Re: edk - Help required for downloading
Posted: Fri Oct 09, 2026 2:45 pm
Hi Daniel
Thanks for elaborate programs on using curl.exe.
I find build.bat /n bse_curl.prg runs but build64.bat /n bse_curl.prg produces following error.log. Can you pls point the mistake I am committing
Thanks
Harbour 3.2.0dev (r1604201603)
Copyright (c) 1999-2016, https://harbour-project.org/
D:/HMG-SAMPLES/hmgforum/BseIndia API/_temp.o: file not recognized: file format not recognized
i686-w64-mingw32-gcc.exe C:/Users/rpcch/AppData/Local/Temp/hbmk_j1jp8v.dir/bse_curl.o C:/Users/rpcch/AppData/Local/Temp/hbmk_j1jp8v.dir/hbmk_znpgm8.o "D:/HMG-SAMPLES/hmgforum/BseIndia API/_temp.o" -pthread -static-libgcc -static-libstdc++ -static -lpthread -mwindows -Wl,--start-group -l"hmg-64" -l"crypt-64" -l"edit-64" -l"editex-64" -l"graph-64" -l"ini-64" -l"report-64" -l"hfcl-64" -lmsvfw32 -lvfw32 -l"hbvpdf-64" -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -obse_curl.exe -L"c:/HMG.3.5/harbour-64/lib/win/mingw64"
Thanks
