Xtract - Data Cube - V0.91 (Ready for release!)
Re: Xtract - Data Cube - V0.91a (Ready for release!)
Here comes the new bug fixed version of Xtract Data Cube - 0.91a
Kindly give your comments.
extract0.91a.zip
(20.46 KiB) Downloaded 693 times
Change Log:
- Fixed bug - double clicking filter prior to selecting row/col/data fields crashed Xtract. (Thanks Sudip and Fernando Chirico)
- Introduced tool bar buttons (Auto calc, Refresh, Print and Exit)
- Introduced Short-cut keys (F2 for auto calc, F5 for refresh, Ctrl+P for printing, Esc for Exit)
- Fixed some bugs
fchirico
Re: Xtract - Data Cube - V0.91 (Ready for release!)
Post by fchirico »
rathinagiri wrote:Hi Fernando Chirico, Sudip and Vanguarda
Now coming to your suggestions:
fchirico wrote: 2 - In a new version would be interesting if there is a button "REFRESH" for when you change a filter, as
Otherwise it should click on the DATACUBE and then click in the fields of filters to "REFRESH" to the DATACUBE.
rathinagiri wrote: I had given the toolbar buttons to either auto-create the cube or cube is created only after pressing the refresh button. I think this would be enough.
I think the same.
fchirico wrote: 3 - To select filters sometimes (when there are many records) you must double-click quickly on the field
to be filtered, otherwise it displays the message "please wait while Tabulating ..." but do not bring the values
(in control) to select the value for which you want to filter. If I double click it brings
rathinagiri wrote: This happens for a long table, especially having more number of rows/more number of columns. In that case, it is better to switch auto-cube off.
Sorry I dont understand "auto-cube off". How i do it this?
fchirico wrote: 4 - When analyzing data with dates, such as sales, must be analyzed by date ranges, so the
Current Filter DATE fields in not comfortable, it might be advisable before pressing the power button XTRACT
so select "SET FILTER TO" or similar.
rathinagiri wrote: Filter options are just primitive. Soon you can expect a better filtering interface and options.
The filters are right, and i think this are very helpfull. And I think they should be. Only i think that if existing a button, that making double click, work like a "set filter...".
fchirico wrote: 5 - To avoid having to run each time the same cube or to analyze the result in another time or to work with
other tools would be useful to export it to what you want.
rathinagiri wrote: I am planning to export the result to MS Excel/Openoffice Calc. Do you have any other options?
No, it's ok.
Now i'm going to prove your new version, than you.
Saludos, Fernando Chirico
Saludos, Fernando Chirico.
fchirico
Post by fchirico »
rathinagiri wrote:Here comes the new bug fixed version of Xtract Data Cube - 0.91a
extract0.91a.zip
Change Log:
- Fixed some bugs
I was evaluating the new version (09a), and is really expectacular, is fast and accurate.
1 - I wish I could choose the colors of the rows, columns and data
2 - would be great if they can save and load the settings of the skeleton of the cube
With these two new items requested, and export to Excel/Open Office, the tool becomes truly professional use. :ugeek:
My congratulations. :P
Regards, Fernando Chirico.
Thanks a lot Fernando. Now I am enhancing the features of filters. After that I shall implement your essential suggestions.
Thanks again.
Hi Rathi,
I tested it. Problem solved. :)
Thanks a lot :)
And sorry for the delayed feedback ;)
fchirico
Post by fchirico »
rathinagiri wrote:Thanks a lot Fernando. Now I am enhancing the features of filters. After that I shall implement your essential suggestions.
Thanks again.
SPANISH:
Rathi:
Quisiera solicitarte autorización para incluir el programa "xTract" que tu has desarrollado, en una aplicación mía. Si me da su autorización le pido por favor me indique qué datos suyos quisiera que muestre el botón de "About" de su programa Xtract.
Desde ya muchas gracias!
ENGLISH:
Rathi:
I would like to ask you for permission to include the "Xtract" that you've developed in my application. If you give me permission I ask please tell me what information about you want to show the button "About" of your program Xtract.
thank you very much!
It is my pleasure that my small part of code is useful to you. I have started this Xtract as an open source project. Therefore, you don't require my permission at all.
A simple mention of my name anywhere (like readme.txt/license file) is enough.
Thanks again for you.
fchirico
Post by fchirico »
Very thanks!
Dear Rathinagiri
Excellant Data Cube
Sir, any latest development
This is partof HFCL or separate utility ?
Thank you BPD.
I am just developing Xtract as a general UDF for analyzing grid/array/dbf data in a single command call. Please wait for the new release.
Thanks again for your interest.
