Cargar array en Grid
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Re: Cargar array en Grid
Post by Claudio Ricardo »
Hola...
Si el array es multidimensional y coincide el número de campos con las columnas del grid, podrías probar así:
If Len (aArray) > 0
   For i = 1 To Len (aArray)
      DoMethod ("Form_X" , "Grid_X" , "AddItem" , aArray [i] )
   Next
   DoMethod ("Form_X" , "Grid_X" , "Refresh")
   DoMethod ("Form_X" , "Grid_X" , "SetFocus")   // si quiero dejar el foco en el grid //
EndIf
A mi me funciona perfecto de este modo...
Claudio Ricardo
Si lo que deseas es limpiar el grid y luego cargarle datos nuevos:
If Len (aArray) > 0
   DoMethod ("Form_X" , "Grid_X" , "DeleteAllItems")
   Next
EndIf
jparada
Post by jparada »
Hola,
Ahora funciona correctamente, gracias a todos que me están ayudando a avanzar en especial a Martín, Claudio y Jimmy.
Saludos,
Javier
por que no usas VIRTUAL GRID? Esto es muy facil
jparada
Post by jparada »
Hi mol,
Honestly I have never worked with the grid more than representing data that comes from an array and that's all, I don't know what advantages or disadvantages have working with a virtual grid, or even if the syntax is fully supported.
Javier
Sorry for my bad Spanish .
Virtual grid is really easy to use. You don't spend time to load data by adding rows.
You don't duplicate resource usage because data presented by grid is still only in your array
Claudio Ricardo
Marek:
Your answer is well written in Spanish ...
I never used virtual grid but following your advice I will try it in my new project!
Thanks!
