libxlsxwriter -> XlsxReader ?
Re: libxlsxwriter -> XlsxReader ?
fouednoomen wrote: Wed May 27, 2020 3:15 pm we need CStruct.ch
here it is
CStruct.zip
(2.27 KiB) Downloaded 179 times
jparada wrote: Wed May 27, 2020 2:28 pm so I am using the Riztan wrapper, please take a look at https://github.com/riztan/hbxlsxwriter
i ZIP of your Link i found "C" Source. is it to build DLL :?:
i have look into hbxlsxwriter.hbp
/libxlsxwriter/include
#-iflag={bcc}-a
i have no Folder /libxlsxwriter/include
can those File from c:\MiniGUI\SAMPLES\Advanced\HbXlsxWriter\xlsxwriter\*.h be used :?:
i guess BCC is used so it is for MiniGUI Extended Version.
how to re-write hbxlsxwriter.hbp for HMG using MinGW :idea:
-hblib
-inc
-o${hb_name}
-w3 -es2
-depkeyhead=xlsxwriter:xlsxwriter.h
-depcontrol=xlsxwriter:no{HB_BUILD_3RDEXT='no'}
-depcontrol=xlsxwriter:${HB_WITH_XLSXWRITER}
-depincpath=xlsxwriter:${HOME}/libxlsxwriter/include
-depincpath=xlsxwriter:/usr/include
-depincpath=xlsxwriter:/libxlsxwriter/include
-depfinish=xlsxwriter
#-iflag={bcc}-a
${hb_name}.hbx
#app.c
workbook.c
worksheet.c
format.c
chart.c
chartsheet.c
content_types.c
core.c
custom.c
drawing.c
relationships.c
shared_strings.c
styles.c
utility.c
hb_misc.c
hb_others.prg
my Question was how to READ a XLSx into Array to display it with GRID.
i guess it must be possible when WRITE a XLSx using XlsWriter.
have found this
https://libxlsxwriter.github.io/introduction.html
It can only create new files. It cannot read or modify existing files.
so i need other Solution to READ a XLSx File
AUGE_OHR wrote: Fri May 29, 2020 9:28 pm have found this
try opensource https://sourceforge.net/projects/xlsxio/
Read / Write Xlsx , include DLL and .a library
//open .xlsx file for reading
xlsxioreader xlsxioread;
if ((xlsxioread = xlsxioread_open(filename)) == NULL) {
  fprintf(stderr, "Error opening .xlsx file\n");
  return 1;
//list available sheets
xlsxioreadersheetlist sheetlist;
const char* sheetname;
printf("Available sheets:\n");
if ((sheetlist = xlsxioread_sheetlist_open(xlsxioread)) != NULL) {
  while ((sheetname = xlsxioread_sheetlist_next(sheetlist)) != NULL) {
    printf(" - %s\n", sheetname);
  xlsxioread_sheetlist_close(sheetlist);
//read values from first sheet
char* value;
printf("Contents of first sheet:\n");
xlsxioreadersheet sheet = xlsxioread_sheet_open(xlsxioread, NULL, XLSXIOREAD_SKIP_EMPTY_ROWS);
while (xlsxioread_sheet_next_row(sheet)) {
  while ((value = xlsxioread_sheet_next_cell(sheet)) != NULL) {
    printf("%s\t", value);
    free(value);
  printf("\n");
xlsxioread_sheet_close(sheet);
//clean up
xlsxioread_close(xlsxioread);
danielmaximiliano wrote: Sat May 30, 2020 12:38 am try opensource https://sourceforge.net/projects/xlsxio/
thx for Code, i will look at it
Yes. It looks nice since it doesn't require Excel to be installed.
We need some Harbour bridge for the library. I think @Auge_Ohr can do this.
nekbmm
DBs Used: DBF,SQLite
Post by nekbmm »
.AND. | .OR. read data from file. ('SELECT * FROM [sheetName$])
