Error DBFNTX/1022 Lock required
SALINETAS24
Re: Error DBFNTX/1022 Lock required
Post by SALINETAS24 »
carlazza wrote: Sat Mar 12, 2022 2:40 pm I wrote this post just to ask how to fix the lock problem
Hola amigo, Me refiero si habias probado la CLAUSULA LOCK que tiene la clase browse...., igual ahora me explico mejor
carlazza
Post by carlazza »
SALINETAS24 wrote: Sat Mar 12, 2022 4:06 pm
Ok Ok amigo.
I've already done it but doesn't work.
Thx
franco
Post by franco »
Could you use:
ON DBLCLICK {||{IIF(RLOCK(),EDIT("E"),UNLOCK},{MSGBOX('IN USE')}};
All The Best,
Franco
Canada
carlazza
Post by carlazza »
Looking for the code in the example, adding only the code
IF FE->( RLOCK() )
FU->FIELD1 := XXX
FU->FIELD2 := XXX
FU->FIELD3 := XXX
FU->FIELD4 := XXX
it works!
how is it possible? What does that statement do?
franco
Post by franco »
I use this a lot in my grids and browses.
It only allows the edit if it gets a lock.
you can try taking out the unlock, then try the second edit with same code, It should not get a lock because the first edit has it locked.
in first edit
ON DBLCLICK {||{IIF(RLOCK(),EDIT("E"), },{MSGBOX('IN USE')}};
All The Best,
Franco
Canada
carlazza wrote: Sat Mar 12, 2022 5:25 pm it works!
! Note : when use RLOCK() you MUST UNLOCK
    FU->(dbGoTo ( CDL2A.Br_cassaout.Value ))
    IF RegEnRed( "FU" )
        FU->FIELD1 := XXX
        FU->FIELD2 := XXX
        FU->FIELD3 := XXX
        FU->FIELD4 := XXX
        MsgInfo("No se pudo grabar el Registro...","Verifique" )
    UNLOCK
FUNCTION RegEnRed( cArea )
    DO WHILE ! ( cArea )->( RLock() )
        IF ! MSGRetryCancel( "Registro usado por otro Usuario", cArea )
            RETURN .F.
    ENDDO
RETURN .T.
franco
Post by franco »
Jimmy,
My first post is the proper way. It unlocks on return.
My second post was for Carl to test his second use of same record in second table to see that he could not get lock as it was still locked in first.
All The Best,
Franco
Canada
