HMG IDE source code
Re: HMG IDE source code
As CALSCOT mentioned:
I applaud the source code becoming public, but I hope that there is some sort of central control or agreemnt as a mechanism to try to ensure that we don't end up with a whole lot of slightly incompatible versions. That could become a nightmare and do long term damage if it was to happen. Any thoughts on how that can be prevented?
This must indeed be solved! Rathi any ideas how to manage?
Super news!
Time to work to update everything for all changes in HMG and add new properties!
Thanks for sharing!
i like to request to add "DBF Field" into FMG in IDE
i have this Code to create a new *.FMG from DBF which can be load after *.FMG was create
DBF2FMG.ZIP
(2.23 KiB) Downloaded 509 times
jairpinho
Post by jairpinho »
thanks Roberto and Claudio for providing the IDE, this will help to improve the community a lot
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
In order to get successful compilation of IDE in HMG 3.5, I had to change this from line 1349
PROCEDURE LOAD_LANGUAGE_MESSAGE()
LOCAL i, nNum, cText, cMsgs, cLin
   cMsgs := HB_MEMOREAD (StartUpFolder + ALLTRIM ( HB_UTF8STRTRAN (HB_MEMOREAD (StartUpFolder + cFileLanguage), chr(26), ' ')))
   AFILL (aMsgs, "XXX")
   for i := 1 To HMG_LEN ( cMsgs )
      cLin := ALLTRIM(memoline ( cMsgs , 254 , i ))
      nNum := VAL ( HB_ULEFT ( cLin , 3 ) )
      if nNum > 0
         cText := ALLTRIM ( HB_USUBSTR ( cLin , 5 , 254 ) )
         aMsgs [ nNum ] := cText
   next i
to this.
It seems that there are more memoline() and HB_MEMOREAD() used in the code. I am curious to find, why does it work in 3.4.4 and doesn't work in 3.5.
//   cMsgs := HB_MEMOREAD (StartUpFolder + ALLTRIM ( HB_UTF8STRTRAN (HB_MEMOREAD (StartUpFolder + cFileLanguage), chr(26), ' ')))
   cMsgs := HB_ATOKENS( HB_MEMOREAD( StartUpFolder + ALLTRIM ( HB_UTF8STRTRAN (HB_MEMOREAD (StartUpFolder + cFileLanguage), chr(26), ' ')) ),   CRLF )
      cLin := cMsgs[ i ] // ALLTRIM(memoline ( cMsgs , 254 , i ))
      if nNum > 0
   next i
Anand
Post by Anand »
srvet_claudio wrote: Mon Nov 16, 2020 5:40 pm Hi all,
Roberto has decided to make public the source code of the HMG IDE.
Thanks to Roberto for this great work!
It's a great project, I hope you enjoy it!
Finally.
Many request were made for it earlier. And we thank Roberto and Claudio for it.
Hope it goes to Git and controlled as like HMG 3.5
Anand
Anand
Pcmodula
Post by Pcmodula »
¡Leyendo entre líneas estas son buenas y malas noticias!
Hermoso porque aumenta el conocimiento de todos,
feo porque todavía no tiene las últimas sugerencias de Roberto.
Me gustaría que me explicara cuáles son los conceptos "incorrectos" de este ide.
Dado que ha delegado al Sr. Soto para publicar las fuentes, tal vez quiera
decir que está pensando en abandonar un proyecto que considera maduro y en
capaz de continuar de forma independiente?
¡Sería un verdadero golpe para el corazón!
Salu2
Pcmodula
Reading between the lines this is good and bad news!
Beautiful because it increases everyone's knowledge,
ugly because she still doesn't have Roberto's latest suggestions.
I would like you to explain what are the "wrong" concepts of this ide.
Since he has delegated Mr. Soto to publish the sources, maybe he wants
say that he is thinking of abandoning a project he deems mature and in
able to continue independently?
It would be a real blow to the heart!
Rds
Pcmodula
fouednoomen
Post by fouednoomen »
Thanks to Roberto and Claudio !
martingz
Post by martingz »
Mil gracias a Roberto y Claudio
ASESORMIX
Post by ASESORMIX »
Saludos Cordiales Sr. Roberto.
Muchísimas Gracias por compartir tu gran esfuerzo con nosotros.
Tu gran generosidad sea recompensada con bendiciones de la Divina Providencia para ti y todos los tuyos.
Gracias, muchisimas gracias.
