Communication via http
Re: Communication via http
Great Work Marek!
Also wiating to see it!
tonton2
Post by tonton2 »
bonsoir tout le monde
bravo et bon courage marek
NB: j'utilise pour Arduino le langage LADDER
L'Algerie vous salut
Y.TABET
nekbmm
DBs Used: DBF,SQLite
Post by nekbmm »
Here is the code waiting for http request. If I want to control lamp, I need to call computer running this app via internet browser or another app calling www site http://localhost:80/KOD?12345
#require "hbhttpd"
MEMVAR server, get, post, cookie, session
	public oServer
	public cAdresKontrolera := "http://192.168.20.190"
	SET LANGUAGE TO POLISH
	SET EPOCH TO 2000
	set century off
	set date ansi
	DEFINE WINDOW Form_1 ;
		WIDTH 640 HEIGHT 490 ;
		TITLE 'Odczyt kolektora' ;
		MAIN ;
		FONT 'Arial' SIZE 10
		DEFINE BUTTON P_StartSerwer
			ROW	10
			COL	10
			CAPTION "START"
			ACTION StartServer()
			WIDTH 120
			HEIGHT 27
		END BUTTON
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
	StartServer()
function StartServer
	nPort := 80
	public oLogAccess := UHttpdLog():New( "eshop_access.log" )
	IF ! oLogAccess:Add( "" )
		oLogAccess:Close()
		? "Access log file open error " + hb_ntos( FError() )
	public oLogError := UHttpdLog():New( "eshop_error.log" )
   IF ! oLogError:Add( "" )
      oLogError:Close()
      oLogAccess:Close()
      ? "Error log file open error " + hb_ntos( FError() )
   oServer := UHttpdNew()
   IF ! oServer:Run( { ;
         "FirewallFilter"      => "", ;
         "LogAccess"           => {| m | oLogAccess:Add( m + hb_eol() ) }, ;
         "LogError"            => {| m | oLogError:Add( m + hb_eol() ) }, ;
         "Trace"               => {| ... | QOut( ... ) }, ;
         "Port"                => nPort, ;
         "Idle"                => {| o | iif( hb_FileExists( ".uhttpd.stop" ), ( FErase( ".uhttpd.stop" ), o:Stop() ), NIL ) }, ;
         "PrivateKeyFilename"  => "private.key", ;
         "CertificateFilename" => "certificate.crt", ;
         "SSL"                 => .F., ;
         "Mount"          => { ;
         "/hello"            => {|| UWrite( "Hello!" ) }, ;
         "/info"             => {|| UwRITE("Sterowanie bramkami w magazynie Kern-Liebers") }, ;
		 "/KOD"	=> {|| OdczytKodu()};
      oLogError:Close()
      oLogAccess:Close()
      ? "Server error:", oServer:cError
      ErrorLevel( 1 )
   oLogError:Close()
   oLogAccess:Close()
function OdczytKodu
	local aKody := {}
	local cBramka
	aKody := HB_HKeys(get)
	for i:=1 to len(aKody)
		uWrite(aKody[i] + "<br>")
		cBramka := SomeTranslationFromCodeToGateNumber(aKody[i])
		SendRequestToArduino(cAdresKontrolera +"/BRAMKA=" +cBramka )
	next i
return
function SomeTranslationFromCodeToGateNumber
	cCode
return cCode
PROCEDURE SendRequestToArduino
	param cURL
	LOCAL oCon, i
	local ret := .f.
	local cOdp:=""
	for i:=1 to 3
		// liczba prób
		oCon := TipClientHttp():New( cUrl )
		IF oCon:Open()
			// tutaj wymuszam zadziałanie przełącznika :)
			cOdp := oCon:ReadAll()
			//msgdebug("Connected", cOdp)
			oCon:close()
			ret := .t.
			exit
	next i
	if !ret
		MsgBox("Nie mogę się połączyć, błąd" + oCon:lastErrorMessage())
RETURN ret
this is first preview only :)
Ps. My solution is based on eshop.prg from harbour contrib
THX!
Thanks Marek for sharing!
Tomorrow I' ll start production tests.
It's beautiful to join something material like lamps, readers with software.
jairpinho
Post by jairpinho »
mol wrote: Sun Jan 07, 2018 2:53 pm Here is the code waiting for http request. If I want to control lamp, I need to call computer running this app via internet browser or another app calling www site http://localhost:80/KOD?12345
#require "hbhttpd"
	public oServer
	SET EPOCH TO 2000
	set century off
	set date ansi
		MAIN ;
			ROW	10
			COL	10
			CAPTION "START"
			WIDTH 120
			HEIGHT 27
		END BUTTON
	StartServer()
	nPort := 80
		oLogAccess:Close()
      oLogError:Close()
      oLogAccess:Close()
         "Port"                => nPort, ;
         "SSL"                 => .F., ;
         "Mount"          => { ;
      oLogError:Close()
      oLogAccess:Close()
      ErrorLevel( 1 )
   oLogError:Close()
   oLogAccess:Close()
function OdczytKodu
	local aKody := {}
	local cBramka
	next i
return
	cCode
return cCode
	param cURL
	LOCAL oCon, i
	local ret := .f.
	local cOdp:=""
	for i:=1 to 3
		// liczba prób
		IF oCon:Open()
			oCon:close()
			ret := .t.
			exit
	next i
	if !ret
RETURN ret
hello Marek, I would like to know how you added the core.prg files within HARBOR \ contrib \ hbhttpd. because i don't have anything inside this folder, so i found it on github but i don't know how to compile, this refro is the future for hmg works with webservice using restful, managing to compile this resource i'll follow the development of the rest server for hmg, however i'm stuck in this part. already use in another language and I will try in hmg
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
I don't remember any problems with compiling it.
my configuration file from this project:
incpaths=
libpaths=
libs=hbtip
libs=curl
libs=hbcurls
libpaths=.
libs=curldll
gt=
mt=no
instpaths=
Nothing special
mol wrote: Thu Jan 04, 2018 1:09 pm Hi guys!
I've realised my first Arduino project. It will switch on/off lamp indicators depend on barcode scanner read in the warehouse.
Barcode scanner sends barcode to computer, computer sends info to my arduino which lamp should be switched on.
I've created http server which wait for info from computer via http.
I can control lamps via internet browser, calling arduino server: http://192.168.20.190/BRAMKA=3
I want to create simple application, which can call such a page.
Second problem is to act as http server to read info from wifi barcode reader.
Can anybody provide simplest http server application?
regards, Marek
does your scanner have websocket property?
