Learning to print
Re: Learning to print
mol wrote:Integrating printing subsystem with pdf generation works very fine.
But, I've found few problems:
1. When I want to print to pdf numbers, I need to convert them to strings. Can sb. approve it?
2. Functions GetPrintableHorizontalOffset(), GetPrintableVerticalOffset(), GetPrintableAreaWidth(), GetPrintableAreaHeight() return 0 while pdf generation. Is it possible to modify them to return values depending from selected paper size?
Regards, Marek
These are good suggestions.
In the case of PDF, I think the programmer can start printing to the full extent of the paper he had chosen but has to be checked.
