IP Publica
Re: IP Publica
andyglezl wrote: Fri Nov 12, 2021 4:54 am Did you include the MainIPPub.hbp file?
I tried it a while ago and it worked.
thx for Answer.
i have assign *.HBP to IDE (Unicode) so i "just" dblclick on *.HBP and press F5
C:\hmg.3.4.4\IDE\IDE.exe "%1"
IHMO inside *.HBP is "only" MainIPPub.prg and *.HBC is empty
what do i miss :idea:
Re: IP Publica
Lo siento, yo nunca he utilizado el IDE...
Simplemente compilo así: G:\MiApp> C:\HMG\3.4.4\Build MainIPPub
Sorry, I've never used the IDE ...
I just compile like this: G:\MiApp> C:\HMG\3.4.4\Build MainIPPub
Re: IP Publica
have open CMD box and type
..\..\build MainIPPub.hbp
but i still got Error ( now with "W@20" )
Harbour 3.2.0dev (r1703241902)
R:/Temp/hbmk_0joemu.dir/MainIPPub.o:MainIPPub.c:(.text+0xaa): undefined reference to `URLDownloadToFileW@20'
hbmk2[MainIPPub]: Error: Running linker. 1
gcc.exe R:/Temp/hbmk_0joemu.dir/MainIPPub.o R:/Temp/hbmk_0joemu.dir/hbmk_xesgsy.o c:/hmg.3.4.4/0/IPPUBLIC/_temp.o -pthread -static-libgcc -static-libstdc++ -static -lpthread -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbmysql -lmysql -lhbfimage -lhbpgsql -lsddmy -lhbvpdf -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhbssl -llibeay32 -lssleay32 -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -oMainIPPub.exe -Lc:/hmg.3.4.4/harbour/lib/win/mingw -Lc:/hmg.3.4.4/lib
hm ... which Version do you use : HMG 3.4.4 or 3.5 :?:
Re: IP Publica
Tengo HMG 3.4.4
:? mmmmm... Quizá
In C:\HMG\3.4.4\ existe el "hmg32.hbc", tiene est´s Libs ?
I have HMG 3.4.4
:? mmmmm ... Maybe
In C:\HMG\3.4.4\ there is the "hmg32.hbc", do you have these Libs?
Re: IP Publica
AUGE_OHR wrote: Fri Nov 12, 2021 11:55 pm hi,
I think You need urlmon lib, try to add "-lurlmon" into MainIPPub.hbp
#harbour options:
-w3
#hbmk2 options:
-lurlmon
#sources:
MainIPPub.prg
Re: IP Publica
edk wrote: Sat Nov 13, 2021 3:21 am I think You need urlmon lib, try to add "-lurlmon" into MainIPPub.hbp
#harbour options:
-w3
#hbmk2 options:
-lurlmon
#sources:
MainIPPub.prg
YES :D
after add it that Way it work for me
but i´m confused about Syntax
i do use Libs= and LibPath= in *.HBC
"where" does (lib)urlmon(.a) come from ?
THX, Jimmy
Re: IP Publica
AUGE_OHR wrote: Sat Nov 13, 2021 5:27 am YES :D
THX, Jimmy
I think when you use the IDE the library entries in the .hbp file are ignored. So they must be declared in .hbc, try this .hbc:
libs=urlmon
On the other hand, if you want to batch compile via build.bat then you have to declare the libraries in .hbp or specify it on the command line, or if you use .hbc then this .hbc file is also given on the command line.
Examples:
1. When .hbp contains references to a library:
#hbmk2 options:
-lurlmon
#sources:
ImageFromWeb.prg
build.bat ImageFromWeb.hbp
2. When the .hbp does not contain a reference to the library, the .hbc file is missing.
build.bat ImageFromWeb.hbp -lurlmon
3. When .hbp does not contain references to the library, but in the .hbc file they are declared.
build.bat ImageFromWeb.hbp ImageFromWeb.hbc
(lib)urlmon(.a) come from "C:\hmg.3.4.4\MINGW\i686-w64-mingw32\lib\liburlmon.a"
