REALLY IMPORTANT: is anyone interested in HMG4 ?
l3whmg
Re: REALLY IMPORTANT: is anyone interested in HMG4 ?
Post by l3whmg »
Hi Rathinagiri
After a brief and quickly check, I found many compiler error. Here some examples and my mod marked L3W
#include "dbstruct.ch"
#include "hbqtgui.ch"   //L3W
MEMVAR oDB           //L3W
MEMVAR oDB1          //L3W
MEMVAR cTableName    //L3W
MEMVAR cNewTable     //L3W
MEMVAR lOpened       //L3W
MEMVAR sql1
hmg3( .t. )
HbQt_ErrorSys()
PUBLIC sql1 := nil   //L3W
other type of error are
sql1.center()     //L3W
sql1.activate()   //L3W
and the other type
function browsefordbf
local fname                //L3W := sql1.dbfname.value
local structarr            //L3W := {}
I can't compile your example
Luigi from Italy
www.L3W.it
Yes. But I could compile and run it with -w0 switch. I am sure my programming style should change. That would be for starting a new project in HMG4.
However, for existing projects I think -w0 will be helpful.
l3whmg
Post by l3whmg »
Hi Rathinagiri.
I'm working on it.
But please tell me if your problem is about "to compile" or about HMG4.
rathinagiri wrote:However, for existing projects I think -w0 will be helpful.
Clipper and Harbour are the same? Yes, but Harbour compiler is most powerfull then Blinker or Rtl, etc. IMHO, the usage of new options can help you to catch some "problems" and keep your project aligned with this compiler.
On the other hand, you can change and customize options within your batch commands.
Every time I download HMG4 I must/want change the standard batch commands....
For example adding other helpfull options (little example)
SET PRGFLAG=-w3 -es2 -gtgui
SET WORKDIR=.\Temp
HBMK2 -oFileName.exe -gui -prgflag=%PRGFLAG% -strip -trace -icon=your.ico -workdir=%WORKDIR% FileSource > %HRBLOG% 2>&1
-w3 and -es2 to keep a good code. I always recommended (on this forum many times) to use these to solve problem about Harbour/Clipper syntax. Mr Pritpal has recommended use of it regarding library compilation.
-strip to strip binaries
-workdir to prevent creation of a lot temporary working directory (..\Document and Settings\..... ) within your system directories, ecc.
- I recommended to everyone to use ".hbp" and ".hbc" files for your little/big project instead a generic "hbmk.hbm" file
So, with "HMG4" (see demo) these are not adopted: why?
But I see the "-run" option, but I think it's dangerous. Many times, I got a crash because my AV don't wants handle in a right way the new program and its dependencies.....and I removed it
Well, I'm working on your program.
Cheers
Luigi from Italy
www.L3W.it
Thanks Luigi.
My problem is not regarding compilation.
I wanted to know why progressbar in my code is not working. That's all.
l3whmg
Post by l3whmg »
Ok, I'm investigating
Cheers
Luigi from Italy
www.L3W.it
l3whmg
Post by l3whmg »
Hi Rathinagiri.
I found the problem. I will do a commit, but you can try by your self.
Inside hmg.ch search DEFINE PROGRESSBAR....
Probably you will find
Wth Object [<varname> :=] With Object PROGRESSBAR.......
You must change in
Wth Object [<varname> :=] PROGRESSBAR.......
In attachement what I change/made to try your program.
ASAP I will commit.
Best regards
xRathi.zip
you program
(4.96 KiB) Downloaded 320 times
Luigi from Italy
www.L3W.it
Thanks Luigi. :)
l3whmg
Post by l3whmg »
Hi Rathinagiri
I done a commit viewtopic.php?f=32&t=1777&p=18193#p18193
Cheers and many thank to you
Luigi from Italy
www.L3W.it
