Illegal characters in filename
Re: Illegal characters in filename
serge_girard wrote: Thu Nov 18, 2021 8:12 am Thanks Jimmy,
That's the solution ! Because of the nature of my program the 'USE' is in a loop from a DIR function
and my USE is this construction:
IF lOpenMode
    if cNew = 'NEW'
       USE ( cDatabase ) EXCLUSIVE  NEW ALIAS cALIAS
       USE ( cDatabase ) EXCLUSIVE ALIAS cALIAS
    if cNew = 'NEW'
       USE ( cDatabase ) SHARED NEW ALIAS cALIAS
       USE ( cDatabase ) SHARED ALIAS cALIAS
IF !NETERR()
   RETURN ( TRUE )
This now works perfect! Thanks again!
In case you want to open several DBFs with an unusual name in different areas this might be helpful:
Local cDBF := "6. März - Wöchentliche Backup-Datei.dbf", i
IF !FILE(cDBF)
	DBCREATE(cDBF, { {'ID','N',10,0} , {'NAME','C',30,0}, {'FLAG','C',3,0} } )
	USE (cDBF) ALIAS (ValidAliasName (cDBF))
	FOR i := 1 TO 2000
		APPEND BLANK
		REPLACE id WITH i
		REPLACE name WITH "Name #" + AllTrim(Str(i))
		REPLACE flag WITH IF (i % 3 = 0, "C", IF ( i % 2 = 0, "B", "A" ) )
	NEXT i
	CLOSE
USE (cDBF) ALIAS (ValidAliasName (cDBF)) SHARED
EDIT EXTENDED
Function ValidAliasName ( cAliasName )
Local i, cValidAliasName := ""
cAliasName := hb_FNameName( cAliasName )
cAliasName := IF ( .NOT. IsAlpha( cAliasName ), "X", "") + cAliasName		//alias must begins alpha
FOR i := 1 TO Len ( cAliasName )
	cValidAliasName += IF ( Lower(SubStr( cAliasName, i, 1)) $ "abcdefghijklmnopqrstuvwxyz1234567890_", SubStr( cAliasName, i, 1), "_" )
NEXT i
RETURN cValidAliasName
Thanks Edward and Jimme,
Great solutions!
