firmar XML
IMATECH
Re: firmar XML
Post by IMATECH »
Here you con find the code to sign a XML file using MS Capicom
https://github.com/JoseQuintas/sefazcla ... assina.prg
M., Ronaldo
By: IMATECH
Imation Tecnologia
edufloriv
Re: firmar XML
Post by edufloriv »
Hola IMATECH,
Puse a prueba el código que gentilmente me pasaste, desafortunadamente se queda en la siguiente línea:
   BEGIN SEQUENCE WITH __BreakBlock()
      cRetorno := "Erro Assinatura: Não carregado MSXML2.MXDigitalSignature.5.0"  //<--- ME LANZA ESTE ERROR
#ifdef __XHARBOUR__
      xmldsig := xhb_CreateObject( "MSXML2.MXDigitalSignature.5.0" )
#else
      xmldsig := win_OleCreateObject( "MSXML2.MXDigitalSignature.5.0" )
#endif
Parece que el problema es una incompatibilidad con Win-10
http://pctoledo.com.br/forum/viewtopic ... &start=15
¿ Hay forma de resolverlo ? - Mil gracias por su valioso tiempo.
Hi IMATECH,
I tested the code you graciously passed me, unfortunately it stays on the following line:
      cRetorno := "Erro Assinatura: Não carregado MSXML2.MXDigitalSignature.5.0"  //<--- THROW ME THIS ERROR
#ifdef __XHARBOUR__
#else
#endif
It seems that the problem is an incompatibility with Win-10
Is there a way to solve it? - Thank you for your valuable time.
Eduardo Flores Rivas
LIMA - PERU
IMATECH
Re: firmar XML
Post by IMATECH »
HI Eduardo !
Looks you don't have "Microsoft XML Core Services 5.0" in your machine (it's part of MS Office 2003)
Are you using "File based Key" or "USB Token" ?
*The sign process can use Open SSL or WinCrypt (no MS Office needed)
MSXML 5.0 MSXML5 is a binary developed specifically for Microsoft Office. It originally shipped with Office 2003 and also ships with Office 2007. Microsoft has not released documentation for this version because Microsoft considers MSXML 5 an internal/integrated component of Office 2003. MSXML 5 is not included in Office 2010.
M., Ronaldo
By: IMATECH
Imation Tecnologia
edufloriv
Re: firmar XML
Post by edufloriv »
Hi Imatech,
I am using file based key, I have got : .CRT, .KEY, .PEM and .PFX files, I have tried with all these formats without result.
I have OpenSSL instaled on my computer. I must sign all the .XML file and these must be the result:
XML before sign:
<ext:UBLExtensions>
    <ext:UBLExtension>
        <ext:ExtensionContent></ext:ExtensionContent>
    </ext:UBLExtension>
</ext:UBLExtensions>
XML after sign:
<ext:UBLExtensions>
    <ext:UBLExtension>
            <ds:Signature Id="SignIMM">
                <ds:SignedInfo>
                    <ds:CanonicalizationMethod Algorithm="http://www.w3.org/TR/2001/REC-xml-c14n-20010315"/>
                    <ds:SignatureMethod Algorithm="http://www.w3.org/2000/09/xmldsig#rsa-sha1"/>
                    <ds:Reference URI="">
                    <ds:Transforms>
                        <ds:Transform Algorithm="http://www.w3.org/2000/09/xmldsig#enveloped-signature"/>
                    </ds:Transforms>
                    <ds:DigestMethod Algorithm="http://www.w3.org/2000/09/xmldsig#sha1"/>
                    <ds:DigestValue>IwJuNQGQaHmmm3iv2jj8JDv70Ow=</ds:DigestValue>
                    </ds:Reference>
                </ds:SignedInfo>
                <ds:SignatureValue>
                nLaghokzMNrmrfPnbIg9b........wzZ2CgLTVjWQUAQ4wDAYDVQQIEwVNYWluZTE1UiLFwZXXXPUlf2o=
                </ds:SignatureValue>
                <ds:KeyInfo>
                    <ds:X509Data>
                        <ds:X509Certificate>
MIIFhzCCA3OgAwI......MIIEVDCCAzygAwIBAgIJAPTrkMJbCOr1MA0GCSqGSIb3DQEBBQUAMHkxCzAJBgNVBAYTAlVTVQQIEwVNYWluZTEgMOiRJ00nE=
                        </ds:X509Certificate>
                    </ds:X509Data>
                </ds:KeyInfo>
            </ds:Signature>
    </ext:UBLExtension>
I would apreciate your help.
LIMA - PERU
IMATECH
Re: firmar XML
Post by IMATECH »
HI Eduardo !
Can you install it and make the test again ?
1) ..\SefazClass\hbMk2 sefazclass
2)..\SefazClass\tests\hbMk2 Test -hbwin
3)..\SefazClass\tests\Test.exe
3.1) Option 2 - Seleciona certificado (Select Cert Key)
3.2) Option 18 - Assinatura, arquivo do usuário (Sing a XML)
3.2.1) Select a XML file then you will have a signed one (*changes needed below)
To save XML signed, file test.prg, line 341~
      CASE nOpc == OPC_ASSINA_USUARIO
         oSefaz:cXmlDocumento := MemoRead( win_GetOpenFileName(, "Choose a XML file to sign", ".\", "XML", "*.XML", 1 ) )
         oSefaz:AssinaXml()
         hb_MemoWrit( "Respuesta.txt", oSefaz:cXmlRetorno )
         hb_MemoWrit( "SignedFile.xml", oSefaz:cXmlDocumento )
         Inkey(0)
tests.7z
sample files
(2.55 KiB) Downloaded 252 times
M., Ronaldo
By: IMATECH
Imation Tecnologia
