use FMG more than once
Re: use FMG more than once
edk wrote: Fri Nov 22, 2019 9:24 pm
AUGE_OHR wrote: Fri Nov 22, 2019 8:33 pm i saw Sample with Macro as Form-Name
   DEFINE WINDOW &fMain ;
so when 1st Form is called by "Form_01" and 2nd Form is called "Form_02" that i can use
   nResult1 := Form_01.TEXT_1.Value
   nResult2 := Form_02.TEXT_1.Value
so how to get this construction. :idea:
nResult := GetProperty ( fMain, "TEXT_1", "Value")
AHA ... :idea:
the Form "is" a "O"bject so i can ask for Child Property. :D
Question : is there a Function to "test" for Member "TEXT_1" :?:
   IsMemberVar( <oObject>, <cVarName>, [<nAttributes>] ) --> lExist
   IsMethod( <oObject>, <cMethodName>, [<nAttributes>] ) --> lExist
Lo siento, yo nunca he usado las formas FMG ...
Pero quizá este ejemplo ayude.
I'm sorry, I've never used FMG forms ...
But maybe this example helps.
MULTIWIN.rar
(3.27 KiB) Downloaded 213 times
https://www.hmgforum.com/viewtopic.php? ... &start=110
andyglezl wrote: Sat Nov 23, 2019 3:41 am Lo siento, yo nunca he usado las formas FMG ...
THX for Demo.
i saw it. when press Button on Main Form i got 2 x new Form.
but i want to press Button in Main again and again ... and each Time i want a new Form.
other Solution are using Tabpage like in Firefox & Co.
but it seems to be a Problem to delete a Tab No which is not last Tab :?:
e.g. i have 3 x Tab and want to close Tab No 2 ... is this possible in HMG :?:
does i this link point to FMG_Editor.rar :?:
Harbour 3.2.0dev (r1703241902)
C:\MiniGUI\SAMPLES\0\MAIL\8\FMG_Editor.prg:1796:24: fatal error: c_registry.c: No such file or directory
compilation terminated.
hbmk2[FMG_Editor]: Error: Running C/C++ compiler. 1
gcc.exe -c -O3 -march=i586 -mtune=pentiumpro -fomit-frame-pointer -W -Wall -pipe -IC:/hmg.3.4.4/harbour/include -IC:/MiniGUI/SAMPLES/0/MAIL/8 -IC:/hmg.3.4.4/include R:/Temp/hbmk_7cvm8f.dir/FMG_Editor.c R:/Temp/hbmk_oyuyf0.c
i found other Version here https://www.hmgforum.com/viewtopic.php? ... &start=130
but that Version give a lot of Error ... ( ANSI / UNICODE ? )
AUGE_OHR wrote: Sat Nov 23, 2019 7:07 am
HI. try my sample in Minigui
C:\MiniGUI\SAMPLES\BASIC\Tab_2
My Tab example minigui.rar
(591.14 KiB) Downloaded 212 times
adapt the code so as not to create a previously created TAB since this example was created for a need that was never implemented.
Or maybe something like that? In my example there are two ways for the context menu of the grid: for the Child window - regular, for the Standard window - more flexible ;)
multiforms.7z
(2.62 KiB) Downloaded 233 times
edk wrote: Sat Nov 23, 2019 7:00 pm Or maybe something like that? In my example there are two ways for the context menu of the grid: for the Child window - regular, for the Standard window - more flexible ;)
multiforms.7z
YES ... that's it THX
my Error was "different" Name while it MUST be same ( Grid_1 ) and have the same Parent ( fMain )
   DEFINE GRID Grid_1
      PARENT fMain
   DEFINE CONTROL CONTEXT MENU Grid_1 OF &fMain
Question :
      @ <nRow> ,<nCol>
            GRID <ControlName>
            [ OF | PARENT <ParentWindowName> ]
and
      DEFINE GRID <ControlName>
            ROW <nValue>
            COL <nValue>
why is 2nd Sample "only" PARENT while 1st Sample have "OF" and "PARENT" :?:
what is the Differenz between "OF" and "PARENT" :?:
AUGE_OHR wrote: Sat Nov 23, 2019 8:25 pm Question :
      @ <nRow> ,<nCol>
            GRID <ControlName>
and
            ROW <nValue>
            COL <nValue>
Many controls have two syntax, OF/PARENT means the same: the name of the form to which the control should be assigned.
next Problem when using many Form with Variable and Macro in a Loop
i have create 8 x Form with Image in a loop.
  FOR i = 1 TO iMax
     cForm  := "Form_"+strzero(i, 2)
     cImage := "Image_"+strzero(i, 2)
     aData[1] := cForm
     aData[2] := hBitmap
     DEFINE WINDOW &cForm ;
        AT nTop, nLeft ;
        WIDTH aSubSize[ 1 ] HEIGHT aSubSize[ 2 ] ;
        ON PAINT Paint_Background_Window(cForm,aData)
        @ 0,0 IMAGE &cImage ;
           PICTURE aLights[i][1] ;
           STRETCH
      // add to Array for later
      aAdd(a_Forms, "Form_" + strzero(i,2))
      nLeft  += aSubSize[ 1 ] + 2
i want to use PAINT Event to change Background (see Wallpaper Sample)
Problem : cForm or aData[1] is always "last Number" ( Form_08 ) :evil:
general i know this Problem so i use a function to "detache" Variable
   ON PAINT Paint_Background_Window( Detache_var(cForm) ,hBitmap) ;
FUNCTION Detache_var(cVar)
LOCAL cNewVar := cVar
RETURN cNewVar
but this does not help using harbour / HMG :(
p.s. i do not want to use 8 x Function Paint_Background_WindowXX()
AUGE_OHR wrote: Mon Nov 25, 2019 3:46 am hi,
  FOR i = 1 TO iMax
     aData[1] := cForm
     aData[2] := hBitmap
        AT nTop, nLeft ;
           STRETCH
RETURN cNewVar
try:
  FOR i = 1 TO iMax
     aData[1] := cForm
     aData[2] := hBitmap
     cOnPaintProc := "Paint_Background_Window( '" + cForm + "', '" + hb_Serialize(aData) + "')"
        AT nTop, nLeft ;
        ON PAINT &cOnPaintProc
           STRETCH
Function Paint_Background_Window(cForm,cData)
Local aData := hb_DeSerialize(cData)
Or
   cOnPaintProc := 'Paint_Background_Window( '+ hb_ValToExp( cForm) + ' , ' + hb_ValToExp( aData ) +')'
Function Paint_Background_Window(cForm,aData)
edk wrote: Mon Nov 25, 2019 9:11 am try:
Or
YES... that it, THX
