Add a Signature to a Report
Red2
Re: Add a Signature to a Report
Post by Red2 »
Hi Jimmy and andyglezl,
Thank you for your valuable feedback and suggestions.
BEGIN PICTURE
	VALUE	"FormSig"    // Form's Signature
	ROW		203
	COL		45
	WIDTH		40
	HEIGHT		10
	Transparent     .T.
	STRETCH		.F.
	ADJUSTIMAGE	.T.
End Picture
As I have stated the above command overwrites the form image layer below it:
[image]
[/image]
If I substitute the old style "@ row col" syntax suggested by andyglezl
@ 203, 45 PRINT IMAGE "FormSig" WIDTH 40  HEIGHT 10
Then no image is produced. Adding "TRANSPARENT" makes no difference here.
Perhaps these two report code styles, "@ row col ..." and "BEGIN ... END ..." don't combine in a .PRG. Can both styles be mixed in the same report?
Jimmy, can you elaborate on what you mean by
have you try to "overlay" Image with Image with "normal" Code ?
I am not quite sure what you mean here. I would appreciate it.
I am very grateful for all of this expert help. More ideas? Thank you!
Red2 wrote: Tue Jul 13, 2021 11:49 pm Jimmy, can you elaborate on what you mean by
Sample
@ X,Y PICTURE Pic1
@ X,Y PICTURE Pic2
both use same Coordinate but that does not "mix" Image ... you will see only 1 x Image
you have to "paint" Pixel of both Image into DC and than display/print it
IMHO you have to "cut out" Place where you want to put Signature.
under Xbase++ i can "cut out" using "SetWindowRgn" but under harbour / HMG it seems only to work on Windows itself.
have a look here viewtopic.php?f=12&t=6176&p=60016 how to "mask" Image so it become "transparency"
De que se puede hacer, se puede...
Solo tienes que "jugar" con la calidad de la imagen
hasta encontrar la que satisfaga.
What can be done, can ...
You just have to "play" with the image quality
until you find the one that satisfies.
Red2
Post by Red2 »
Hola andyglezl,
Google Translation
Gracias por tomarse el tiempo para proporcionar el enlace "... \ Print_to_PDF". (
Acabo de volver a acceder al sitio de HMGForum).
Lo echaré un buen vistazo aunque puede que no tenga tiempo hasta el lunes.
¡Gracias de nuevo!
Thank you for taking the time to provide the "...\Print_to_PDF" link.
(I am just now again able to access the HMGForum site).
I will have a good look although I may not have time until Monday.
Thanks again!
