No funciona print image con la nueva actualización de windows
Re: No funciona print image con la nueva actualización de windows
Ya esta enterada Microsoft
https://www.xatakawindows.com/windows/m ... ega-parche
https://support.microsoft.com/en-us/top ... 56d3626e14
GodkarPS
hmg with SQL SERVER - Location: INDIA
Dear All, problem has been solved after uninstall <Security Update for Microsoft Windows (KB5000808)>
This happens when KB5000808 or KB5000802 are installed on Win10. Uninstalling temporarily fixes the problem. Microsoft put out updates yesterday (see https://www.bleepingcomputer.com/news/m ... g-crashes/), but they do not fix the printing problem we are having. I do not believe there is a way to permanently block this update. I have paused updates for 15 days on impacted computers.
When your toolbox only contains a hammer, everything looks like a nail...
- AUGE_OHR
did you use SMB1 or SMB2
have have "read" it does NOT work with "Drive"
but it work with UNC Path
X:\Picture\Test.BMPCode: Select all
\\Server\Picture\Test.BMPhave fun
Thank you for the suggestion. I tried it both ways and was not successful.
I have created a sample showing the problem by modifying SAMPLES\PrintSystem\EMF to include a jpg and a png. The png should be blank/white and the jpg should be black on Win 10 systems with KB5000802 or KB5000808 installed.
- EMFdemo-with-images.zip
- (88.87 KiB) Downloaded 156 times
I asked this before. If there is a way it could be a work around for 802 problem. print to pdf and execute direct to default or dialog printer.
Does anyone know how I can print a .pdf file to my default printer direct or preview.
All The Best,
Franco
Canada
Franco
Canada
Try...
SHELLEXECUTE( 0, "Print" , "AcroRd32.exe", cRaiz + 'Clientes.pdf' )
- salamandra
- DBs Used: DBF, MySQL, SQL
Hi franco,
This will open your pdf file with Adobe (or your default pdf reader) Reader and you´ll can print it out, with or without file preview.
Salamandra, Brazil
You can try execute file 'your_pdf_file.pdf'
Salamandra, Brazil
These solutions with exporting to pdf or direct print aren't acceptable in my opinion. How to rebuild a lot of applications with many points of printing?
