Add some text in the exe file
hmgchang
Re: Add some text in the exe file
Post by hmgchang »
Ok Mol...
Good suggestion and make sense to have an .ini file instead of modifying the
running .exe file.
Any suggestion for the .ini file type ? text file ?
Thks n Rgds
Chang
Just Hmg It !
TXT and as save as name.INI
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Post by Claudio Ricardo »
Hi...
Example Config.ini file... if not exist, is created for Write_Ini function
PUBLIC pcFileIni := GetCurrentFolder () + "\Config.ini"
PUBLIC pnMainRowIni := 10	// First init value
PUBLIC pnMainColIni := 10	// First init value
Set Language To Spanish
Set CodePage To Unicode
Set Multiple Off
Set Century On
Set Date French
Set Decimals To 2
Set BrowseSync On
Set TooltipStyle Balloon
	If File (pcFileIni)
		Read_Ini ()
	Else
		Write_Ini ()
	EndIf
        Load Window Main
			SetProperty ("Main" , "Col" , pnMainColIni)
			SetProperty ("Main" , "Row" , pnMainRowIni)
        Main. Activate
Function Read_Ini
	BEGIN INI FILE pcFileIni
		GET pnMainColIni SECTION "MAIN" ENTRY "ColIni"
		GET pnMainRowIni SECTION "MAIN" ENTRY "RowIni"
	END INI
Function Write_Ini
		SET SECTION "MAIN" ENTRY "ColIni" TO pnMainColIni
		SET SECTION "MAIN" ENTRY "RowIni" TO pnMainRowIni
	END INI
Function Main_Button_Exit
	pnMainColIni := GetProperty ( "Main" , "Col" )
	pnMainRowIni := GetProperty ( "Main" , "Row" )
	Write_Ini ()
	Main. Release
This save in Config.ini Row and Col main window position stored in public var's for remember at init the last window position
but can save much more information.
This is the content of the example .ini file:
[MAIN]
ColIni=96
RowIni=18
Pd. Sorry for my bad english :oops:
hmgchang wrote: Wed Mar 17, 2021 6:21 am Ok Mol...
running .exe file.
Thks n Rgds
Chang
hmgchang wrote: Wed Mar 17, 2021 4:04 am Hola Masters,
i can use ON SIZE event when i size a window,
but how about moving a window... any ON MOVE ?
or how can i catch the move event ?
Thks n rgds
Chang
See this example, but according to your goal, you don't need to read window parameters on the fly, just handle it when closing the window.
#define WM_MOVE            		0x0003
#define WM_SIZE                         0x0005
Local nFRow:=0, nFCol:=0, nFWidth:=400, nFHeight:=600, lCenter:=.T.
IF File("Config.ini")
   Begin ini file ("Config.ini")
      Get nFRow    Section "FORM_1" ENTRY "Row"
      Get nFCol    Section "FORM_1" ENTRY "Col"
      Get nFWidth  Section "FORM_1" ENTRY "Width"
      Get nFHeight Section "FORM_1" ENTRY "Height"
   End Ini
   lCenter:=.F.
EndIf
DEFINE WINDOW Form_1 AT nFRow, nFCol WIDTH nFWidth HEIGHT nFHeight TITLE 'Hello World!' MAIN ;
	ON RELEASE SaveIni()
  DEFINE STATUSBAR
     STATUSITEM "Try moving or resizing this window"
  END STATUSBAR
IF lCenter
    CENTER WINDOW Form_1
CREATE EVENT PROCNAME MoveAndSizeForm_1() HWND Form_1.HANDLE
ACTIVATE WINDOW Form_1
Function SaveIni()
      Set Section "FORM_1" ENTRY "Row" To Form_1.Row
      Set Section "FORM_1" ENTRY "Col" To Form_1.Col
      Set Section "FORM_1" ENTRY "Width" To Form_1.Width
      Set Section "FORM_1" ENTRY "Height" To Form_1.Height
End Ini
Function MoveAndSizeForm_1()
Local nMSG := EventMSG ()
Local xPos, yPos, nWidth, nHeight, nRow, nCol
IF nMSG == WM_MOVE .OR. nMSG == WM_SIZE
	xPos := LOWORD(EventlParam())
	yPos := HIWORD(EventlParam())
	nWidth := Form_1.Width
	nHeight := Form_1.Height
	nRow := Form_1.Row
	nCol := Form_1.Col
	Form_1.StatusBar.Item(1):="Form_1  Row: "+StrZero(nRow,5,0)+" / Col: "+StrZero(nCol,5,0)+" | Width: "+StrZero(nWidth,5,0)+" / Height: "+StrZero(nHeight,5,0)+" | xPos: "+StrZero(xPos,5,0)+" / yPos: "+StrZero(yPos,5,0)
hmgchang
Post by hmgchang »
Hola and thousand thanks to Mr. Claudio Ricardo and Mr. edk
for the very useful code.
It solved my problem effectively.
But still i wonder :
1. why the ON MOVE event not build in the hmg ?
2. any documentation on the BEGIN INI statement ? or any others un-documented statements ?
3.
These users thanked the author edk for the post (total 2):
danielmaximiliano (Thu Mar 18, 2021 12:38 am) • andyglezl (Thu Mar 18, 2021 2:12 am)
. How can i make this ?
Thks n Rgds
Chang
Just Hmg It !
Claudio Ricardo
Hi...
Maybe no one needed to start an event when moving a window.
With this button:
