mouseover label
Re: mouseover label
KDJ wrote: Sun Jun 10, 2018 4:36 pm Grigory
Why WM_MOUSELEAVE in HMG Extended works and in classic HMG doesn't work?
Krzysztof
IMHO Because HMG Extended uses a Label subclassing on C-level 8-)
KDJ
Re: mouseover label
Post by KDJ »
Grigory, thank you very much for your explanation.
koke
DBs Used: DBF, mySql, mariaDB
Re: mouseover label
Post by koke »
Gracias a todos han sido de mucha ayuda.
Google translate
Thank you all, you have been very helpful.
,___,
[O.o]
/)__)
KoKe
KDJ
Re: mouseover label
Post by KDJ »
gfilatov wrote: Sun Jun 10, 2018 4:50 pm
Krzysztof
Grigory
I solved this problem.
Before that I completely forgot about the function EventProcessAllHookMessage().
WM_MOUSELEAVE works also in classic HMG:
MEMVAR _HMG_SYSDATA
FUNCTION Main()
  DEFINE WINDOW MainForm;
    WIDTH  300;
    HEIGHT 260;
    TITLE  "Move cursor over labels";
    MAIN
    DEFINE LABEL Label1
      ROW       10
      COL       10
      WIDTH     140
      HEIGHT    45
      VALUE     "This is LABEL1"
      ALIGNMENT Center
      FONTCOLOR BLACK
    END LABEL
    DEFINE LABEL Label2
      ROW       65
      COL       10
      WIDTH     140
      HEIGHT    45
      VALUE     "This is LABEL2"
      ALIGNMENT Center
      FONTCOLOR BLACK
    END LABEL
    DEFINE LABEL Label3
      ROW       120
      COL       10
      WIDTH     140
      HEIGHT    45
      VALUE     "This is LABEL3"
      ALIGNMENT Center
      FONTCOLOR BLACK
    END LABEL
    DEFINE BUTTON CloseButton
      ROW     190
      COL     10
      WIDTH   80
      HEIGHT  23
      CAPTION "Close"
      ACTION  MainForm.RELEASE
    END BUTTON
  HMG_ChangeWindowStyle(MainForm.Label1.HANDLE, 0x00800200 /*WS_BORDER|SS_CENTERIMAGE*/, NIL, .F., .T.)
  HMG_ChangeWindowStyle(MainForm.Label2.HANDLE, 0x00800200 /*WS_BORDER|SS_CENTERIMAGE*/, NIL, .F., .T.)
  HMG_ChangeWindowStyle(MainForm.Label3.HANDLE, 0x00800200 /*WS_BORDER|SS_CENTERIMAGE*/, NIL, .F., .T.)
  EventProcessAllHookMessage(EventCreate("LabelEventHandler", MainForm.Label1.HANDLE), .T.)
  EventProcessAllHookMessage(EventCreate("LabelEventHandler", MainForm.Label2.HANDLE), .T.)
  EventProcessAllHookMessage(EventCreate("LabelEventHandler", MainForm.Label3.HANDLE), .T.)
  MainForm.CENTER
  MainForm.ACTIVATE
FUNCTION LabelEventHandler()
  STATIC lTracking := .F.
  LOCAL  nHWnd := EventHWND()
  LOCAL  nMsg  := EventMSG()
  LOCAL  cControl
  LOCAL  cForm
  SWITCH nMsg
    CASE WM_MOUSEMOVE
      IF ! lTracking
        GetControlNameByHandle(nHWnd, @cControl, @cForm)
        SetProperty(cForm, cControl, "FONTCOLOR", RED)
        SetProperty(cForm, cControl, "FONTBOLD", .T.)
        lTracking := TrackMouseEvent(nHWnd) //TME_LEAVE is default flag
      EXIT
    CASE WM_MOUSELEAVE
      SetProperty(cForm, cControl, "FONTCOLOR", BLACK)
      SetProperty(cForm, cControl, "FONTBOLD", .F.)
      lTracking := .F.
      EXIT
  ENDSWITCH
#pragma BEGINDUMP
#include "HMG_UNICODE.h"
#include <windows.h>
#include "hbapi.h"
      // https://msdn.microsoft.com/en-us/library/windows/desktop/ms646265(v=vs.85).aspx
      // TrackMouseEvent(nHWnd, [nFlags], [nHoverTime]) --> lSuccess
HB_FUNC( TRACKMOUSEEVENT )
  TRACKMOUSEEVENT tmi;
  tmi.cbSize      = sizeof(TRACKMOUSEEVENT);
  tmi.dwFlags     = HB_ISNUM(3) ? (DWORD) hb_parni(2) : TME_LEAVE;
  tmi.hwndTrack   = (HWND) HMG_parnl(1);
  tmi.dwHoverTime = HB_ISNUM(3) ? (DWORD) hb_parni(3) : HOVER_DEFAULT;
  hb_retl(TrackMouseEvent(&tmi));
#pragma ENDDUMP
Re: mouseover label
Hi Krzysztof!
Your sample works fine till application has focus.
When I switched to another application and return to Label Test, onMouseEvent stopped to work :-(
When I leave mouse cursor over label - it becomes RED - I'm switching by Alt-Tab to another application and return to Test - label stays RED and another label does not react with mouse overlapping.
When I leave mouse cursor outside label and swith by Alt-Tab and return to Test - everything looks OK.
Re: mouseover label
This is my little sample, can you test it?
// OnMouseHover demo
// 2016.06.20 Marek Olszewski
	private aLabelColors := { => }
	aLabelColors [ "KAFEL1" ] := {100,100,100}
	aLabelColors [ "KAFEL2" ] := {100,200,0}
	aLabelColors [ "KAFEL3" ] := {0,200,200}
	// turn off case sensitive hash keys matching
	hb_HCaseMatch(aLabelColors, .F.)
	DEFINE WINDOW Form_Main ;
		WIDTH 640 HEIGHT 600 ;
		TITLE 'Main Window' ;
		MAIN
		@ 60,10 LABEL KAFEL1 ;
			WIDTH 200 HEIGHT 200 ;
			VALUE "OPTION 1";
			BACKCOLOR aLabelColors [ "KAFEL1" ];
			CENTERALIGN
		@ 60,220 LABEL KAFEL2 ;
			VALUE "OPTION 2";
			BACKCOLOR aLabelColors [ "KAFEL2" ];
			CENTERALIGN
		@ 270,220 LABEL KAFEL3 ;
			VALUE "OPTION 3";
			BACKCOLOR aLabelColors [ "KAFEL3" ];
			CENTERALIGN
		@ 270,10 LABEL KAFEL4 ;
			VALUE "STATIC OPTION NOT COLORIZED";
			BACKCOLOR {255,255,255};
			CENTERALIGN
	CENTER WINDOW Form_Main
	CREATE EVENT PROCNAME OnMouseHover( EventWPARAM(), "FORM_MAIN" )  HWND Form_Main.Handle
	ACTIVATE WINDOW Form_Main
function OnMouseHover
	param hWnd, cFormName
	LOCAL cControl := ""
	LOCAL cForm := ""
	static cPrevious := ""
	GetControlNameByHandle( hWnd, @cControl, @cForm )
	if empty(cControl)
		if !empty(cPrevious)
			// set oryginal color to previous control
			SetProperty(cFormName, cPrevious, "BackColor",aLabelColors [ cPrevious ])
			//to prevent flickering
			cPrevious := ""
			return
	// to avoid errors - eliminate changes for absent controls in aLabelColors array
	if HB_HPOS( aLabelColors,  cControl) == 0
		return
		// to avoid flickering
		if !(cControl == cPrevious)
	SetProperty(cForm, cControl, "BackColor",{255,255,0})
	cPrevious := cControl
return
Re: mouseover label
Hace tiempo hice algo parecido...
El ejemplo completo se encuentra aquí.
viewtopic.php?f=6&t=4468&p=42585&hilit= ... enu#p42585
Some time ago I did something similar ...
The complete example is here.
FUNCTION SelCtrl( wParam )
	LOCAL cCtrl, cForm, cCtrlPso := "", nOpc := 0
	GetControlNameByHandle( wParam, @cCtrl, @cForm )
	cForm := ALLTRIM( cForm )
	cCtrl := ALLTRIM( cCtrl )
	IF "LB_A" $ cCtrl
		nOpc := ASCAN( aActi, "Y" )
		IF nOpc > 0
			cCtrlPso := "LB_A"+STRZERO( nOpc, 2 )
			FormMain.&cCtrlPso..BACKCOLOR := { 210, 233, 255 }
			FormMain.&cCtrlPso..FONTCOLOR := BLACK
			aActi[ nOpc ] := "N"
		FormMain.&cCtrl..BACKCOLOR := { 0, 191, 255 }
		FormMain.&cCtrl..FONTCOLOR := YELLOW
		aActi[ VAL( SUBSTR( cCtrl, 5, 2 ) ) ] := "Y"
RETURN Nil
KDJ
Re: mouseover label
Post by KDJ »
mol wrote: Thu Jun 21, 2018 4:55 am Hi Krzysztof!
Maybe in this way it will be good:
MEMVAR _HMG_SYSDATA
FUNCTION Main()
    WIDTH  300;
    HEIGHT 260;
    MAIN;
    ON GOTFOCUS MainFormOnGotFocus()
    DEFINE LABEL Label1
      ROW       10
      COL       10
      WIDTH     140
      HEIGHT    45
      ALIGNMENT Center
      FONTCOLOR BLACK
    END LABEL
    DEFINE LABEL Label2
      ROW       65
      COL       10
      WIDTH     140
      HEIGHT    45
      ALIGNMENT Center
      FONTCOLOR BLACK
    END LABEL
    DEFINE LABEL Label3
      ROW       120
      COL       10
      WIDTH     140
      HEIGHT    45
      ALIGNMENT Center
      FONTCOLOR BLACK
    END LABEL
      ROW     190
      COL     10
      WIDTH   80
      HEIGHT  23
      CAPTION "Close"
    END BUTTON
  MainForm.CENTER
  MainForm.ACTIVATE
FUNCTION MainFormOnGotFocus()
  PostMessage(MainForm.Label1.HANDLE, WM_MOUSELEAVE, 0, 0)
  PostMessage(MainForm.Label2.HANDLE, WM_MOUSELEAVE, 0, 0)
  PostMessage(MainForm.Label3.HANDLE, WM_MOUSELEAVE, 0, 0)
FUNCTION LabelEventHandler(cParam)
  LOCAL  cControl
  LOCAL  cForm
  SWITCH nMsg
    CASE WM_MOUSEMOVE
      IF ! lTracking
      EXIT
    CASE WM_MOUSELEAVE
      lTracking := .F.
      EXIT
  ENDSWITCH
#pragma BEGINDUMP
#include "hbapi.h"
  tmi.dwFlags     = hb_parnidef(2, TME_LEAVE);
  tmi.dwHoverTime = hb_parnidef(3, HOVER_DEFAULT);
#pragma ENDDUMP
mol wrote: Thu Jun 21, 2018 5:37 am This is my little sample, can you test it?
Yes, I have tested your example.
It uses WM_SETCURSOR to determine the cursor location, although this is not explicitly written in the code.
It works fine, but if you place the cursor on the label "OPTON 1" and then quickly move the cursor to the left outside the main window - the color of this label will not change, it will remain yellow.
Re: mouseover label
Sucha a interface with labels looks like webside and it's very fine.
The only one problem is that the label can't get focus and it's not possible to interact with keyboard (some people still want to work in this way :-D)
