LibXL and harbour
Red2
Re: LibXL and harbour
Post by Red2 »
Hi Maren,
Thank you for your prompt response.
Very sorry about your computer.
In the next day or two I will take a deeper look at XLSXClass.ZIP.
Again, thank you for all your kind help!
I'm attaching my small class for reading xlsx files directly (without using OLE, libraries, etc.) along with an example of its use.
Once I needed to read large xlsx files (over 200k rows) and all xml-parser solutions I knew were too slow. So I decided to delve into the structure of xlsx files and built a class that does not create temporary files and loads data into memory and uses tokens for xml analysis.
The class is small and consists of the following methods:
oXLSX := SmallXLSXReader():Open( cXlsxFileOpen [, bBlockUnZip, bBlockParser, lAttributes ] )
Opens xlsx file, parameters are given: file name with path, optional code block executed during xml component unpacking, optional code block executed during xml data processing, optional logical parameter specifying whether attributes*) should be included in the returned data also.
*) attributes are a hash table with keys:
"col" - cell address,
"style" - style used in the cell,
"DateTime" - whether the data is date and time,
"type" - data type,
"value" - value in the cell (entered or calculated according to a formula),
"formula" - used formula
aSheetList := oXLSX:WorkSheetList()
Returns an array of sheet names in the workbook.
aSheetData := oXLSX:WorkSheet( cSheetName [, bBlockUnZip, bBlockParser ] )
Reads data from the sheet and returns it as an array
oXLSX:Close()
Releases variables stored in the class.
The class was written for my needs and I reserve that there is no guarantee that it will work with all xlsx workbooks, but maybe it will be useful to someone.
XLSX_Reader.7z
(6.29 KiB) Downloaded 528 times
edk wrote: Thu May 18, 2023 11:54 am I'm attaching my small class for reading xlsx files directly (without using OLE, libraries, etc.) along with an example of its use.
Hi Edward,
Thanks a lot for your valuable contribution :!:
The sample code is very useful. 8-)
I've attached the updated code without Harbour and C compiler warnings for your reference. :arrow:
ReadXLSX.zip
updated source
(6.98 KiB) Downloaded 542 times
Amazing! Thanks a lot!
gfilatov wrote: Thu May 18, 2023 2:47 pm I've attached the updated code without Harbour and C compiler warnings for your reference. :arrow:
Thanks Grigory.
You used the ColumnsAutoFit() method in your version, which does not exist in the official HMG, so I took the liberty of adopting them from your Harbour MiniGUI Extended.
I think now it should work in both HMG and MiniGUI Extended :? .
In addition, in the class itself, I improved the recognition of the cell value type and formatting style as Date/Time/DateTime.
XLSX_Reader_v0.2.7z
(6.82 KiB) Downloaded 540 times
Thanks !
nekbmm
DBs Used: DBF,SQLite
Post by nekbmm »
Everything is fine in my examples.
NEX.
Georg_BA
Post by Georg_BA »
Hello everyone
I have an interesting problem with an xlsx file
there are 2 files in the attachment
file_1.xlsx original file from the supplier
the file does not contain the "dimension ref" section
the process terminates with an error
Date:2023.06.07 Time: 21:03:20
Error BASE/1133 Bound error: array assign
Called from (b)SMALLXLSXREADER_PARSER_SHEET(193)
Called from AEVAL(0)
Called from SMALLXLSXREADER:PARSER_SHEET(193)
Called from (b)SMALLXLSXREADER_WORKSHEET(162)
Called from SMALLXLSXREADER:WORKSHEET(162)
Called from LOADSHEET(101)
Called from READ_XLSX(84)
Called from (b)MAIN(21)
Called from EVENTS(1756)
Called from DOMESSAGELOOP(0)
Called from MAIN(38)
the file can be opened in any XLSX editor and I will save it under a different name File_2.xlsx everything will be fine
it is possible to modify the given class to load an xlsx file without a value "dimension ref"
thank you for your help
Regards, Georg
sample.zip
(12.97 KiB) Downloaded 406 times
This is the version of the class that reads your file:
SmallXLSXReaderClass.7z
(4.73 KiB) Downloaded 463 times
As I mentioned earlier, the SmallXLSXReaderClass project is based on tokenization, not xml parsing, and does not guarantee proper operation for all variants of the created xlsx file. Due to the fact that the xml structure in your file is correct in terms of content, but it is not the same as it is generated by MS Excel, that is why the tokenization is not entirely correct.
The class was created for my needs, so this is my final version. If something doesn't work, you can modify and improve the class, the code is open ;) = DIY
Georg_BA
Post by Georg_BA »
Hello
I thought it would be a job for you :mrgreen:
but now seriously, thank you very much for your help, your solutions are always interesting
tested, loads everything correctly
Best regards, Georg
