Latest HMG in 64 Bits
Red2
Re: Latest HMG in 64 Bits
I really hope that this initiative comes to fruition!
jorge.posadas
Estoy de acuerdo y ansioso de esa liberacion de 64b
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Programador independiente
Morelia, Mich.
M é x i c o .
Movil +52 44 3734 1858
SKYPE: jorge.posadasch
POSADAS SOFTWARE
Jorge Posadas Ch.
Morelia, Mich.
M é x i c o .
- miszler.zoltan
Hello Gentlemen!
Does anyone have a 64 bit solution for handling mysql with libmysql.dll. The translation has the following error message:
Harbor 3.2.0dev (r2304211101)
Copyright (c) 1999-2023, https://harbour.github.io/
C:/hmg.3.6/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.1.0/../../../../x86_64-w64-mingw32/bin/ld. exe: C:/Users/Zoli/AppData/Local/Temp/hbmk_x828sy.dir/sqlfunc.o:sqlfunc.c:(.data+0x90): undefined reference to `HB_FUN_TMYSQLSERVER'
hbmk2: Error: Referenced, missing, but unknown function(s): TMYSQLSERVER()
Thanks: Zoltán
Thanks: Zoltán
gisjr134
- DBs Used: DBF,MySQL,PostgreSQL
Hello EveryOne ,
You Will have to link HbMysql.Hbc into Your Project.
Build64 /n YourProject.Hbp YourProject.Hbc hbmySql.Hbc
hbmySql.Hbc l is located at the Folder \Harbour64\contrib\hbmysql.
gisjr134
Does Anyone know how To read or Get Resoources from a Dll File in Hmg ? Until now i only got the resource embebed in the Exe File.
Hello,
You cannot do it in HMG because there isn't the appropriate command SET RESOURCE TO <DLLname>.
Please try the attached demo app with use external resource DLL in your environment.
The full source code of this example is below:
* Copyright 2017 Grigory Filatov <gfilatov@inbox.ru>
* Copyright 2017 Verchenko Andrey <verchenkoag@gmail.com> Dmitrov, Moscow region
* Loading resources from mydemo.dll
ANNOUNCE RDDSYS
#include "minigui.ch"
Static nStaticNum := 0
Function MAIN
Local nI, nRow, nWidth, aIcoExit, aPrgBar, aRes, aBackColorAvi, aSWH
Local cPathMyDll := GetStartUpFolder() + "\mydemo.dll"
If !File( cPathMyDll )
MsgStop("There is no resource file for the program!" + CRLF + cPathMyDll )
Quit
Endif
aIcoExit := { "Exit48x1" , "Exit48x2" } // two icons for exit
// list of icons for snake
aPrgBar := {}
For nI := 1 TO 8
Aadd( aPrgBar, "ZMK" + strzero(nI,2) )
Next
SET RESOURCES TO ( cPathMyDll )
DEFINE WINDOW Form_1 ;
AT 0,0 WIDTH 700 HEIGHT 550 ;
TITLE "Displaying resources from the MyDemo.Dll" ;
ICON "1MAIN_ICO" ;
MAIN ;
FONT 'Tahoma' SIZE 14 ;
BACKCOLOR WHITE
nWidth := This.ClientWidth
@ 20, 0 LABEL Label_Vers VALUE MiniGUIVersion() WIDTH nWidth HEIGHT 42 ;
TRANSPARENT FONTCOLOR BLACK SIZE 12 BOLD CENTERALIGN
@ 45, 0 LABEL Label_Compil VALUE hb_compiler() WIDTH nWidth HEIGHT 42 ;
@ 70, 0 LABEL Label_Info VALUE Version() WIDTH nWidth HEIGHT 42 ;
DRAW ICON IN WINDOW Form_1 AT 5, 5 PICTURE "1MAIN_ICO" WIDTH 128 HEIGHT 128 TRANSPARENT
@ 12,Form_1.Width-122 IMAGE Image_1 PICTURE "LOGO128" WIDTH 96 HEIGHT 96 STRETCH
@ 128+5*2, 0 IMAGE Image_2 PICTURE "Harbour" WIDTH Form_1.Width HEIGHT 156 STRETCH
nRow := 128+5*2 + 156
@ nRow, 0 LABEL Label_Full VALUE '' WIDTH nWidth+10 HEIGHT 50
aSWH := GetAviResSize("ZIPAVI")
nCol := (nWidth-aSWH[1])/2
@ nRow,nCol ANIMATEBOX Avi_1 WIDTH aSWH[1] HEIGHT aSWH[2] File "ZIPAVI" AUTOPLAY TRANSPARENT NOBORDER
aBackColorAvi := nRGB2Arr( GetSysColor( 4 ) ) // 4-COLOR_MENU из i_winuser.ch
Form_1.Label_Full.BackColor := aBackColorAvi // fix the background like the system color
@ 390, 50 LABEL Label_AniIco VALUE 'Animation from Icons' Autosize FONTCOLOR MAROON TRANSPARENT
DRAW ICON IN WINDOW Form_1 AT 420, 100 PICTURE aPrgBar[1] WIDTH 64 HEIGHT 64 TRANSPARENT
@ 380, 270 BUTTONEX Button_Dbf CAPTION "Run DBF" + CRLF + "from Resource" ;
ICON "DBase48" WIDTH 120 HEIGHT 124 ;
NOXPSTYLE HANDCURSOR NOTABSTOP VERTICAL ;
FONTCOLOR WHITE BACKCOLOR SILVER SIZE 10 BOLD ;
ACTION {|| RunDBF() }
@ 380, 410 BUTTONEX Button_Play CAPTION "Play Wave" + CRLF + "from Resource" ;
PICTURE "Sound48" WIDTH 120 HEIGHT 124 ;
ACTION {|| PlayWave("QUARTER",.T.,.F.,.F.,.F.,.F.) }
@ 380 , 550 BUTTONEX Button_Exit WIDTH 120 HEIGHT 124 ;
CAPTION "Exiting" + CRLF + "the program" ICON aIcoExit[1] ;
FONTCOLOR WHITE BACKCOLOR MAROON SIZE 10 BOLD ;
ON MOUSEHOVER ( SetProperty(ThisWindow.Name, This.Name, "ICON", aIcoExit[2] ) ,;
SetProperty(ThisWindow.Name, This.Name, "fontcolor", BLACK ) ) ;
ON MOUSELEAVE ( SetProperty(ThisWindow.Name, This.Name, "ICON", aIcoExit[1] ) ,;
SetProperty(ThisWindow.Name, This.Name, "fontcolor", WHITE ) ) ;
ACTION {|| ThisWindow.Release }
DEFINE TIMER Timer_1 INTERVAL 100 ACTION MyAnimationIcons(420, 100, aPrgBar,64)
Form_1.Sizable := .F. // NOSIZE
Form_1.MaxButton := .F. // NOMAXIMIZE
Form_1.Center
Form_1.Activate
Static Function MyAnimationIcons(nRow, nCol, aPrgBar, nWH)
nStaticNum++
nStaticNum := IIF( nStaticNum > LEN(aPrgBar), 1, nStaticNum )
DRAW ICON IN WINDOW Form_1 AT nRow, nCol PICTURE aPrgBar[nStaticNum] WIDTH nWH HEIGHT nWH TRANSPARENT
Function RunDBF()
Local cPath := GetStartupFolder() + "\"
Local cFile := "test.dbf"
IF RCDataToFile( "test_dbf", cPath + cFile, "CUSTOM" ) > 0
// run the file from the disk
ShellExecute( 0, "open", "test.dbf", cPath, , 1 )
- MyDemo.zip
- Demo application
- (991.58 KiB) Downloaded 399 times
