andyglezl wrote: ↑Tue Dec 28, 2021 9:35 pm
Hola EDK
Muchas gracias por tu aporte, le veo mucha utilidad.
He estado haciendo pruebas pero ya me perdí, y "necesito una una pequeña ayuda de mis amigos".
Los datos que están en Amarillo si los puedo obtener pero los que están en Azul no logro hacerlo.
Trate de hacerlo con el DO_CASE que genera tu ejemplo pero tampoco resultó.
Alguna idea ?
Hi EDK
Thank you very much for your contribution, I see it very useful.
I've been doing tests but I'm lost, and "I need a little help from my friends."
I can get the data that are in Yellow but the ones that are in Blue I can't.
I tried to do it with the DO_CASE that your example generates but it didn't work either.
Any ideas ?
Pueden agrandar la imagen abriéndola en otra pestaña.
The image can be enlarged by opening it in another tab.
XMLDemo.zip
Improved version with a new feature: in order not to fill the RAM with the XML data table, I added a new function
Below is a prg code generator based on the loaded xml file structure.
I have completely replaced hb_XmlToArray in favor of hb_XMLParser. If someone would like to get an array with xml data, in the generator below I showed how to do it using hb_XMLParser.
You can use the generator to create just a Do Case sequence or an almost ready-to-use .prg code.
In a rather original way, I used resources to self-generate new .prg from source code.
