HMG_HPDF - Export to PDF made easy... (New Version)
Thanks Roberto.
You want to specify some columns only for exporting?
- HMG Founder
Usually, my application's grids has lots of columns, but I only need to print the most relevant (because space limitations), so have an option to specify which columns to print programmatically, could be great.rathinagiri wrote:Thanks Roberto.
If such option does not exists yet, I guess that a logical array parameter could be a good solution.
TIA.
Hi Roberto,
Since I have adapted _GridPDF from _GridPrint we can select the columns to be printed as well.
These are the parameters for the function _GridPDF. This function can be used to make a PDF of a two dimensional array also.
_gridpdf(cGrid, cWindow, cPDFFile, fontsize, orientation, aHeaders, fontname1, showwindow1, mheaders, summation, aArrayData, aArrayHeaders, aArrayJustify, aColumnWidths, nPaperSize, nPaperWidth, nPaperHeight, lVerticalLines, lHorizontalLines, nLeft, nTop, nRight, nBottom )
I will explain one by one:
cGrid - Name of the Grid control. Can be omitted if an array is to be exported.
cWindow - Name of the Window. Can be omitted if an array is to be exported.
cPDFFile - Name of the PDF file to be exported.
fontsize - Normal print fontsize.
orientation - "P" for portrait and "L" for Landscape
aHeaders - An array of Headers having maximum three strings to be repeated on each page. This will be printed bold with a higher fontsize than the normal one.
fontname1 - Name of the font
showwindow1 - GridPDF window to be shown or not.
mHeaders - An array of Merge Headers in the format { { nStartCol, nEndCol, cHeaderName },... } eg., { { 2, 4, 'This is the merged header for columns 2, 3, 4 } }
Summation - An array of '0's and '1's to specify which column values are to be summed up.
aArrayData - Only required in array printing mode. If it is for Grid, it can be omitted.
aArrayHeaders - Column Headers in case of array mode.
aArrayJustify - Column Justification in array mode.
aColumnWidths - An array of column widths in mm for each column. You can put '0' if you don't want to print a column.
nPaperSize - Paper size constant from ch file.
nPaperWidth - User defined Paper Width in mm
nPaperHeight - User defined Paper Height in mm
lVerticalLines - .t. if column separation line required.
lHorizontalLines - .t. if row separation line required.
nLeft - Left margin of the page in mm
nTop - Top margin of the page in mm
nRight - Right margin of the page in mm
nBottom - Bottom margin of the page in mm
So, you can leave column without exporting using the values in aColumnWidths to be 0.
- HMG Founder
Thanks for the detailed explanation.rathinagiri wrote:Hi Roberto,
It will be extremely useful for me.
As I've said in a previous message, IMHO, it should be integrated at HMG core as a method for grid.
Thanks again for your great work.
- HMG Founder
I've made another little modification, added a command to print directly (from a post on this thread).
- pdf.zip
- (245.64 KiB) Downloaded 686 times
- HMG Founder
OOPS!
I've realized that I've was not working with the last HPDF version.
Could be you so kind to provide a link to it?
TIA.
TIA.
- HMG Founder
Thanks!
- HMG Founder
This is the final version of modified HPDF (I've applied changes to its current version now).
Summary of changes:
- New SET PRINTSYSTEM PDF command.
- 'HPDF' prefix to commands and constants changed to 'PRINT'
- New clause 'PREVIEW' to SELECT PRINTER command.
- New command 'OPEN FILE' (alias for EXECUTE FILE)
- New command PRINT FILE <cFile> [ TO <cPrinter> ]
I'll add this modified HPDF version to uHTTP server bundled with HMGSCRIPT and work on server side PDF generation.
Hopefully (if I find enough time to do it) I'll publish a new HMGSCRIPT version soon.
Summary of changes:
- HPDF.zip
- (374.37 KiB) Downloaded 747 times
Thanks a lot Roberto;
It's wonderful as always
I hope a new version of HMG_3 before HMG_5 ( HMG_Script )
With my best regards.
