HMG 3.0.0 + IDE + HFCL (Forum Test VIII)
Re: HMG 3.0.0 + IDE + HFCL (Forum Test VIII)
Thanks Roberto. It is running fine. :)
rathinagiri wrote:Thanks Roberto. It is running fine. :)
Thanks for testing! :)
I found a bug in IDE 3 test 8
It doesn't recompile changed forms! Only changing prg files causes recompilation of project!!!
Even reset incremental data doesn't cause including changes in forms (e.g. new buttons)
Please, check it.
Best regards, Marek
Hi Maestro
Thanks a lot for this new release :)
I'll test it and will report the results.
Best regards
Hello Master Roberto,
Thanks a lot for this new release (3-in-1) :D
I shall report after testing.
Hello Sudip!
Try to add BUTTON in any window via IDE and compile project.
Check if it appears.
Marek
Vanguarda
Post by Vanguarda »
Roberto Lopez wrote: Please, test:
ide_30_test_08_vanguarda_bug.rar
It has debugger support too.
Thanks Master, i´m testing it now. Sorry my delay for response.
mol wrote:Hello Sudip!
Marek
Hello Marek,
Yes, I confirm this problem. The button appears in form only after Resetting Project Incremental Data.
Other than this small problem, it runs fine. I also feel slight improvement of speed of generated .exe file :)
Vanguarda
Post by Vanguarda »
It work fine. The problem is solved.
My best regards,
PS: I´m still testing...
