Workspace - development environment
Re: Workspace - development environment
Hola : como les dije que a veces me gusta programar en Pascal pude intergar el compilador FPC dentro de Workspace.
la forma era desacoplar los compiladores dentro de Workspace y creando archivos .hrb
An HRB file (.hrb) is a Harbour Portable Binary file. It contains precompiled portable p-code and symbol tables generated by the Harbour Compiler. Think of it as a compiled script or modular component that runs across different operating systems without OS-specific binary code.
Key CharacteristicsPortable Binary: Contains intermediate byte-code (p-code) rather than native machine code.Modular Updates: Allows developers to ship single updated program routines rather than recompiling and sending a full monolithic executable.
Dynamic Execution: Can be loaded, executed, or queried at runtime using Harbour's interpreter tools.
How to Use HRB Files
Creation: Compile a source file into an HRB binary via the command line using hbmk2 -gh file.prg or harbour file.prg /gh.
Execution: Run the portable binary directly using the Harbour runner tool via hbrun file.hrb.
Integration: Main programs can load .hrb files dynamically during execution to call isolated functions or modules.
https://github.com/harbour/core/blob/ma ... bmk2.en.md
https://www.hmgforum.com/viewtopic.php?t=5233 por Luis Vasquez
Plugins :
Captura de pantalla 2026-08-13 234814.png (95.51 KiB) Viewed 475 times
Captura de pantalla 2026-08-13 234848.png (43.2 KiB) Viewed 475 times
Hola a todos: los invito a mi grupo Workspace:https://t.me/HMGWorkspace
en nuevo entorno de desarrollo esta casi funcional y necesito que prueben con sus ejemplos, se recomienda crear una carpeta EJ: C:\Projects
probar ahi las aperturas de xxx.hbp
pueden compilar , hacer debug de sus proyectos, sean en modo GUI o harbour puro.
In the new development environment, it's almost functional, and I need you to test it with your examples. It's recommended to create a folder, e.g., C:\Projects, and test opening xxx.hbp there.
You can compile and debug your projects, whether in GUI mode or pure harbor mode.
estaré respondiendo dudas en el grupo // I will be answering questions in the group.
Captura de pantalla 2026-08-15 124018.png (161.26 KiB) Viewed 343 times
Captura de pantalla 2026-08-15 124639.png (137.46 KiB) Viewed 343 times
Captura de pantalla 2026-08-15 125414.png (146.55 KiB) Viewed 343 times
Hola a Todos:
casi terminado Workspace y FormEditorService que incluye edición de formulario dentro de un ViewPort que permite como ejemplo mi Aplicación para cámaras IP que tiene una resolución de 1200x 1024, al tener mucha resolucion en canvas de Main.fmg este se puede desplazar con las barras de posición.
Hello everyone: I've almost finished Workspace and FormEditorService, which includes form editing within a ViewPort. For example, my IP camera application has a resolution of 1200x1024, and because of the high resolution of the Main.fmg canvas, it can be scrolled using the position bars.
dejo capturas y como siempre los espero en el canl de Telegram ahi tienen a disposicion Workspace
t.me/HMGWorkspace
Exist With Save.png (98.88 KiB) Viewed 240 times
Thx Daniel !
Enlace de invitacion : https://t.me/HMGWorkspace
Captura de pantalla 2026-08-28 161323.png (79.42 KiB) Viewed 227 times
Hola a todos:
como siempre los invito a probar Workspace en mi canal esta la descarga del mismo : https://t.me/HMGWorkspace
ahora estoy integrando la posibilidad de revisar .exe, .dll, .a, .lib
generar el .def para generar un .a desde un .dll o .lib
Captura de pantalla 2026-09-01 181022.png (81.6 KiB) Viewed 171 times
Hola a todos: casi terminado DependencyService:
la finalidad de este servicio es revisar funciones exportadas.
yo me siento mas comodo trabajar con una libreria estatica .a que un dll, a veces hay .lib que tambien puede ser covertidas en libreria estatica .a
ya no hay necesidad de utilizar e instalar herramientas de terceros .
mi proximo paso es hacer es agregar report a DependencyService que indique como lo hace un getor de paquetes de Linux (Aptget) la falta de dependencias de un binario
DependencyService report
Runtime dependency group: VLC
Status: incomplete
Found:
  libvlc.dll
Missing:
  libvlccore.dll
  plugins\
Suggestion:
  Copy libvlccore.dll next to the executable.
  Copy the VLC plugins folder next to the executable.
  Verify that all files are 64-bit.
DependencyService :
Captura de pantalla 2026-09-01 225144.png (102.67 KiB) Viewed 165 times
Se me hace mas practico trabajar con una libreria estatica .a que con una DLL ya que tuve mucho que luchar con Hasar 715p
pase de esto:
Function AbrirPuerto( lRetorno )
nHandler := CallDll32( "OpenComFiscal" , "WINFIS32.DLL" , 1 , 0 )
    If nHandler >= 0
       Principal.StatusBar.Item(2) :="Puerto de impresora OK "
       nError := CallDll32( "InitFiscal"    , "WINFIS32.DLL" , nHandler )
       If nError = 0
         lRetorno :=  .T.
       Else
         alerror( nError )
         Principal.StatusBar.Item(2) := " La impresora no se puede Inicializar"
          lRetorno := .T.
       Endif
   Else
    alerror( nHandler )
    Principal.StatusBar.Item(2) :=" Hubo un error de abrir puerto Comm "
    lRetorno := .T.
   Endif
Return ( lRetorno )
a esto :
   nHandler := OpenComFiscal( 1, 0 )
   If nHandler >= 0
      Principal.StatusBar.Item(2) := "Puerto de impresora OK "
      nError := InitFiscal( nHandler )
      If nError = 0
         lRetorno := .T.
      Else
         alerror( nError )
         lRetorno := .T.
      Endif
   Else
      alerror( nHandler )
      Principal.StatusBar.Item(2) := " Hubo un error de abrir puerto Comm "
      lRetorno := .T.
   Endif
Return ( lRetorno )
