MySql and AdoDb experience
l3whmg
Re: MySql and AdoDb experience
Post by l3whmg »
Hello everyone,
I understand your point of view on ODBC, which is a little more complicated (library, installing drivers) :geek: .
I really liked the "simplicity" :mrgreen: of the syntax of the instructions that I could use, especially when I had to refer to individual fields or set up a SQL string and so on.
I believe that the library hbmysql creates fewer problems (I think using socket connection for access :roll: ), but I did not make significant evidence: I'll try!
About date fields (but the same for other fields) the problem is: can the language/compiler use them? I am limited to dates in the standard format (like dd-mm-yyyy) appropriately managed by clipper; as mentioned by Roberto, I've used a version of WAMP (http://www.appservnetwork.com). I'll try XAMPP (http://www.apachefriends.org)
Thank (many thanks) you for your attention shown to my little job.
Luigi from Italy
www.L3W.it
I've tried MySQL and hbmysql for one reason - record locking future built in MySQL.
But, in my opinion, it doesn't work.
I'll try to reach record locking effect with ODBC.
I'll write about my results.
Marek
mol wrote:I've tried MySQL and hbmysql for one reason - record locking future built in MySQL.
Marek
Please, read this thread:
http://www.webmaster-talk.com/the-datab ... cking.html
At the end there is a very interesting sample that could be useful for you.
Marek
There is another interesting thread:
http://www.foxite.com/archives/lock-rec ... 045174.htm
l3whmg
Post by l3whmg »
Ciao Marek,
I hope to indicate a right way. I remember having found these instructions:
- You must properly configure MySql, because it has the automatism that may affect or alter the use of Lock and Unlock even at the row level.
- It is better to use InnoDB because (it seems) is the only way (like Clipper) to perform the row-level locking.
- Best to approach the SQL string.
- Successfully set a parameter, when accessing to the database, which responds to precise rules (if you've noticed, in my library was provided a numeric parameter).
All these informations I found browsing Internet and the site http://dev.mysql.com/ :roll:
I'm sorry, but my experiences on a row-level locking were unlucky :oops:
I hope to have you provided useful informations and not misleading.
Best regards
Luigi from Italy
www.L3W.it
I'll back to test MySQL when I find a little free time.
Thanks for suggestions.
