Variables and Definition Errors
Re: Variables and Definition Errors
Hi Alan, take a look at DATA_BOUND in the samples, the screenshot shows the path in your installation-folder. I fancy you could use it for your app.
- databound.png (920.9 KiB) Viewed 5039 times
Hi Alan,
Looks good. 1 type LIBRARY->ART_NO instead of LIBRARY->ARTNO + cAlbumRef.
It seems you are on your way !
- dragancesu
First: check LIBRARY.dbf structure and field name (artno or art_no), indexing field ref, not in structure
MISTAKE: IF cTitle := ""
CORRECT: IF cTitle = ""
But, generaly not good practice
LOCAL cTitle := ""
and
@ 200,400 TEXTBOX cTitle
use different name,
when work with TEXTBOX cTitle than IF WindowName.cTitle.Value = "aaa"...
LOCAL cTitle := ""
and
use different name,
Thanks so much for your input. I'm just curious about the use of := instead of =. I don't quite understand the purpose of := and I didn't use it in my Clipper programming years ago.
The DATA_BOUND sample looks very helpful. But there's a couple of things it doesn't tell me which someone may be able to assist me on. In the DATA_BOUND example, how would you do a Search for a specific record (as opposed to scrolling through them all to find it) and how to add a new record. Nerither of these are included in DATA_BOUND.
However, I think I have enough to continue from here and probably simplify my program somewhat.
Alan
Alan
Hola asharpham
From the outset, your program showed me the following error message
Hice algunas correcciones a tu programa para hacerlo funcional
los comentarios vienen dentro del programa
I made some corrections to your program to make it functional
the comments come within the program
De entrada, me desplegó los siguientes mensaje de errorThis program is unfinished so not all of the menu buttons work. It loads the main menu and loads "Add New Music" but none of the other menu items work, as well as the 3 buttons at the bottom. Some of the labels aren't displaying properly either but I know I can fix that as I work on it.
/* MUSIC LIBRARY MAIN MENU
by Alan Sharpham
2018 Revision from "The Schedule"
Version 1.0
#INCLUDE "hmg.ch"
#INCLUDE "inkey.ch"
FUNCTION Main()
PUBLIC nFontSize:=12
PUBLIC nHeaderLength:=0
PUBLIC nColumn,cHeader
PUBLIC nLastRecNumber:=0
PUBLIC nNewRecNo:=0, NewRec:=.T.
SET DATE BRITISH
SET CENTURY ON
SET NAVIGATION EXTENDED
*set procedure to open_dbf
*set procedure to open_ntx
if ! file ("LIBRARY.dbf") // <=======================
alist_fld := {}
aadd(alist_fld,{"TRACKNUM","N",4,0})
aadd(alist_fld,{"ALBUM_NO","C",6,0})
aadd(alist_fld,{"ALBUM_TITL","C",40,0})
aadd(alist_fld,{"TITLE","C",33,0})
aadd(alist_fld,{"ARTIST","C",40,0})
aadd(alist_fld,{"ART_NO","N",4,0})
aadd(alist_fld,{"TRACK","N",2,0})
aadd(alist_fld,{"DUR","C",5,0})
aadd(alist_fld,{"YR","C",2,0})
aadd(alist_fld,{"FILENAME","C",8,0})
dbcreate("LIBRARY",alist_fld)
USE library NEW
IF LASTREC() = 0
DBAPPEND() // <======================= At least there must be a record to create the indices
//LIBRARY->RECORD := "" // <======================= There is no RECORD field in the DB
//LIBRARY->REF := "" // <======================= There is no REF field in the DB
LIBRARY->TITLE := ""
LIBRARY->ARTIST := ""
//LIBRARY->ARTNO := 0 // <======================= There is no ARTNO field in the DB
LIBRARY->ART_NO := 0
LIBRARY->TRACK := 0
LIBRARY->DUR := ""
LIBRARY->YR := "" // <======================= There is no YEAR field in the DB
if ! file ("iTITLE.ntx")
index on TITLE to iTITLE
if ! file ("iARTIST.ntx")
index on ARTIST to iARTIST
if ! file ("iARTNO.ntx")
//index on ARTNO to iARTNO // <======================= There is no ARTNO field in the DB
index on ART_NO to iARTNO
//if ! file ("iALBUMREF.ntx") // <======================= There is no REF field in the DB
// index on REF to iALBUMREF
//endif
if ! file ("iFILENAME.ntx")
index on FILENAME to iFILENAME
endif // <=======================
//SET INDEX TO iTITLE,iARTIST,iARTNO,iALBUMREF,iFILENAME // <======================== From here you can open all the indices
SET INDEX TO iTITLE,iARTIST,iARTNO,iFILENAME // <======================== There is no REF field in the DB and not indice
nLastRecNumber := LASTREC()
cHeader := "My Music Library"
nHeaderLength := LEN(cHeader)
DEFINE WINDOW Library_1 ;
WIDTH 800 ;
; //HEIGHT 800 ; // <================== My monitor is smaller
HEIGHT 700 ;
TITLE "My Music Library" ;
NOSIZE ;
NOMAXIMIZE ;
ICON "CloudsIcon.jpg" ;
BACKCOLOR {231,255,249} ; // Light green
MAIN
DEFINE LABEL Heading
ROW 10
COL 290
AUTOSIZE .T.
VALUE cHeader
nFontSize := 24
FONTNAME "Van Dijk"
FONTSIZE nFontSize
FONTCOLOR {102,51,0}
FONTBOLD .T.
TRANSPARENT .T.
END LABEL
DEFINE LABEL Date
ROW 60
COL 370
AUTOSIZE .T.
VALUE DTOC(Date())
FONTNAME "Arial"
FONTSIZE 12
FONTBOLD .T.
TRANSPARENT .T.
END LABEL
DEFINE BUTTON AddButton
ROW 100
COL 310
CAPTION " Add New Music "
TOOLTIP "Click to add a new album"
WIDTH 200
HEIGHT 50
TRANSPARENT .T.
ACTION ENTER()
END BUTTON
DEFINE BUTTON EditButton
ROW 200
COL 310
CAPTION " Edit Tracks / Albums "
TOOLTIP "Click to edit tracks or albums"
WIDTH 200
HEIGHT 50
ACTION MUSICED()
END BUTTON
DEFINE BUTTON DeleteButton
ROW 300
COL 310
CAPTION "Delete Tracks / Albums"
TOOLTIP "Click to delete tracks or albums"
WIDTH 200
HEIGHT 50
ACTION DELETEmusic()
END BUTTON
DEFINE BUTTON DisplayButton
ROW 400
COL 310
CAPTION " Display Menu "
TOOLTIP "Click for display menu"
WIDTH 200
HEIGHT 50
ACTION DISPLAY()
END BUTTON
DEFINE BUTTON PrintButton
ROW 500
COL 310
CAPTION " Print Menu "
TOOLTIP "Click for print menu"
WIDTH 200
HEIGHT 50
ACTION PRINTmenu()
END BUTTON
DEFINE BUTTON ExitButton
ROW 600
COL 310
CAPTION " Quit "
TOOLTIP "Click to Exit"
WIDTH 200
HEIGHT 50
ACTION Library_1.Release
END BUTTON
Library_1.CENTER
Library_1.ACTIVATE
Functions in Child_Windows
FUNCTION ENTER()
LOCAL cTitle := " "
LOCAL lAddRecords := .T.
LOCAL cArtist := ""
LOCAL nArtno := 0
LOCAL cAlbumTtl := ""
LOCAL cDura := ""
LOCAL nYear := 0
LOCAL cAlbumRef := ""
LOCAL cFileName := ""
DEFINE WINDOW Library_2 ;
; // WIDTH 1100 HEIGHT 1000 ; // <================== My monitor is smaller
WIDTH 1100 HEIGHT 700 ;
TITLE 'My Music Library - Add Menu' ;
NOSIZE ;
BACKCOLOR {247,226,223} ; // Light pink
CHILD
//IF Used() // <================== Why the question if from the beginning is already open ???
// SELECT Library
//ELSE
// USE Library NEW
//ENDIF
DEFINE LABEL AddHeading
PARENT Library_2
ROW 10
COL 370
AUTOSIZE .T.
VALUE cHeader
FONTNAME "Van Dijk"
FONTSIZE nFontSize
FONTBOLD .T.
TRANSPARENT .T.
END LABEL
DEFINE LABEL Add_SubHeading
PARENT Library_2
ROW 80
COL 400
AUTOSIZE .T.
VALUE "Add New Music"
FONTNAME "Arial"
FONTSIZE 20
FONTCOLOR {255,0,0}
FONTITALIC .T.
TRANSPARENT .T.
END LABEL
DEFINE LABEL Label_Add_1
PARENT Library_2
ROW 200
COL 200
VALUE "Track Title:"
FONTNAME "Arial"
FONTSIZE 16
FONTCOLOR {0,0,0}
TRANSPARENT .T.
END LABEL
DEFINE LABEL Label_Add_2
PARENT Library_2
ROW 250
COL 200
VALUE "Artist:"
FONTNAME "Arial"
FONTSIZE 16
FONTCOLOR {0,0,0}
TRANSPARENT .T.
END LABEL
DEFINE LABEL Label_Add_2a
PARENT Library_2
ROW 250
COL 630
VALUE "Artist Code: "+AllTrim(STR(nArtNo))
FONTNAME "Arial"
FONTSIZE 10
FONTCOLOR {0,0,0}
TRANSPARENT .T.
TOOLTIP "Artist Number"
END LABEL
DEFINE LABEL Label_Add_3
PARENT Library_2
ROW 300
COL 200
VALUE "Album No:"
FONTNAME "Arial"
FONTSIZE 16
FONTCOLOR {0,0,0}
TRANSPARENT .T.
END LABEL
DEFINE LABEL Label_Add_3a
PARENT Library_2
ROW 300
COL 630
WIDTH 500
VALUE "Type HD if on hard drive"
FONTNAME "Arial"
FONTSIZE 10
FONTCOLOR {255,0,0}
TRANSPARENT .T.
END LABEL
DEFINE LABEL Label_Add_4
PARENT Library_2
ROW 350
COL 200
VALUE "Album Title:"
FONTNAME "Arial"
FONTSIZE 16
FONTCOLOR {0,0,0}
TRANSPARENT .T.
END LABEL
DEFINE LABEL Label_Add_5
PARENT Library_2
ROW 400
COL 200
VALUE "Track No:"
FONTNAME "Arial"
FONTSIZE 16
FONTCOLOR {0,0,0}
TRANSPARENT .T.
END LABEL
DEFINE LABEL Label_Add_6
PARENT Library_2
ROW 450
COL 200
VALUE "Track Length:"
FONTNAME "Arial"
FONTSIZE 16
FONTCOLOR {0,0,0}
TRANSPARENT .T.
END LABEL
DEFINE LABEL Label_Add_7
PARENT Library_2
ROW 500
COL 200
VALUE "Year Produced:"
FONTNAME "Arial"
FONTSIZE 16
FONTCOLOR {0,0,0}
TRANSPARENT .T.
END LABEL
DEFINE LABEL Label_Add_8
PARENT Library_2
ROW 550
COL 200
VALUE "Track Filename:"
FONTNAME "Arial"
FONTSIZE 16
FONTCOLOR {0,0,0}
TRANSPARENT .T.
END LABEL
DEFINE LABEL Label_Add_8a
PARENT Library_2
ROW 550
COL 630
WIDTH 500
VALUE "Leave blank if not on hard drive"
FONTNAME "Arial"
FONTSIZE 10
FONTCOLOR {0,0,0}
TRANSPARENT .T.
END LABEL
DEFINE BUTTON AddNewEntry
PARENT Library_2
ROW 620
COL 200
WIDTH 100
HEIGHT 50
CAPTION "Add"
TRANSPARENT .T.
FONTCOLOR {0,0,0}
FONTSIZE 12
FONTBOLD .T.
ONCLICK AddEntry(cTitle,cArtist,cAlbumRef,cAlbumTtl,nTrack,cDura,nYear,nArtNo,cFileName)
END BUTTON
DEFINE BUTTON ClearEntry
PARENT Library_2
ROW 620
COL 400
WIDTH 100
HEIGHT 50
BACKCOLOR { 255,0,0 } // Red
CAPTION "Clear Entry"
FONTCOLOR {0,0,0}
FONTSIZE 12
FONTBOLD .T.
// ONCLICK ClearEntry(cTitle,cArtist,nArtNo)
END BUTTON
DEFINE BUTTON ExitWindow
PARENT Library_2
ROW 620
COL 600
WIDTH 100
HEIGHT 50
CAPTION "Exit"
FONTCOLOR {0,0,0}
FONTSIZE 12
FONTBOLD .T.
lAddRecords := .F.
ONCLICK Library_2.RELEASE // <======================= To exit this window
END BUTTON
//dbGoBottom() // <======================= Why go to the end if you are going to create a new one ???
//nArtno := LIBRARY->ARTNO
//cArtist := AllTrim(LIBRARY->ARTIST)
//cAlbumRef := AllTrim(LIBRARY->REF)
//nYear := LIBRARY->YEAR // <=======================
@ 200,400 TEXTBOX cTitle ; // Matches Label 1
PARENT Library_2 ;
WIDTH 200 ;
MAXLENGTH 33 ;
ON LOSTFOCUS IF( Empty( Library_2.cTitle.Value ), Library_2.cTitle.Setfocus, Nil ) // <======================= from here you can validate that cTitle contains a value
// <======================= it works when you press Enter or TAB not with the mouse
@ 250,400 TEXTBOX cArtist ; // Matches Label 2
PARENT Library_2 ;
WIDTH 200 ;
MAXLENGTH 40
@ 300,400 TEXTBOX cAlbumRef ; // Matches Label 3
PARENT Library_2 ;
WIDTH 200 ;
MAXLENGTH 6
@ 350,400 TEXTBOX cAlbumTtl ; // Matches Label 4
PARENT Library_2 ;
WIDTH 200 ;
MAXLENGTH 40
//IF Upper(AllTrim(cAlbumRef)) <> "HD"
nTrack := 0
@ 400,400 TEXTBOX nTrack ; // Matches Label 6
PARENT Library_2 ;
WIDTH 200 ;
MAXLENGTH 4
//ENDIF
@ 450,400 TEXTBOX cDura ; // Matches Label 7
PARENT Library_2 ;
WIDTH 200 ;
MAXLENGTH 5
@ 500,400 TEXTBOX nYear ; // Matches Label 8
PARENT Library_2 ;
WIDTH 200 ;
MAXLENGTH 4
@ 550,400 TEXTBOX cFileName ; // Matches Label 9
PARENT Library_2 ;
WIDTH 200 ;
MAXLENGTH 8
Library_2.CENTER
Library_2.Activate
//IF cTitle := "" <====================== I do not understand this
// RELEASE ALL
// RETURN
//ELSE
// AddEntry(cTitle,cArtist,cAlbumRef,nTrack,cDura,nYear,nArtNo,cFileName)
//ENDIF
FUNCTION AddEntry(cTitle,cArtist,cAlbumRef,nTrack,cDura,nYear,nArtNo,cFileName)
*IF cTitle := "" <=============== := is to assign a value, not to ask if it has that value
//IF cTitle = "" // <======================= Already validated from the moment of capture
// lAddRecords := .F.
// RETURN
//ENDIF
// SELECT Library // <================== Again, Why this if from the beginning is already open ???
// SET INDEX TO iTITLE,iARTIST,iARTNO,iALBUMREF,iFILENAME
dbAppend()
// FUNCTION AddEntry(cTitle,cArtist,cAlbumRef,nTrack,cDura,nYear,nArtNo,cFileName)
// <================ The values that you pass as parameters are the values that you assigned at the beginning of this function, you must use the value
// <================ which brings each TEXTBOX control that you defined
//LIBRARY->RECORD := LIBRARY->(RECNO())
//LIBRARY->REF := cAlbumRef
LIBRARY->TITLE := Library_2.cTitle.Value
LIBRARY->ARTIST := Library_2.cArtist.Value
//LIBRARY->ART_NO := Library_2.ArtNo.Value // <================= TEXTBOX NOT DEFINED
LIBRARY->TRACK := VAL( Library_2.nTrack.Value )
LIBRARY->DUR := Library_2.cDura.Value
LIBRARY->YR := Library_2.nYear.Value
//cAlbumRef := AllTrim(cAlbumRef)
//IF cAlbumRef := "HD"
// LIBRARY->FILENAME := cFILENAME
//ELSE
// LIBRARY->FILENAME := ""
//ENDIF
dbCommitall()
//SET INDEX TO // <================== Why disable indices ???
// ClearEntry(cTitle,Cfilename)
FUNCTION LastEntry(nYear,nArtNo,cArtist,cAlbumRef)
FUNCTION MUSICED()
DEFINE WINDOW Library_3 ;
WIDTH 1000 HEIGHT 1000 ;
TITLE 'My Music Library - Edit Menu' ;
BACKCOLOR {196,253,230} ;
CHILD
Library_3.CENTER
Library_3.Activate
FUNCTION DELETEmusic()
DEFINE WINDOW Library_4 ;
TITLE 'My Music Library - Delete Menu' ;
CHILD
Library_4.CENTER
Library_4.Activate
FUNCTION DISPLAY()
DEFINE WINDOW Library_5 ;
TITLE 'My Music Library - Display Menu' ;
BACKCOLOR {196,174,253} ;
CHILD
Library_5.CENTER
Library_5.Activate
FUNCTION PRINTmenu()
DEFINE WINDOW Library_6 ;
TITLE 'My Music Library - Print Menu' ;
BACKCOLOR {46,227,255} ;
CHILD
Library_6.CENTER
Library_6.Activate
Yes Andres, there is still a long way to go. I'm assessing the DATA_BOUND sample as an option to my code but there are some things written into my code because of future processes I'll be adding.
And the reason I disable the indexes after saving is because in the future I will need to set a different order for a different process. ART_NO is incorrect as I recreated the Database using ARTNO for the field. I seem to have fixed that since uploading the zip file.
Many thanks for your input,
Alan
Alan
- dragancesu
For the beginning, make the structure correct, then indexes
When you open a table open with indexes, if you want to keep the natural order of use SET ORDER TO 0
Look at the BROWSE and GRID commands, they are much more powerful than CLIPPER
Look at windows programs, show data and leave the user to work with them
This is your old concept, sometimes COBOL then old CLIPPER, try to make it more modern, and for commands it's easy, it's learned
Hi Alan, see the following sample from Data_Bound, I have changed it to match my needs (change an existing record and write the changes to dbf):
Regards from Bavaria.
Robert
local cPersnr
set navigation extended
use
DEFINE WINDOW form_chg ;
WIDTH 600 ;
HEIGHT 480 ;
TITLE 'Stammdaten Fahrer bearbeiten' ;
On Init OpenBBPERS() ;
ON RELEASE CloseBBPERS()
@ 50,10 LABEL LABEL_1 VALUE 'PERSNR:'
@ 50,80 Textbox Text_seek;
parent form_chg ;
width 40;
height 20;
value cPersnr;
font 'ARIAL' size 10 ;
inputmask "9999" on lostFocus seek_persnr()
DEFINE TOOLBAR ToolBar_1 BUTTONSIZE 100,20 FLAT RIGHTTEXT BORDER
BUTTON SAVE ;
CAPTION '&Speichern' ;
PICTURE 'save.bmp' ;
ACTION ( Save_chg() , Refresh() )
BUTTON QUIT ;
CAPTION '&Quit' ;
picture 'exit.bmp' ;
ACTION ( END() )
END TOOLBAR
@ 100,10 LABEL LABEL_2 VALUE 'VORNAME:'
@ 130,10 LABEL LABEL_3 VALUE 'NAME:'
@ 160,10 LABEL LABEL_4 VALUE 'STRASSE:'
@ 190,10 LABEL LABEL_5 VALUE 'PLZ:'
@ 220,10 LABEL LABEL_6 VALUE 'ORT:'
@ 250,10 LABEL LABEL_7 VALUE 'Wegzeit:'
@ 280,10 LABEL LABEL_8 VALUE 'STATUS:'
@ 100,200 TEXTBOX TEXT_2;
FIELD BBPERS->VNAME ;
MAXLENGTH 30
@ 130,200 TEXTBOX TEXT_3;
FIELD BBPERS->NAME ;
MAXLENGTH 30
@ 160,200 TEXTBOX TEXT_4;
FIELD BBPERS->STR ;
MAXLENGTH 30
@ 190,200 TEXTBOX TEXT_5 ;
FIELD BBPERS->plz ;
MAXLENGTH 30
@ 220,200 TEXTBOX TEXT_6 ;
FIELD BBPERS->ort ;
MAXLENGTH 1
@ 250,200 TEXTBOX TEXT_7 ;
numeric ;
FIELD BBPERS->wegzeit ;
// inputmask '999'
@ 280,200 TEXTBOX TEXT_8 ;
FIELD BBPERS->status ;
width 15 ;
MAXLENGTH 1
inputmask 'A'
form_chg.Text_seek.SetFocus
ACTIVATE WINDOW form_chg
Procedure Refresh
form_chg.TEXT_2.Refresh
form_chg.Text_3.Refresh
form_chg.TEXT_4.Refresh
form_chg.TEXT_5.Refresh
form_chg.TEXT_6.Refresh
form_chg.TEXT_7.Refresh
form_chg.TEXT_8.Refresh
// form_chg.Text_2.SetFocus
Procedure Save_chg
form_chg.TEXT_2.Save
form_chg.TEXT_3.Save
form_chg.TEXT_4.Save
form_chg.TEXT_5.Save
form_chg.TEXT_6.Save
form_chg.TEXT_7.Save
form_chg.TEXT_8.Save
form_chg.text_seek.SetFocus
MsgInfo ('SAVED')
procedure seek_persnr
select bbpers
seek form_chg.text_seek.value
if !found() .and. !empty(form_chg.text_seek.value)
MsgInfo( form_chg.text_seek.value+' nicht gefunden')
if empty(form_chg.text_seek.value)
// release window form_chg
if found()
nRecNr:=RecNo()
go nRecNr
refresh()
return
function end
use
return
Procedure CloseBBPERS
USE
Procedure OpenBBPERS
use bbpers alias bbpers new
index on persnr to persnr
returnRobert
Hi Alan
:= is "assign" and = is both assign and relational ( comparison ) operator ( further info )
and = operator has a goody: the compiler automatically detect, which you want do, assign or comparison ?
Note : := added to language syntax with CL 5 version )
Happy Clippering
Going back to the DATA_BOUND example, the line "Win_1.Add1.Refresh" where Win_1 is the Window name and "Add1" is the Textbox name (I've changed them for my purposes), am I correct in saying that "refresh" refreshes the value of the textbox? In each case the textbox refers to a database FIELD but I presume it doesn't save to the database at this point as these statements are followed by a series of .save statements.
So what are the "refresh" statements refreshing? And are the "save" statements saving to the database or do I still need to use "dbCommit()"?
A problem I am having with my edited version of DATA_BOUND which I've saved as "TestLib.prg" is that I want to include the ability to add new records. In doing this, I want to refresh the screen with mostly empty textboxes but keeping 2 of them the same as the last entry. This seems to work but when I mouse over the textboxes they revert to the previous (or top) entry. I have no "mouseover" commands anywhere in my code so I'm not sure why this is happening.
I'm uploading the TestLib file and including my database and index files so it can be run. I'm getting there but still need some direction and I appreciate all the help being given.
Alan
Alan
- TestLib.zip
- (4.43 KiB) Downloaded 262 times
