IDE UPDATE (XIf)
Re: IDE UPDATE (XIf)
esgici wrote:Hello
Here my two cents :)
Thanks!
I've tested reports and have some comments.
First: when length of title of column is too long, report break it into 2 lines. But, separator is too high - look at image below:
Second: reports, or all HMG is printer driver' sensitive
Image above contains good letters when printer is set to HP OfficeJet 6500 (new ink driver).
Image below was a snapshot frtom preview, where printer was set to LaserJet 2100:
I think, problem is similar to that one, when I tried to print bolded text with internal HMG function.
Vanguarda
Post by Vanguarda »
Roberto Lopez wrote:Esgici, Marek, Vanguarda
Please, when possible, send me updated messages from 283 to 286.
TIA.
Hi Masters....
Sorry my delay again... :(
In attachment follow the new PtBR.LNG
My best regards,
PtBR.rar
(3 KiB) Downloaded 335 times
TIA.
Hi Masters....
My best regards,
Thanks!
mol wrote:I've tested reports and have some comments.
Regarding the title length, please consider that this is a first version. This will not feature double line titles. The fix for this will be limit the character count in titles input when required.
A second version (when the first be stable and tested enough) will include such feature (among others).
EDIT: Report generator calls the functions directly (the same as you've reported previously). So there is the key to solve it.
Thanks for reporting.
Vanguarda
Post by Vanguarda »
Master, i´ve a little doubt.
The app "IDE.EXE" not was created with "SET MULTIPLE OFF"?
Vanguarda wrote:Master, i´ve a little doubt.
No.
Vanguarda
Post by Vanguarda »
Roberto Lopez wrote: No.
Thanks.
fchirico
Post by fchirico »
Roberto Lopez wrote:Hi All,
This release features grouping support in report builder and DECLARE WINDOW <Current Window> statement in new code snippets.
Gracias Roberto!
Perdoname, estuve probando el GROUPING y no lo puedo hacer funcionar, si al reporte le saco el GROUPING funciona, de lo contrario aparece un error:
Date:11/14/09 Time: 21:08:18
Error BASE/1072 Argument error: <>
Called from EXECUTEREPORT(688)
Called from VER(8)
Lo he probado con distintas DBFs y siempre el mismo error. Seguramente esté haciendo algo mal.
Te adjunto 2 ejemplos, la carpeta "ejemplos" funciona ok y la carpeta "ejemplos2" es la que solo le agregué el GROUPING y no funciona.
Muchas gracias.
Saludos, Fernando Chircio.
ejemplos.zip
(27.23 KiB) Downloaded 319 times
Saludos, Fernando Chirico.
Gracias Roberto!
Called from VER(8)
Muchas gracias.
I've found the problem and already fixed.
I'll publish a fixed version ASAP.
