Hi Edward,
Thank you for your kind and quick response!
(My knowledge of C is, unfortunately, less than yours).
Perhaps this "corner" is not normally implemented in HMG.
My own Resize code accurately resizes the columns in GRIDs and BROWSEs.
To these windows I just want some way to include the "Resize Corner" graphic.
Is there is any other way this can be done in HMG?
¿Hay alguna otra forma en que esto se pueda hacer en HMG?
I would greatly appreciate anyone's suggestions or guidance here.
Thanks again,
Red2
Rezise window limit, how i do ?
- Claudio Ricardo
Re: Rezise window limit, how i do ?
Hi Red2, Maybe this...
At the end of the form
Add this control in the reposition function when resizing.
It won't actually do anything but warn the user that the window can be resized.
I didn't find .png icon but you can search the internet.
DEFINE IMAGE Image_Resize
ROW Main.ClientAreaHeight - 20
COL Main.ClientAreaWidth - 20
WIDTH 20
HEIGHT 20
ONCLICK Nil
PICTURE "Your_Transparent_.png_Icon"
STRETCH .T.
HELPID Nil
VISIBLE .T.
TRANSPARENT .T.
BACKGROUNDCOLOR {255,255,255} // <- Your back color
ADJUSTIMAGE .F.
TRANSPARENTCOLOR Nil
TOOLTIP "Resize"
END IMAGE
- Claudio Ricardo
Hi, I do this icon in transparent .png with Gimp white and black color 20x20 px.
- Grip20.zip
- (416 Bytes) Downloaded 102 times
- Grip20B.zip
- (426 Bytes) Downloaded 100 times
Or following Claudio's idea to use Label instead of Image:
FUNCTION Main()
Local nEvent, nMinHeight := 350, nMinWidth := 550, nMaxHeight := 400, nMaxWidth := 650
DEFINE WINDOW Test AT 157 , 162 WIDTH nMinWidth HEIGHT nMinHeight TITLE "Hello World!!!!!" MAIN BACKCOLOR {120,150,255} ON PAINT PaintSizeGrip( ThisWindow.Name ) ON RELEASE EventRemove ( nEvent )
DEFINE MAIN MENU
DEFINE POPUP "File"
MENUITEM "Some item" ACTION MsgInfo ( "Some item" )
SEPARATOR
MENUITEM "Exit" ACTION ThisWIndow.Release
END POPUP
END MENU
nEvent := EventCreate( { || SetMinMaxTrackSize( EventLPARAM(), nMinWidth, nMinHeight, nMaxWidth, nMaxHeight ) }, test.HANDLE, 36 /*WM_GETMINMAXINFO*/ )
// only min size defined
// nEvent := EventCreate( { || SetMinMaxTrackSize( EventLPARAM(), nMinWidth, nMinHeight ) }, test.HANDLE, 36 /*WM_GETMINMAXINFO*/ )
Center Window Test
Activate Window Test
#pragma BEGINDUMP
#include "windows.h"
#include "hbapi.h"
#include "hbapiitm.h"
#include "HMG_UNICODE.h"
#include <windowsx.h>
#include <commctrl.h>
#include <shlobj.h>
//SetMinMaxTrackSize(lParam, nMinX, nMinY, nMaxX, nMaxY)
HB_FUNC( SETMINMAXTRACKSIZE )
MINMAXINFO *MinMax = (MINMAXINFO *) HMG_parnl(1);
if (hb_parni(2) > 0)
MinMax->ptMinTrackSize.x = hb_parni(2);
if (hb_parni(3) > 0)
MinMax->ptMinTrackSize.y = hb_parni(3);
if (hb_parni(4) > 0)
MinMax->ptMaxTrackSize.x = hb_parni(4);
if (hb_parni(5) > 0)
MinMax->ptMaxTrackSize.y = hb_parni(5);
#pragma ENDDUMP
FUNCTION PaintSizeGrip( cWName )
Local nRow, nCol
IF !Empty ( cWName )
nRow := GetProperty ( cWName, "ClientAreaHeight" ) - 10
nCol := GetProperty ( cWName, "ClientAreaWidth" ) - 10
IF .Not. _IsControlDefined ( "SizeGrip", cWName )
@ nRow, nCol Label SizeGrip OF &cWName VALUE Chr ( 0x79 ) AUTOSIZE FONT "Wingdings 3" SIZE 10 TRANSPARENT
SetProperty ( cWName, "SizeGrip", "Row", nRow )
SetProperty ( cWName, "SizeGrip", "Col", nCol )
A small hint: ON PAINT can also be used instead of the ON SIZE eventClaudio Ricardo wrote: ↑Wed Mar 23, 2022 6:47 am Add this control in the reposition function when resizing.
Red2
Thank you Claudio and Edward,
Your kind guidance looks promising.
However, I have not been able to get Claudio's actual .PNG image, "SizeGrip",
to appear in the bottom right corner. Instead, just a black square displays.
Despite my attempts, the .PNG image is not being displayed.
My Question:
What am I doing wrong or missing?
I would appreciate any and all suggestions.
¿Qué estoy haciendo mal o omitiendo?
Agradecería cualquier y todas las sugerencias.
From the .RC:
The IMAGE definition in the .FMG file:
My Question:
From the .RC:
SizeGrip PNG Grip_Resize.PNGCode: Select all
DEFINE IMAGE imgResizeGrip
ROW 325
COL 363
WIDTH 20
HEIGHT 20
PICTURE "SizeGrip"
HELPID Nil
VISIBLE .T.
STRETCH .T.
ACTION Nil
END IMAGE- Attachments
- GripNotVisible.PNG (3.42 KiB) Viewed 1262 times
- Claudio Ricardo
Hi... TRANSPARENT .T. and posibly also need set backcolor, when define image control (see my code)
Attention ! HMG Ide delete this line when open .fmg for edit...
you need put it editing manually the .fmg file.
Edward code using LABEL instead IMAGE is best option.
