HMG 3.0 (Test I)
Re: HMG 3.0 (Test I)
I've found problems in 'compile.bat' when you try to use parameters different than -c or -d.
I'm working on it to post a patch.
Hello Master Roberto,
I am not sure where I did mistake, but I got compilation error.
IDE is also not working (compilation). May be you will correct it later. And I only want to inform you about my test.
I had compiled the main.demo successfully using the compile.bat provided.
Rathi, I guess I have done some mistakes :(
I uninstalled version 2.9.5. Deleted C:\HMG folder. Then installed HMG 3.0.0.
Then I restarted computer. Went to command prompt. CD C:\Samples\Main.Demo folder. Then typed COMPILE DEMO.
There must be something which I missed ;)
Please help me if you find any mistake in my steps.
Thanks in advance.
sudip wrote: IDE is also not working (compilation). May be you will correct it later. And I only want to inform you about my test.
I've included in changelog, a note indicating incompatibility with IDE:
- Updated: Harbour compiler to 2.0 Beta 3 (HMG IDE 2.9.4 and earlier
versions ARE NOT COMPATIBLE with this HMG version).
Maindemo should work fine.
Please note that compile.bat syntax has changed. Please, read the changelog.
Anyway, please, wait until I post the patch.
Thank you Master :)
sudip wrote:...
Hello Sudip,
You have a path to BCC in your environment.
Please be so kind to update your local hmg\batch\compile.bat as below:
@echo off
rem ***************************************************************************
rem HMG 3.0 Compile batch.
rem Roberto Lopez (2009.10.10)
cls
set path=C:\hmg\HARBOUR\comp\MINGW\bin;%path%
rem set default resources
I hope that helps :idea:
I have some bad news...
In incremental mode, HBMK, successfully, detect changes in include files invoked from .prgs and then, when an include file is modified, prgs that invokes it, are automatically recompiled.
The LOAD WINDOW HMG command, generates an #include directive for adding .fmg form files to a .prg.
So, the command:
LOAD WINDOW Test
Will generate the following code:
#include <Test.fmg>
Sadly, since #include directive is not explicity wrote in the .prg, apparently HBMK2 is ignoring it, so, changes in .fmg files will not force recompilation of calling prg(s).
The bottom line is that I'll must remove 'incremental' feature from 'Compile.Bat' since it will not work with form files (nor reports).
Any idea to overcome this is welcome.
Hello Grigory,
gfilatov wrote:...
@echo off
Thanks a lot. :D My problem was solved.
