Page 2 of 2
Re: Timeout to close App
Posted: Fri Aug 09, 2024 7:50 am
by edk
Is that your goal?:
#include "i_MsgBox.ch"
FUNCTION Main
Local nIdleTimeToClose := 10
define window sample at 0,0 width 640 height 480 ;
   title "System Idle Time " + StrZero ( SysIdleSecs(), 4 )
  @12, 10 LABEL Label_1 VALUE "Text_1" width 80 RIGHTALIGN
  @10, 95 TEXTBOX Text_1 ;
    VALUE 10 ;
    NUMERIC
  @42, 10 LABEL Label_2 VALUE "Text_2" width 80 RIGHTALIGN
  @40, 95 TEXTBOX Text_2 ;
    VALUE 20 ;
    NUMERIC
  @72, 10 LABEL Label_3 VALUE "Text_3" width 80 RIGHTALIGN
  @70, 95 TEXTBOX Text_3 ;
    VALUE 30 ;
    NUMERIC
  DEFINE TIMER IdleTimeOut INTERVAL 1000 ACTION CheckIdleTimeout( nIdleTimeToClose )
end window
sample.Text_1.setfocus
center window sample
activate window sample
RETURN Nil
Procedure CheckIdleTimeout( nIdleTimeOut )
Local nSysIdleTime
Static nIdleTimeOutLevel := 0
Static nNextIdleTimeOut  := 0
This.Enabled := .F.     //disable timer
nSysIdleTime := SysIdleSecs()
IF nSysIdleTime < nIdleTimeOut .AND. ( nIdleTimeOutLevel <> 0 .OR. nNextIdleTimeOut = 0 )	//System idle time is less than timeout, it is level 0
     IF nIdleTimeOutLevel > 0
          This.Value := 1000   //set the timer back to 1 second
          ScreenSaver( /* cInfo */ , .T. /* lRelease */ )
     nNextIdleTimeOut := nIdleTimeOut
IF nSysIdleTime >= nNextIdleTimeOut   //System idle time has reached timeout, level up, increasing the timeout idle time to the next level.
     nIdleTimeOutLevel ++
     nNextIdleTimeOut := nSysIdleTime + 60     //nSysIdleTime + nIdleTimeOut
DO CASE
     CASE nIdleTimeOutLevel = 2
         MessageBoxTimeout ( "The system idle timeout level " + StrZero ( nIdleTimeOutLevel, 1 )  + " has been reached, the application will be closed in 5 seconds.", "Idle state", MB_ICONWARNING + MB_TOPMOST, 5 * 1000 )
         ReleaseAllWindows()
     CASE nIdleTimeOutLevel = 1
         This.Value := 50     //set the timer to 50 milliseconds, refresh screen saver faster.
         ScreenSaver( "System idle timeout reached. The app will close in " +  StrZero ( nNextIdleTimeOut - nSysIdleTime, 2 ) + " sec." )
ENDCASE
ThisWindow.Title := "System Idle Time " + StrZero ( nSysIdleTime, 4 )
This.Enabled := .T.   //enable timer
RETURN Nil
Procedure ScreenSaver( cInfo, lRelease )
Local nColLabel := GetDesktopWidth() / 2
Local nRowLabel := GetDesktopHeight() / 2
Local nFontHeight := 28
Static nDirectionX := 0
Static nDirectionY := 0
Default lRelease := .F.
Default cInfo := "Screen Saver"
IF .Not. IsWindowActive ( _ScreenSaver_ ) .AND. .Not. lRelease
     DEFINE WINDOW _ScreenSaver_ AT 0, 0 WIDTH GetDesktopWidth() HEIGHT GetDesktopHeight() ;
            TOPMOST NOMINIMIZE NOMAXIMIZE NOSIZE NOSYSMENU NOCAPTION ;
            BACKCOLOR BLACK
     @nRowLabel, nColLabel LABEL Label_1 OF _ScreenSaver_  VALUE cInfo AUTOSIZE ;
                        FONT "Arial Rounded MT" SIZE nFontHeight BOLD ;
                        FONTCOLOR WHITE TRANSPARENT
     //Center Label
     _ScreenSaver_.Label_1.Col := _ScreenSaver_.Label_1.Col - ( _ScreenSaver_.Label_1.Width / 2 )
     nDirectionX := hb_RandomInt ( 0, 2 )
     nDirectionY := hb_RandomInt ( 0, 2 )
     IF nDirectionX = 2
          nDirectionX := -1
     IF nDirectionY = 2
          nDirectionY := -1
     ACTIVATE WINDOW _ScreenSaver_
     IF lRelease
          _ScreenSaver_.Release
          _ScreenSaver_.Label_1.Value     := cInfo
          _ScreenSaver_.Label_1.Col       := _ScreenSaver_.Label_1.Col + ( nDirectionX * 3 )
          _ScreenSaver_.Label_1.Row       := _ScreenSaver_.Label_1.Row + ( nDirectionY * 3 )
          _ScreenSaver_.Label_1.FontColor := { hb_RandomInt ( 0, 255 ), hb_RandomInt ( 0, 255 ), hb_RandomInt ( 0, 255 ) }
          IF _ScreenSaver_.Label_1.Col <= 0 .OR. ( _ScreenSaver_.Label_1.Col + _ScreenSaver_.Label_1.Width ) >= _ScreenSaver_.Width
               nDirectionX := nDirectionX * ( -1 )          //bounce
          IF _ScreenSaver_.Label_1.Row <= 0 .OR. ( _ScreenSaver_.Label_1.Row + nFontHeight + IF( nFontHeight < 12, 12, 16 )  ) >= _ScreenSaver_.Height
               nDirectionY := nDirectionY * ( -1 )          //bounce
RETURN Nil
#pragma BEGINDUMP
#include "windows.h"
#include "time.h"
#include "hbapi.h"
HB_FUNC( SYSIDLESECS )
 LASTINPUTINFO lpi;
 lpi.cbSize = sizeof (LASTINPUTINFO);
 GetLastInputInfo (&lpi);
 hb_retnd( ( DOUBLE ) ( GetTickCount() - lpi.dwTime ) / CLOCKS_PER_SEC );
#pragma ENDDUMP
Posted: Fri Aug 09, 2024 9:47 am
by AUGE_OHR
hi Edward,
edk wrote: Fri Aug 09, 2024 7:50 am Is that your goal?:
YES, THX
now it is working like i want, but i do´nt understand how ?
at Level 0 it Count UP as expect
at Level 1 it Count DOWN, but i see no SUBTRACT in Code :shock:
Posted: Fri Aug 09, 2024 10:15 am
by edk
There is no level subtraction because when the system is no longer idle it returns to level 0. :mrgreen:
Level 0: Idle timeout not exceeded.
Level 1: first idle threshold exceeded, execute screen saver, if during level 1 the system is no longer idle, reverts to level 0.
Level 2: second final idle threshold exceeded, terminate application.
Posted: Wed Dec 03, 2025 6:06 pm
by mol
I can't find how to set new value to interval?
I'm tring
form_1.Interval_1.Value := 18000
but it causes Error: Interval_1 od form_1 not defined
What's going on?
