SELECT PRINTER DIALOG
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: SELECT PRINTER DIALOG
Post by dragancesu »
Look in manual
SELECT PRINTER <cPrinter> | DEFAULT
    [ TO <lSuccessVar> ]
    [ ORIENTATION <nOrientation> ]
    [ PAPERSIZE <nPaperSize> ]
    [ PAPERLENGTH <nPaperLength> ]
    [ PAPERWIDTH <nPaperWidth> ]
    [ COPIES <nCopies> ]
    [ DEFAULTSOURCE <nDefaultSource> ]
    [ QUALITY <nQuality> ]
    [ COLOR <nColor> ]
    [ DUPLEX <nDuplex> ]
    [ COLLATE <nCollate> ]
    [ PREVIEW ]
    [ NOSAVEBUTTON ]
    [ DIALOGFILENAME <cDialogFileName> ]
    [ SAVEAS <cFullFileName> ]
you have all definition for printer, and must define before create page
Forget count lines, measure is milimeter, it's so simple
CalScot
Post by CalScot »
I think that the bottom line is that however you choose to do it, you must define the parameters for each printer that could be selected.
SALINETAS24
Post by SALINETAS24 »
Muchas gracias a todos por sus sugerencias.
Creo haber encontrado el camino.
Esta escrito en la carpeta HFCL, en el GRIDPRINT.PRG
Vamos con una cervecita fresquita
JALMAG
DBs Used: DBF, MariaDB
Post by JALMAG »
Hola amigo, aqui tienes todas las opciones disponibles:
http://hmgextended.com/files/manual/index.html
En Library, MiniPrint -> Print Commands->Select printer
