The memory leak problem in hmg only occurs in unicode, and is due to the lack of explicit memory release when at c code the strings are transformed into utf8 to utf16 which is the Windows standard. This bug drags back from the hmg unicode startups and is my fault. But to fix it requires rewriting much of the c code and unfortunately I don't have time to work on hmg.
I'm sorry but I'm visiting the forum. I haven't programmed for Windows for a long time, my interest now is mobile applications...
The STATUSBAR control has a BUG
- srvet_claudio
Re: The STATUSBAR control has a BUG
Wow! Welcome Claudio!
- salamandra
- DBs Used: DBF, MySQL, SQL
Hola Dr Claudio,
>> ENGLISH <<
This HMG Unicode related issue got me a little discouraged. I have some large systems (about 400 programs and more than 500 forms) in ANSI that for various reasons I would like to convert to UNICODE, but apparently it is better to wait (or desist ??). What would be your recommendation regarding this?
Salamandra, Brazil
Esa cuestion relacionada a HMG Unicode me desanimo un poco. Tengo algunos sistemas grandes (cerca de 400 programas y mas de 500 forms) en ANSI que por varias razones me gustaria convertir en UNICODE, mas por lo visto es mejor esperar (o desistir ??). Qual seria tu recomendacion a ese respecto ?srvet_claudio wrote: ↑Thu Jul 02, 2020 4:17 pm Hi,
>> ENGLISH <<
Salamandra, Brazil
- srvet_claudio
I believe that in practice memory consumption is not a problem, just use a timer with a Release Memory. I never had problems with this topic, maybe other unicode users can give you a better point of view.
- salamandra
Hi Dr Claudio,
I´ll try. Thank you anyway.
Salamandra, Brazil
srvet_claudio wrote: ↑Thu Jul 02, 2020 8:53 pm Hi,
Salamandra, Brazil
Hi Dr Claudio,
Thank you answer.
huiyi
Thank you answer.
huiyi
