Lookup Table
Tristan
Re: Lookup Table
Post by Tristan »
Thanks Master :D !
Re: Lookup Table
I am not Master, I am a learner :)
I call only one person, "Master" :D
miras
Re: Lookup Table
Post by miras »
Hi Tristan and all!
I think the code of Sudip fine and good thinking.
This is the my example when you look directly at the table for some field with F2 or directly type in field nid. You also can add a new record in TEST table and the new added to the field.
I hope this example will help You.
Otherwise, I use HMG and minigui ext. about 3 years and I am very pleased with what they can.
Miras
TESTLUP.rar
(5.61 KiB) Downloaded 458 times
Re: Lookup Table
Hello Miras,
Thanks a lot for sharing this excellent code. I am using Minigui (both Official and Ext) less than 1 year ;)
I am really excited about it's power and simplicity :)
IMHO, your code is for HMG Extended (checking compile.bat file). It runs fine with Minigui Extended.
Then I modified compile.bat file for HMG Official and it compiled and ran :), but I found problem when I pressed F2 :(
Date:10.11.09 Time: 19:43:24
Error: Harbour MiniGUI 2.9.5 (2009.10.09)
Control: BroTESt Of FrmTest Not defined. Program Terminated
Called from SETPROPERTY(6373)
Called from NFINDCODE(437)
Called from (b)DATATABLE(174)
Called from _DOCONTROLEVENTPROCEDURE(4740)
Called from EVENTS(1399)
Called from SETWINDOWTEXT(0)
Called from _DEFINEMASKEDTEXTBOX(391)
Called from DATATABLE(174)
Called from OPENTEST(463)
Called from (b)EXAMPLE(87)
Called from EVENTS(553)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4428)
Called from EXAMPLE(103)
Called from (b)MAIN(45)
Called from EVENTS(1319)
Called from _ACTIVATEWINDOW(4382)
Called from MAIN(59)
Tristan
Re: Lookup Table
Post by Tristan »
Hi Miras,
Thanks for example.
Tristan
Tristan
Re: Lookup Table
Post by Tristan »
Where I can find accounting or inventory application that build with HMG ?
Thanks,
Tristan
Re: Lookup Table
sudip wrote:...
Hello Sudip,
You are right :!:
You should update the code for using this sample with the HMG Official :arrow:
PROCEDURE DataTable()
Public lAddrow      := .F.
Public lInit := .F.                   // <-- added here
If .Not. IsWIndowActive ( FrmTest )
    DEFINE WINDOW FrmTest ;
		WIDTH 700 HEIGHT 650 ;
		TITLE 'Test table' ;
		ICON 'kotac' ;
		CHILD NOSIZE NOMAXIMIZE ;
		ON INIT {|| lInit := .T. } ;           // <-- added here
		ON RELEASE {|| lInit := .F. }       // <-- added here
     @ 1,100 TEXTBOX TBoxFind VALUE 1 HEIGHT 23 WIDTH 100 NUMERIC INPUTMASK '9999999999' RIGHTALIGN;
			      ON CHANGE iif(lInit, nFindCode(), ) ;           // <-- added here
		   	    ON ENTER { || FrmTest.Brotest.SetFocus }
I hope that helps :idea:
Re: Lookup Table
Hello Grigory,
Thanks a lot for your prompt help :)
But again I got some errors when pressing F2
Date:10.11.09 Time: 20:40:02
Called from NFINDCODE(439)
Called from (b)DATATABLE(175)
Called from DATATABLE(175)
Called from OPENTEST(465)
Re: Lookup Table
sudip wrote:Hello Grigory,
Sudip,
Ok. Please replace the all PROCEDURE DataTable with code below:
Public lInit := .F.
		ICON 'kotac' ;
    DEFINE LABEL Label_Trazi
            ROW    1
            COL    20
            WIDTH  45
            HEIGHT 20
            VALUE " Find: "
            FONTNAME "Arial"
            FONTSIZE 9
            TOOLTIP ""
            FONTBOLD .T.
            FONTITALIC .F.
            FONTUNDERLINE .F.
            FONTSTRIKEOUT .F.
            HELPID NIL
            VISIBLE .T.
            TRANSPARENT .F.
            ACTION NIL
            AUTOSIZE  .F.
            BACKCOLOR NIL
            FONTCOLOR NIL
            CENTERALIGN .T.
     END LABEL
			      ON CHANGE iif(lInit,nFindCode(), ) ;
  DEFINE TAB Tab_1 AT 30,10 WIDTH 660 HEIGHT 550 VALUE 1 FONT "Arial" SIZE 9 ;
              TOOLTIP "Test table" ON CHANGE NIL FLAT
    PAGE "Table browse"
        @ 30,10 BROWSE BroTest									;
         			WIDTH 630  										;
			        HEIGHT 500 										;
			        HEADERS { 'Code','First name', 'Last name', 'Birth date', 'MarRied','BIO'} ;
			        WIDTHS { 90,150,150,100,150 } ;
			        WORKAREA Test ;
			        FIELDS { 'Test->CODE','Test->FIRST','Test->LAST','Test->BIRTH','Test->MARRIED','Test->MARRIED'} ;
			        JUSTIFY { BROWSE_JTFY_RIGHT, BROWSE_JTFY_RIGHT, BROWSE_JTFY_RIGHT ,BROWSE_JTFY_LEFT, BROWSE_JTFY_LEFT, BROWSE_JTFY_LEFT} ;
			        ON CHANGE { || Load_Row() } ;
			        ON DBLCLICK {|| IIF(CallTest = " ", CallTest := " ",FrmTest.RELEASE), ReturnData() }  ;
              ON GOTFOCUS {|| OpenSELT(1) }
    END PAGE
    PAGE "Data for view and correction"
            DEFINE FRAME Frame_1
                ROW    040
                COL    10
                WIDTH  610
                HEIGHT 400
                FONTNAME "ARIAL"
                FONTSIZE 9
                FONTBOLD .F.
                FONTITALIC .F.
                FONTUNDERLINE .F.
                FONTSTRIKEOUT .F.
                CAPTION "Data table"
                BACKCOLOR NIL
                FONTCOLOR NIL
//                TRANSPARENT  .T.
            END FRAME
            @ 060,020 LABEL Lid VALUE "Code:" WIDTH 95 HEIGHT 23 FONT "ARIAL" SIZE 09
		        @ 060,120 TEXTBOX nCode HEIGHT 23 WIDTH 100 NUMERIC INPUTMASK '9999999999' RIGHTALIGN ;
                     ON ENTER {|| FrmTest.cFirst.SetFocus }
            @ 090,020 LABEL lfrlas VALUE "First name                   Last name" WIDTH 390 HEIGHT 25 FONT "ARIAL" SIZE 09
            @ 120,020 TEXTBOX cFirst WIDTH 150 HEIGHT 23 MAXLENGTH 30 VALUE ""  FONT "ARIAL" SIZE 09  ;
                           ON ENTER {|| FrmTest.cLast.SetFocus}
            @ 120,200 TEXTBOX cLast WIDTH 150 HEIGHT 23 MAXLENGTH 30 VALUE "" FONT 'Arial' SIZE 10 ;
                              ON ENTER {|| FrmTest.dBirth.SetFocus}
            @ 150,020 LABEL Ldb VALUE "Birth:" WIDTH 95 HEIGHT 23 FONT "ARIAL" SIZE 09
			      @ 150,120 TEXTBOX dBirth HEIGHT 23 WIDTH 80 DATE  ;
			                        ON ENTER FrmTest.lMar.SetFocus
            @ 180,020 CHECKBOX lMar CAPTION 'Married' ;
                      width 120 value .f. ;
                      ON CHANGE {|| nil  } ;
                       ON LOSTFOCUS {||  FrmTest.eBio.SetFocus }
            @ 210,020 EDITBOX eBio ;
			                      WIDTH 550 ;
		                      	HEIGHT 130
				@ 470,020 BUTTON SaveTest CAPTION "&Save" WIDTH 90 HEIGHT 25 ACTION  {|| SaveTest() }
        @ 470,480 BUTTON CancelTest CAPTION "&Cancel" WIDTH 90 HEIGHT 25 ACTION  {|| CancelTest() }
    END PAGE
  END TAB
  @ 001,400 BUTTON NewTest CAPTION "&Add" WIDTH 90 HEIGHT 25 ACTION  {|| AddTest() }
  @ 001,490 BUTTON CorTest CAPTION "&Edit" WIDTH 90 HEIGHT 25 ACTION  {|| EditTest() }
  @ 001,580 BUTTON EraTest CAPTION "&Delete" WIDTH 90 HEIGHT 25 ACTION  {|| EraseTest() }
    WhatButton()
    FrmTest.TBoxFind.SetFocus
  CENTER WINDOW FrmTest
   LoadTest()
   DisabTestField()
 	ACTIVATE WINDOW FrmTest
    FrmTest.SetFocus
and try again... :arrow:
Re: Lookup Table
Hello Grigory,
Thanks a lot. It runs fine with HMG :)
Again, as a learner of both versions I want to know what's the difference between previous and current code :)
Thanks in advance :)
