mssql server 2012 express
jairpinho
Re: mssql server 2012 express
Post by jairpinho »
jorge.posadas wrote: Wed Apr 17, 2019 3:11 pm jairpinho
This an example I hope help you
Gracias Jorge, funcionó perfectamente sin odbc conexión nativa sigue el ejemplo para todos. espero recibir más ejemplos para otros tipos de conexión rdd o odbc para dejar como exeomplo para el grupo
english
Thanks Jorge, worked perfectly without odbc native connection follows example for all. I hope to receive more examples for other types of connection rdd or odbc to leave as exeomplo for the group
AD0_NATIVE.zip
(1.49 MiB) Downloaded 338 times
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Tiger
Post by Tiger »
Hi jairpinho,
Thanks for your sample "AD0_NATIVE.zip ", it helps me to connect to the MSSQL now. And I just wonder how to export the query result to excel file. Can anyone guide me to do it? I try to search the form but I can't get it.
Tiger
Tiger wrote: Wed Sep 04, 2019 3:50 am And I just wonder how to export the query result to excel file. Can anyone guide me to do it? I
there is a Excel Demo in c:\hmg.3.4.4\SAMPLES\Controls\OLE\demo.prg
create a empty worksheet and pass hole Array like this
PROCEDURE Excel(aData)
LOCAL oExcel, oHoja
   oExcel := CreateObject( "Excel.Application" )
   oExcel:WorkBooks:Add()
   oHoja := oExcel:ActiveSheet()
   // fill Sheet with Array
   oHoja:value := aData
Tiger
Post by Tiger »
AUGE_OHR wrote: Wed Sep 04, 2019 9:45 pm hi,
LOCAL oExcel, oHoja
Thank for the hint, I will try this way.
Hi!
I want to reftresh this topic.
I'm trying to rebuild my application, but, it doesn't want to connect to MSSQL server
My connection string:
cConStr := "Driver={SQL Server};"+;
"Server=" + cSQLSerwer + ";"+;
"Database="+ cSQLBaza + ";"+;
"Trusted_Connection=yes" + ";"+;
"Integrated Security=SSPI;" +;
"Uid=" + cSQLUser+ ";"+;
"Pwd="+ cSQLPassword +";"
lOK := hb_RDDINFO( RDDI_CONNECT, { "ODBC", cConStr })
lOK should be 0 if not connected and <> 0 if connected.
But, I'm getting an array as a result, containing exactly what I pass to RDDINFO - { "ODBC", cConStr }
Do you have any idea what can be wrong?
Any other ways to connect to mssql server?
jparada
Post by jparada »
try ADO, small example:
IF ( oConnection := win_OleCreateObject( "ADODB.Connection" ) ) == NIL
    ? "No es posible crear objeto conexión", win_OleErrorText()
  BEGIN SEQUENCE WITH {|oError| BREAK( oError ) }
    oConnection:Open("Provider=SQLNCLI11;Server=SERVERNAME\INSTANCENAME;Database=DBNAME;Uid=USER;Pwd=PASS;" )
  RECOVER USING oError
    ? "Error al intentar conectar a la base de datos " +  E"\n" + hb_Utf8ToStr(oError:Description)
  END SEQUENCE
  oRs := win_OleCreateObject( "ADODB.Recordset" )
  cQry1 := "SELECT TOP 5 ccodigoagente AS Agente, cnombreagente AS Nombre FROM admAgentes"
    oRs:Open(cQry1, oConnection)
    ? "Error al realizar la consulta " +  E"\n" + hb_Utf8ToStr(oError:Description)
  END SEQUENCE
  oRs:MoveFirst()
  Do While !oRs:Eof()
    AADD( aData , { oRs:Fields( "Nombre" ):Value, oRs:Fields( "Agente" ):Value  } )
    oRs:MoveNext()
  ENDDO
  oRs:Close()
  oConnection:Close()
Javier
Thank you! I'll try this. How about speed?
jparada
Post by jparada »
Compared against what?, anyway, I have no comparison parameter, since I personally have not used any other connection method, I only use ADO.
Javier
As I understand well, in ADO, when I get data from serwer, I must put it into table or .dbf file.
Using SQLMIX, I'm getting data into temporary table. There is a minimal change to old code to use this way of using sql server.
Am I wrong?
