HMG 3.0 (Test XII)
Re: HMG 3.0 (Test XII)
I wanna post report and dbf, where I have problem with polish characters.
report_pl_chars.zip
(1.77 KiB) Downloaded 358 times
Roberto Lopez wrote:
mol wrote:I have a question:
How to connect to MySQL database without mysql.lib when ADO is removed from harbour?
Via ODBC, but, you should install MySql ODBC client (I guess that there is no licensing problems with it).
For a sample of ODBC usage, please look at \hmg\samples\rdd.sql\mdb.
I don't know how to link all my informations for working app.
When I connect to MySQL database via ODBC, I get connection, but, after, when I send request to database, I get error:
Error SDDODBC/1902 Invalid field type: SELECT * FROM country (DOS Error 65528)
Called from DBUSEAREA(0)
CALLED FROM MAIN(43)
	odp := RDDINFO( RDDI_CONNECT,;
		{ "ODBC", "DBQ=" +"Server=localhost;Driver={MySQL ODBC 5.1 Driver};dsn=;User=root;password=123;database=korespondencja;Option=3;"} )
	if odp = 0
                //not connected
		return
	// it's required to use record locking to set autocommit to 0!!!!
	RDDINFO(RDDI_EXECUTE,"SET AUTOCOMMIT = 0")
	DBUSEAREA( .T.,, "SELECT * FROM country", "country" )
I can place all sample if sb. want to access to test it.
Marek
mol wrote:I wanna post report and dbf, where I have problem with polish characters.
Thanks Marek. I'll try to catch the problem.
	if odp = 0
                //not connected
		return
Marek
I've not attempted to use MySql via ODBC yet (I've just pointed that it could be possible) so, I have not info right now to help you on that.
Connecting to database, inserting rows works OK. But I can't retrieve data by select...
Don't you know Roberto, where to find more info about RDDSQL?
I can't find anything with google.
I've tried to write to Przemek Czerpak, but, I think, I have bad address.
Best regards, Marek
mol wrote:Connecting to database, inserting rows works OK. But I can't retrieve data by select...
Best regards, Marek
RDDSQL author is Mindaugas Kavaliauskas <dbtopas at dbtopas.lt>
Here is the library source code and samples from Harbour sources.
rddsql.rar
(54.95 KiB) Downloaded 395 times
I've written to him, but he couldn't help me.
I think, I will leave this topic.
I think, it must be a little bug in RDDSQL.
Regards, Marek
I've made some tests and found, that RDDSQL with MySQL and ODBC have problem with CHAR, VARCHAR or TEXT fields.
I'm writing with Mindaugas Kavaliauskas <dbtopas at dbtopas.lt> about this problem.
I'll inform you about results.
I'm very interesting to make working example with Mysql, RDDSQL and ODBC with record locking.
Best regards, Marek
mol wrote:I've made some tests and found, that RDDSQL with MySQL and ODBC have problem with CHAR, VARCHAR or TEXT fields.
Hello Marek,
I was able to connect and select data from mysql table by RDDSQL and mysql ODBC connector 3.51.
Take a look for the working sample below:
 * Copyright 2002-2009 Roberto Lopez <harbourminigui@gmail.com>
 * Copyright 2009 Grigory Filatov <gfilatov@freemail.ru>
 * Based on RDDSQL ODBC sample included in Harbour distribution
#include "minigui.ch"
#include "dbinfo.ch"
#include "error.ch"
#define RDDI_CONNECT          1001
#define RDDI_DISCONNECT       1002
#define RDDI_EXECUTE          1003
ANNOUNCE RDDSYS
REQUEST SQLMIX, SDDODBC
Function Main()
LOCAL nConnection
	RDDSETDEFAULT( "SQLMIX" )
	SET( _SET_DATEFORMAT, "yyyy-mm-dd" )
	nConnection := RDDINFO( RDDI_CONNECT, { "ODBC", "Server=localhost;Driver={MySQL ODBC 3.51 Driver};dsn=;User=root;database=test;" } )
	IF nConnection == 0
		MsgStop("Unable connect to the server!", "Error")
		Return nil
	DEFINE WINDOW Form_1 ;
		WIDTH 640 HEIGHT 480 ;
		TITLE 'MiniGUI ODBC Database Driver Demo' ;
		MAIN NOMAXIMIZE ;
		ON INIT OpenTable() ;
		ON RELEASE CloseTable()
		DEFINE MAIN MENU
			DEFINE POPUP 'File'
				ITEM "Exit"		ACTION ThisWindow.Release()
			END POPUP
		END MENU
		@ 10,10 BROWSE Browse_1	;
			WIDTH 610	;
			HEIGHT 390	;
			HEADERS { 'Code' , 'Name' , 'Residents' } ;
			WIDTHS { 50 , 160 , 100 } ;
			WORKAREA country ;
			FIELDS { 'country->Code' , 'country->Name' , 'country->Residents' } ;
			JUSTIFY { BROWSE_JTFY_LEFT, BROWSE_JTFY_LEFT, BROWSE_JTFY_RIGHT }
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
Return nil
Procedure OpenTable
   If CreateTable()
	INDEX ON FIELD->RESIDENTS TAG residents TO country
	GO TOP
   Else
	Form_1.Release()
   EndIf
Procedure CloseTable
   DBCLOSEALL()
Function CreateTable
Local ret := .T.
   RDDINFO(RDDI_EXECUTE, "DROP TABLE country")
   If RDDINFO(RDDI_EXECUTE, "CREATE TABLE country (CODE char(3), NAME char(50), RESIDENTS int(11))")
      If ! RDDINFO(RDDI_EXECUTE, "INSERT INTO country values ('LTU', 'Lithuania', 3369600), ('USA', 'United States of America', 305397000), ('POR', 'Portugal', 10617600), ('POL', 'Poland', 38115967), ('AUS', 'Australia', 21446187), ('FRA', 'France', 64473140), ('RUS', 'Russia', 141900000)")
	MsgStop("Can't fill table Country!", "Error")
	ret := .F.
      EndIf
   Else
	MsgStop("Can't create table Country!", "Error")
	ret := .F.
   EndIf
Return ret
arroya2
Post by arroya2 »
En Español.
Hola Roberto.
Mi pregunta es si esta versión de HMG 3.0 es fiable para trabajar con ella, o debo seguir usando HMG 2.9.5. Usted sabe que estoy comenzando a programar en HMG y no soy muy habilidoso que digamos.
Saludos cordiales.
Rafael Pérez
In English.
Hello Roberto.
My question is whether this version of HMG 3.0 is reliable to work with it, or should I keep using 2.9.5 HMG. You know I'm starting to program in HMG and I'm not very clever to say.
Rafael Perez
