pl)
* do not include <tchar.h>, current code does not use
any tchar functions and macros and some older MinGW
versions are broken and this files breaks some standard
unicode macros like TEXT()
I don't know is there any relation :(
TIA
Re: HMG 3.1.1
Maybe it's time to create new full version?
Re: HMG 3.1.1
Hi Dr
- run buildlib.bat
- build and run
- add
- run buildlib.bat
- build and run
TIA
Hi Esgici.
Wow, is strange problem ... :?: in my two laptop works ok (XP and 7).
Please:
1) delete the line (you add): #include "HMG_UNICODE.h" of the file C:\HMG.3.1.1\INCLUDE\minigui.ch
2) Test if in the file C:\HMG.3.1.1\INCLUDE\HMG_UNICODE.h have the lines:
    #define HMG_CHAR_TO_WCHAR(c)     ((c != NULL) ? hb_osStrU16Encode(c) : NULL)  // return WCHAR
    #define HMG_WCHAR_TO_CHAR(c)      hb_osStrU16Decode(c)                       // return CHAR
3) See if the beginning of the file C:\HMG.3.1.1\SOURCE\c_winapimisc.c, c_dialogs.c, ... have the line: #include "HMG_UNICODE.h"
4) See if file C:\HMG.3.1.1\hmg.hbp is:
-hblib
-olib/hmg
-Iinclude
-D__HBIDE__
-w2 -es2
source/UNICODE_STRING.prg
source/ErrorSys.prg
source/h_browse.prg
Hope it works :!:
Claudio
Re: HMG 3.1.1
mol wrote:Maybe it's time to create new full version?
Yes, it's the best.
Re: HMG 3.1.1
esgici wrote: ...
FOUND !
Guilty is C:\hmg.3.1.1\IDE\hmg.ini ( Not me :lol: )
I'm changing ( very frequently ) HMG root folder name ( hmg, hmg.3.1.1, hmg.311, hmg_3.046 etc ).
HMG_IDE always look at C:\hmg.3.1.1\IDE\hmg.ini for HMG root folder ( HMG path) :(
I must modify content of that hmg.ini depending on HMG root folder whenever changed :!:
Sorry Dr and other friends interested :oops:
By the way; it's important enhancement ability to change menu content ( especially for language ) :arrow:
Separate thanks for this Dr. :)
Re: HMG 3.1.1
Now is the time for a new version. :)
Re: HMG 3.1.1
rathinagiri wrote:Now is the time for a new version. :)
Definitely :!:
Re: HMG 3.1.1
esgici wrote:
esgici wrote: ...
FOUND !
It's ok, no problem. :D
Re: HMG 3.1.1
srvet_claudio wrote: It's ok, no problem. :D
Hello Dr. Soto,
There is a GDI bitmap resources leak in the current GdiPlus usage.
My test sample is below:
 * http://www.hmgforum.com//
        DEFINE WINDOW Win_1 ;
                WIDTH 640 HEIGHT 480 ;
                TITLE 'Main Window' ;
                ICON 'WORLD' ;
                MAIN
                @ 200,140 IMAGE Image_1 ;
                        PICTURE 'img.gif' ;
                        WIDTH 200 ;
                        HEIGHT 200
                @ 10 ,10  BUTTON Button_1 CAPTION "Set png" ACTION test() WIDTH 100  HEIGHT 30
                @ 10 ,110 BUTTON Button_2 CAPTION "Set jpg" ACTION Win_1.Image_1.Picture := "img.jpg" WIDTH 100  HEIGHT 30
                @ 10 ,210 BUTTON Button_3 CAPTION "Set ico" ACTION Win_1.Image_1.Picture := "img.ico" WIDTH 100  HEIGHT 30
                @ 10 ,310 BUTTON Button_4 CAPTION "Set wmf" ACTION Win_1.Image_1.Picture := "img.wmf" WIDTH 100  HEIGHT 30
                @ 10 ,410 BUTTON Button_5 CAPTION "Set cur" ACTION Win_1.Image_1.Picture := "img.cur" WIDTH 100  HEIGHT 30
                @ 10 ,510 BUTTON Button_6 CAPTION "Set bmp" ACTION Win_1.Image_1.Picture := "demo.bmp" WIDTH 100  HEIGHT 30
        ACTIVATE WINDOW Win_1
func test
local i
for i:=1 to 1000
Win_1.Image_1.Picture := "img.png"
do events
next
retu nil
We have 1(one) unreleased bitmap resource at the each step of iteration (tested via GDIView utility from http://www.nirsoft.net/) :roll:
What is your opinion?
