FROM XML TO DBF
tomtagaris
Re: FROM XML TO DBF
Post by tomtagaris »
Τhank you all for your help
Thanasis
Re: FROM XML TO DBF
I really prefer files in DBF or simple flatfiles.... XML and JSON are not for humans?
tomtagaris
Re: FROM XML TO DBF
I finally followed the solution of EDK who I thank from the bottom of my heart for the help he has offered me. And I would like ask for a problem I am encountering in the transfer to dbf of the date from an hml file because it is in yyyy-mm-dd format I convert it with SUBSTR() in ctod( dd/mm/yyyy) format but some dates are not transferred βut is empty (//) like this
can someone help me
thanks
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: FROM XML TO DBF
Post by dragancesu »
Re: FROM XML TO DBF
tomtagaris wrote: Mon Jan 23, 2023 8:55 am And I would like ask for a problem I am encountering in the transfer to dbf of the date from an hml file because it is in yyyy-mm-dd format I convert it with SUBSTR() in ctod( dd/mm/yyyy) format but some dates are not transferred βut is empty (//) like this
can someone help me
thanks
The easiest way is to use the function hb_CtoD(<cDate> [, <cDateFormat>]) -> dDate, for example:
REPLACE issueDate WITH hb_CtoD( cXmlIssueDate, "YYYY-MM-DD" )
@dragancesu
The function will convert a string to a date variable. So it doesn't matter what date display format you have set.
tomtagaris
Re: FROM XML TO DBF
Thanks very much
tomtagaris
Re: FROM XML TO DBF
one more question
how to export if there are many lines
<invoiceDetails>
<lineNumber>1</lineNumber>
<quantity>15</quantity>
<measurementUnit>1</measurementUnit>
<netValue>48.45</netValue>
<vatCategory>1</vatCategory>
<vatAmount>11.63</vatAmount>
</invoiceDetails>
<invoiceDetails>
<lineNumber>2</lineNumber>
<quantity>2</quantity>
<netValue>25.74</netValue>
<vatAmount>6.18</vatAmount>
</invoiceDetails>
<invoiceDetails>
<lineNumber>3</lineNumber>
<quantity>30</quantity>
<netValue>25.5</netValue>
<vatAmount>6.12</vatAmount>
</invoiceDetails>
<invoiceDetails>
<lineNumber>4</lineNumber>
<netValue>30</netValue>
<vatAmount>7.2</vatAmount>
</invoiceDetails>
<invoiceDetails>
<lineNumber>5</lineNumber>
<quantity>3</quantity>
<netValue>19.5</netValue>
<vatAmount>4.68</vatAmount>
</invoiceDetails>
<invoiceDetails>
<lineNumber>6</lineNumber>
<quantity>10</quantity>
<netValue>22</netValue>
<vatAmount>5.28</vatAmount>
Re: FROM XML TO DBF
Just:
	CASE cKey == "uid" .AND. cPath == "RequestedDoc/invoicesDoc/invoice"
		SELECT invoice
		APPEND BLANK
		REPLACE invoice->iud WITH xValue
	CASE cKey == "lineNumber" .AND. cPath == "RequestedDoc/invoicesDoc/invoice/invoiceDetails"
		SELECT invoiceDetails
		APPEND BLANK
		REPLACE invoiceDetails->uid WITH invoice->iud
		REPLACE invoiceDetails->LineNumber WITH xValue
tomtagaris
Re: FROM XML TO DBF
YES BUT WRITE ONLY ONE LINE BUT THE REST
tomtagaris
Re: FROM XML TO DBF
ΟΚ I WILL TRY IT
ΤΗΑΝΚΣ
