index dbf character numbers
Re: index dbf character numbers
franco wrote: Wed Jun 09, 2021 4:52 pm I get argument error when trying to use strzero.
what Type is your FIELD :?:
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Post by Claudio Ricardo »
Hi...
Maybe you can modify all records in db... (Backup first)
Local cCode := ""
Use db New
DbGoTop ()
	While .NOT. Eof ()
		cCode := db->Code
		Replace Code With StrZero ( Val ( cCode ),10)
		Skip
	EndDo
Commit
Use
And search:
Use db New
Index On Code To iCode
	If DbSeek (cCodeYouFind, .T.)  // Much better to old Seek and no need Go Top previous
		? Found
	EndIf
franco
Post by franco »
field is character
All The Best,
Franco
Canada
I honestly do not know if I understand correctly, but I am giving an example where in the invoice.dbf database the field "inv_number" is a character type and the properly indexed file browse and searches correctly invoice numbers in ascending numerical order.
Function Main()
SET CENTURY ON
SET DATE TO ANSI
DEFINE WINDOW test AT 0 , 0 WIDTH 400 HEIGHT 600 TITLE "Demo" MAIN NOSIZE NOMAXIMIZE;
	ON INIT PrepareDBF()
	@ 20,10 TEXTBOX tSeek WIDTH 120 VALUE "" INPUTMASK "9999999999" ;
        ON CHANGE Iif( ! Empty( test.tSeek.Value ) , ( DBSEEK (VAL ( test.tSeek.Value )), test.Browse_1.Value := RecNo()) , Nil )
	@ 70,10 BROWSE Browse_1 ;
      OF test ;
      WIDTH 350 ;
      HEIGHT 430 ;
      FONT "Arial" ;
      SIZE 9 ;
      HEADERS { "Invoice #","Date", "Customer" } ;
      WIDTHS { 120,80, 120 } ;
      WORKAREA INVOICE ;
      FIELDS { "INV_NUMBER", "INV_DATE", "CustomerID" } ;
      ON GOTFOCUS Nil;
      ON CHANGE Nil ;
      ON DBLCLICK Nil ;
      JUSTIFY { 0,0, 0 }
CENTER WINDOW test
ACTIVATE WINDOW test
Function PrepareDBF()
Local aStru := { {"INV_NUMBER", "C", 10, 0}, {"INV_DATE", "D", 8, 0}, {"CustomerID", "N", 10, 0 } }
Local i, k := 1
IF ! FILE ( "Invoice.dbf" )
	WAIT WINDOW "Preparing invoice.dbf, please wait ..." NOWAIT
	DBCREATE( "Invoice.dbf", aStru )
	USE Invoice.dbf NEW
	FOR i := 122222 TO 1 STEP -1
		IF i % 100 = 0
			k++
		DO EVENTS
		APPEND BLANK
		REPLACE inv_number WITH AllTrim( Str ( i ) )
		REPLACE inv_date WITH Date() - k
		REPLACE CustomerId WITH hb_RandomInt ( 1, 1000 )
	NEXT i
	WAIT CLEAR
	CLOSE DATA
IF ! FILE ( "Invoice.ntx" )
	USE Invoice.dbf NEW
	WAIT WINDOW "Preparing invoice.ntx, please wait ..." NOWAIT
	INDEX ON Val ( inv_number ) TO Invoice.ntx
	CLOSE DATA
	WAIT CLEAR
SELECT 1
USE Invoice.dbf Index Invoice.ntx
franco
Post by franco »
Edk, This works but my invoice numbers started with 555B, then went from 10,000, then went from 100,000.
Your idea works but you have to enter the complete invoice number.
I does not go to first 100000. if your first invoice is 100000 and I enter 1 invoice is not found.
In numeric search it does not soft seek or go to first invoice starting with 1, then 3 and so o if your scanning for invoice 132132.
Can you make the browse reset for each entry.
Thanks
Franco
All The Best,
Franco
Canada
Hi Franco. Is the 555B a fixed prefix? Could you please attach a sample file with invoice numbers?
franco wrote: Wed Jun 09, 2021 5:45 pm field is character
do you also want to add "Date" (as String) :?:
EDK show you the Way to use VAL() and numeric Index
but if you want to add "more" like Date you need a String for IndexKey()
 INDEX ON STRZERO( VAL( FIELD->cNumber), 6) + DTOS( FIELD->dDATE)
 @ X,Y GET nNumber PICTURE 999999
 cSeek := STRZERO( nNumber, 6) + DTOS( DATE() )
Do you want to be able to search by the initial fragment of the invoice number, but to show all the matching results in numerical rather than character-ascending order?
I think that such an index key cannot be built. For this reason, Browse cannot be used. But ... you can build a Virtual Grid, where you first need to create a numeric table with invoice numbers matching the search pattern, sort the table according to the ascending order, and then display the DBF file content in the grid according to the order from the previously created numeric table.
Bez tytułu.png (114.3 KiB) Viewed 2178 times
I only have some concerns about the performance of such a solution in a network environment (the database is searched twice, the first time to create a list, then to display it) :roll:
Sample:
Function Main()
Local aDBFInvNum := {}
Private cPrefix := "555B"
SET CENTURY ON
SET DATE TO ANSI
        ON CHANGE If( ! Empty( test.tSeek.Value ) , ;
			( aDBFInvNum := GetInvNumList ( test.tSeek.Value, aDBFInvNum ), ;
			  Grid_1Refresh ( aDBFInvNum ) ), ;
		  Nil )
	@ 70,10 GRID Grid_1 ;
		WIDTH 350 ;
		HEIGHT 430 ;
		JUSTIFY {GRID_JTFY_LEFT, GRID_JTFY_RIGHT, GRID_JTFY_RIGHT } ;
		ON GOTFOCUS Nil ;
		ON CHANGE Nil ;
		VIRTUAL ;
		ITEMCOUNT LEN( aDBFInvNum ) ;
		ON QUERYDATA DBFQuery ( aDBFInvNum )
CENTER WINDOW test
Local i, k := 1
IF ! FILE ( "Invoice1.dbf" )
	WAIT WINDOW "Preparing invoice1.dbf, please wait ..." NOWAIT
	DBCREATE( "Invoice1.dbf", aStru )
	USE Invoice1.dbf NEW
	FOR i := 133333 TO 10000 STEP -1
		IF i % 100 = 0
			k++
		DO EVENTS
		APPEND BLANK
		REPLACE inv_number WITH cPrefix + AllTrim( Str ( i ) )
	NEXT i
	WAIT CLEAR
	CLOSE DATA
IF ! FILE ( "Invoice1.ntx" )
	WAIT WINDOW "Preparing invoice1.ntx, please wait ..." NOWAIT
	INDEX ON inv_number TO Invoice1.ntx
	CLOSE DATA
	WAIT CLEAR
SELECT 1
USE Invoice1.dbf Index Invoice1.ntx
FUNCTION DBFQuery ( aDBFInvNum )
Local nQRow := This.QueryRowIndex
Local nQCol := This.QueryColIndex
IF nQRow = 0 .OR. nQCol = 0 .OR. nQRow > Len ( aDBFInvNum ) .OR. nQCol > FCOUNT()
SEEK cPrefix + AllTrim( Str ( aDBFInvNum [ nQRow ] ) ) + " "
IF FOUND()
	This.QueryData :=  invoice1->&(FIELD( nQCol ))
FUNCTION Grid_1Refresh ( aDBFInvNum )
IF test.Grid_1.Itemcount < Len (aDBFInvNum)
	test.Grid_1.Itemcount := 0
test.Grid_1.Itemcount := Len (aDBFInvNum)
test.Grid_1.value := 1
test.Grid_1.refresh
FUNCTION GetInvNumList ( cSeekInvNum, aDBFInvNum )
Local nItem := 0
StopWindowEventProcedure ("test", .T.)
StopControlEventProcedure ("tSeek", "test", .T.)
cSeekInvNum := AllTrim ( cSeekInvNum )
aDBFInvNum := {}
GO TOP
SEEK cPrefix + cSeekInvNum
DO WHILE invoice1->inv_number = cPrefix + cSeekInvNum .AND. !EOF()
	AADD( aDBFInvNum, Val ( StrTran( invoice1->inv_number, cPrefix, "" ) ) )
	SKIP
	Do Events
ENDDO
StopControlEventProcedure ("tSeek", "test", .F.)
StopWindowEventProcedure ("test", .F.)
RETURN ASORT ( aDBFInvNum )
you can use SCOPE for "cPrefix"
you can find "part of" String using $
INDEX ON FIELD->cPrefix + STRZERO(VAL((FIELD-cNumber),6)
SEEK(cPrefix)
SET SCOPE TO (cPrefix)
SET FILTER TO LTRIM(STR(nNumber)) $ FIELD->cNumber
BROWSE
after BROWSE you need to "reset"
SET FILTER TO
SET SCOPE TO
