Page 11 of 21
Re: HMG 3.4.4
Posted: Sun Apr 01, 2018 11:35 pm
by andyglezl
Hola Nikko, bienvenido al foro
Una pregunta, ejecutaste "c:\hmg_344\Build.bat pagodil.prg"
o solo "c:\hmg_344\hbmk2 pagodil.prg"
Hello Nikko, welcome to the forum
One question, you ran "c:\hmg_344\Build.bat pagodil.prg"
or just "c:\hmg_344\hbmk2 pagodil.prg"
Re: HMG 3.4.4
Posted: Mon Jun 18, 2018 9:01 am
by mol
Hi Guys!
I'm trying to add RichEditBox control to the Tab.
It causes IDE error:
Error BASE/1081 Argument error: +
Called from GENCODE(28201)
Called from SAVE(26902)
Called from (b)NEW(2164)
Called from _DOWINDOWEVENTPROCEDURE(6091)
Called from EVENTS(3523)
Called from DOMESSAGELOOP(0)
Called from DOMETHOD(9003)
Called from _OPEN(26326)
Called from EDITFILE(30306)
Called from (b)MAIN(1077)
Called from EVENTS(2015)
Called from HMGMAKE(39542)
Called from BUILDPROJECTM(36907)
Called from RUNAPPLICATION(31697)
Called from (b)NEWBUILD(39615)
Called from EVENTS(828)
Called from (b)SHOWLOG(43070)
Called from SHOWLOG(43239)
Called from NEWBUILD(39637)
Called from (b)HMGMAKE(39528)
Called from _PROCESSINITPROCEDURE(5876)
Called from _ACTIVATEWINDOW(5691)
Called from (b)MAIN(623)
Called from MAIN(1253)
Re: HMG 3.4.4
Posted: Mon Jun 18, 2018 9:24 am
by edk
Sorry Marek, but I can not reproduce this issue
- Bez tytułu.png (98.36 KiB) Viewed 40437 times
Re: HMG 3.4.4
Posted: Mon Jun 18, 2018 10:06 am
by mol
Try to add richeditbox on second tab
PS. I'm using ANSI version of IDE
Re: HMG 3.4.4
Posted: Mon Jun 18, 2018 10:50 am
by edk
On second tab is also OK, but... if I load the form to IDE-ANSI, all RichEditBoxes disappears!
While saving the form occurs errors as you report.
Re: HMG 3.4.4
Posted: Mon Jun 18, 2018 2:04 pm
by mol
When I add RichEditBox to second Tab, it disappears - it looks like RichEditBox is placed under the Tab.
When I try to save form - error occurs.
Re: HMG 3.4.4
Posted: Thu Jun 21, 2018 3:18 pm
by koke
Hola mol
Estoy trabajando en un programa con RICHEDITBOX y no puedo hacer que funcione, lo e compilado con varias versiones y no sé qué está pasando, no me marca ningún error al compilar pero no aparece en mi aplicación tengo que utilizar la versión 3.2 de HMG para que me aparezca estoy trabajando con IDE-ANSI y la versión 3.4.3.
Tengo que incluir alguna librería?
Gracias
Traducción por google
Hello mol
I'm working on a program with RICHEDITBOX and I can not make it work, I've compiled it with several versions and I do not know what's happening, I do not mark any errors when compiling but it does not appear in my application I have to use version 3.2 of HMG so that I appear I am working with IDE-ANSI and version 3.4.3.
Do I have to include a library?
Thank you.
Re: HMG 3.4.4
Posted: Thu Jun 21, 2018 3:49 pm
by mol
Hi Koke!
I didn't attach any additional library.
Error, which I've reported is bounded with IDE.
My application works OK with few richeditboxes.
Maybe you can prepare small sample?
Re: HMG 3.4.4
Posted: Thu Jun 21, 2018 4:35 pm
by koke
En el adjunto agrego dos exes compilados en diferentes versiones de HMG
traducción por google
In the attachment I add two exes compiled in different versions of HMG
Re: HMG 3.4.4
Posted: Fri Jun 22, 2018 12:59 pm
by mol
I think the problem is with IDE Ansi version. I didn't test UNICODE version.
But, we can not try to resolve it while we have no access to source code of IDE.
