PDF Viewer DLL?
KDJ
Re: PDF Viewer DLL?
Post by KDJ »
Pablo
I divided the project into two files:
- PdfView.prg - with Harbour functions,
- PdfView_C.c - with C functions.
How it compile using HMG IDE?
Test_source.zip
(10.07 KiB) Downloaded 449 times
Re: PDF Viewer DLL?
Hi Krzysztof,
You have prepared into two files, it's a good way to let ready for adopting these C functions at HMG core. :)
By the way, these C functions are useful and there are not similar one at HMG core.
I hope be incorporated to us as well libSumatraPDF library. :)
KDJ wrote: Sat Apr 22, 2017 7:38 pm How it compile using HMG IDE?
By habit and practicity we use to put C functions at the same place of prg sources.
But how to do in good order having in mind our IDE ?
As far I know, IDE works in conjunction with Build.bat file and works with three parameters at build proccess:
  1. /option ( [ /n ] [ /d ] [ /c ] )
  2. prgfile (main prg) or hbpfile
  3. hbcfile
But in this case, saving the c file at hbp file, is not good idea because IDE will not be considered and will cut off out... :(
In Harbour is correct to include in hbp file but with different name of PRG file taking this in consideration (to avoid conflict).
Probably our IDE should be changed this behaviour during its re-writing hbp files on building process. :?
What I have been done in this case when C file need to be builded separated from PRG is to put at main PRG file as include file:
It's not a elegant way in my view but it will garantee to be linked.
I very much appreciate your concern to leave the compilation universally with the options we have in HMG. :D
Re: PDF Viewer DLL?
In Harbour's ChangeLog there has long been this configuration:
Added -bldflags option which tells hbmk to also
apply user build flags (HB_USER_*FLAGS) used when
building Harbour.
Added new flags to replace -bldflags[-]:
-bldf[-] and -bldf=[p][c][l]. We can pass any combinations
to the latter. '-bldf=' is the same as '-bldf-'.
To consider that at the time of compilation you can inherit flags from the Harbour.
This is not the same case but just for your information.
I've never used it, so I can not give you more details, maybe you can figure it out.
https://www.google.com.br/search?q=bldf ... r+bldflags
KDJ
Re: PDF Viewer DLL?
Post by KDJ »
Hi Pablo
Thank you very much for your explanation.
For compile via IDE, I found another solution - C functions in PdfView_C.prg.
PdfView_source.zip
(15.21 KiB) Downloaded 503 times
In new version:
- added ability to translate the interface,
- added Polish translation.
Re: PDF Viewer DLL?
A Huge "Thank You"
Re: PDF Viewer DLL?
You are welcome Krzysztof and happy you give a way putting at PRG for IDE proposes. :)
I also liked the language option which is a good step for the user to create their translations for their own language.
By the way, have you seen my project Google Translate and HMG ?
I've used this at PrintFile thinking to make easier for users at translation process .
I loved the way applied by Google Translator and ActiveX and what they can do together...
Thank you for your new release and congratulations. Excellent job. :P
quartz565
Re: PDF Viewer DLL?
Post by quartz565 »
Thank you Krzysztof !!
Nikos.
os: Windows Server 2019 - 64
quartz565
Re: PDF Viewer DLL?
Post by quartz565 »
KDJ wrote: Mon Apr 24, 2017 8:21 pm For compile via IDE, I found another solution - C functions in PdfView_C.prg.
Compiling in IDE, it works perfectly !!
(Tested on windows 10 and Windows Server 2012)
Τhank you again !
Nikos.
vagblad
DBs Used: MySQL,DBF
Re: PDF Viewer DLL?
Post by vagblad »
I've checked the option "Open pdf at once" and from the toolbar the zoom option "Fit to page" (ctrl+0)
Everytime you scroll down the grid to another file the pdf opens in "Fit Width" mode. So i have to click the Fit to page button again or press Ctrl+0 everytime.
This could be a problem for someone who just wants to make a quick check on the pfd or use the whole thing as a preview browser.
I went and added inside PdfView.prg the following :
Sumatra_Zoom(cPanel, 2)
in 2 places. At the end of the FIleopen Function and at the end of Filereopen function. It works ok now for me but it does a small flickering of the screen everytime you change files, because at first it opens the pdf in fit to width mode and then goes to fit to page mode again.
Is there any way to use the "Fit to page" mode by default?
Thanks for your great work.
Vagelis Prodromidis
vagblad
DBs Used: MySQL,DBF
Re: PDF Viewer DLL?
Post by vagblad »
After a few tries we've decided to do the following:
Added a new line at the end of the pdfview.ini:
Zoom=fit page
Now inside SumatraPDF.prg we changed the line 74 to:
EXECUTE FILE '"' + cExeFile + '"' PARAMETERS '-zoom ' + '"' + cZoom + '"' + ' -page ' + HB_NtoS(nPage) + ' -lang ' + cLang + ' -plugin ' + HB_NtoS(GetProperty(cPanel, 'HANDLE')) + ' "' + cPdfFile + '"'
At the PdfView.prg we made the following changes and additions:
Line 33: Added the static czoom variable:
STATIC cZoom
Line 240,241,242 :
MENUITEM LangStr("FitPage") + e"\tCtrl+0"        NAME FitPage      ACTION {Sumatra_Zoom(cPanel, 2), cZoom := "fit page"}
MENUITEM LangStr("RealSize") + e"\tCtrl+1"       NAME SizeReal     ACTION {Sumatra_Zoom(cPanel, 3), cZoom := "actual size"}
MENUITEM LangStr("FitWidth") + e"\tCtrl+2"       NAME FitWidth     ACTION {Sumatra_Zoom(cPanel, 4), cZoom := "fit width"}
At the FUNCTION SettingsRead()
line 1029:
cZoom        := "fit page"
line 1053:
        CASE "Zoom"        ; cZoom        := cValue          ; EXIT
and finally at the Function SettingsWrite() lines 1109 and 1110:
           "Lang="        + cLang + CRLF + ;
           "Zoom="        + cZoom + CRLF
With this way we use the fit page as default viewing method and everytime you change it from the menu it saves the new value inside the ini file. That did the trick for us and i thought i should share it.
I am attaching the files as well. Thanks again.
PdfView.zip
(12.71 KiB) Downloaded 447 times
Vagelis Prodromidis
