Partial clear screen
asharpham
Re: Partial clear screen
Post by asharpham »
Thanks Rathinagiri. Before sending the entire code I'll show you where this is called from. If you can't work it out from here, I'm happy to zip up the entire code and files.
The code calling the procedure is:
DEFINE TOOLBAR ToolBar_2 BUTTONSIZE 150,35 FLAT BORDER BOTTOM
BUTTON SEARCH ;
CAPTION '&Search' ;
PICTURE 'IconSearch.bmp' ;
ACTION { SeekText() , Library_1.Seek1.SetFocus , Refresh() }
This is followed by:
PROCEDURE SeekText
IF IsControlDefined ( 'LABEL_Search' , 'Library_1' )
DoMethod ( 'Library_1' , 'LABEL_Search' , 'Release' )
IF IsControlDefined ( 'Seek1' , 'Library_1' )
DoMethod ( 'Library_1' , 'Seek1' , 'Release' )
IF IsControlDefined ( 'SeekButton' , 'Library_1' )
DoMethod ( 'Library_1' , 'SeekButton' , 'Release' )
IF IsControlDefined ( 'Quit' , 'Library_1' )
DoMethod ( 'Library_1' , 'Quit' , 'Release' )
DEFINE BUTTON SeekButton
PARENT Library_1
ROW 400
COL 200
WIDTH 100
HEIGHT 50
ONCLICK { Library_1.Seek1.SetFocus , SeekRecord() }
END BUTTON
DEFINE BUTTON QuitSearch
PARENT Library_1
ROW 400
COL 300
WIDTH 100
HEIGHT 50
PICTURE 'IconExit.bmp'
ONCLICK { 'HideButtons()' , 'RETURN' }
END BUTTON
DEFINE LABEL LABEL_Search
PARENT Library_1
ROW 350
COL 130
VALUE 'Track Title:'
FONTBOLD .T.
END LABEL
@ 350,250 Textbox Seek1 ;
PARENT Library_1 ;
WIDTH 200
And then:
PROCEDURE HideButtons
Library_1.SeekButton.Visible := .F.
Library_1.QuitSearch.Visible := .F.
Library_1.Seek1.Release
While you're looking at this code, perhaps I can ask you a question I've posted elsewhere becaue it relates to this code as well. Is it possible to centre the text under the image in the Toolbar button? At present the text is lower and right of the icon.
Alan
By this code, you are passing only an array and not procedure.
You have to enter like this.
onclick HideButtons()
'Return' is not required.
I request you to go through this topic also.
viewtopic.php?f=6&t=3905
asharpham
Post by asharpham »
This has been very informative, Rathingiri. Thank you again.
tonton2
Post by tonton2 »
Bonjour tout le monde ,
je ne sais pas pourquoi la fonction "VISIBLE" ne fonctionne pas dans cet exemple ,alors que la fonction "ENABLED" fonctionne normallement.
merci beaucoup pour votre aide
traduction google
Hello everyone ,
I do not know why the "VISIBLE" function does not work in this example, while the "ENABLED" function works normally.
thank's all
MENU_Dynamic_Demo.rar
(10.83 KiB) Downloaded 277 times
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
