Read text file no allow edits
RussBaker
Re: Read text file no allow edits
Post by RussBaker »
Thank you all for suggestions.
I took Dragan's code and made some changes. I don't need to search the file nor use line numbers.
Added printing function, which allows me to use any Windows or network printer. This is important as line printers are hard to find.
My old Clip code was inserting page breaks into the report, so this allows me to detect them and break the page in HMG.
I also built in some logic to detect page width. My reports come in 80 and 120 column formats, so I want to use the correct print width for selecting fonts size.
It accepts command line arguments so I can do
PREVIEW.EXE Mytextfile.txt
What I found important was selecting a font that is monospaced and exists in most Windows installs.
Again, that's to a fantastic HMG support community.
Attached is his modified code.
--Russ
Main.zip
(1.58 KiB) Downloaded 442 times
Wonderful!
I have slightly modified to reduce the width of the grid, center the window and allow to print in lpt1 if it is available. Hope you don't mind altering.
My humble suggestions:
1. dbcloseall is not required as no dbf activity is done here.
2. Virtual grid can be used for large text files.
3. Instead of using len() and substr() functions, we can use hmg_len() and hb_usubstr() functions as they are unicode compatible.
 * This program is generated by HMGCASE
 * developed by Dragan Cizmarevic < dragancesu(at)gmail.com >
#define CRLF            Chr(13)+Chr(10)
#define LINEBUFF        1024
STATIC aGrid := {}, _find := '', _readmefile := ''
PROCEDURE MAIN
     PUBL Maxline:=0
    _readmefile:="test.txt"
    Procargin()
      set navigation extended
   DEFINE WINDOW Readme_Form_1 ;
      AT 10,10 ;
      WIDTH 1024 ;
      HEIGHT 768 ;
      TITLE "Report Preview" ;
      MAIN ; // for test, usually MODAL
      ON INIT Readme_Load_file(_readmefile) ;
      ON RELEASE dbcloseall()
      ON KEY ESCAPE ACTION Readme_Form_1.Release
	  @ 15, 50 BUTTON cmd4Print CAPTION " Print " ACTION printtext() WIDTH 90 HEIGHT 25
	  @ 15, 150 BUTTON cmd5Print CAPTION " LPT1 Print " ACTION printtextlpt1( _readmefile ) WIDTH 90 HEIGHT 25
      @ 50,1 GRID Readme_Grid_1 ;
         WIDTH 1010 ;
         HEIGHT 675 ;
         HEADERS { "","" } ;
         WIDTHS { 1, 980 } ;
         FONT "Lucida Console" ;
         SIZE 9.7 ;
         JUSTIFY { 1,0 } ;
         NOLINES
   Readme_Form_1.center
   ACTIVATE WINDOW Readme_Form_1
Function Readme_Load_file(cfile)
Local i, cLine := "", aLine := {}
Private lEof:= .f.
nArquivo:=FOpen(cFile,0)
If nArquivo # -1
   Do While !lEof
      cLine := CharRem( Chr(26), ReadLine(nArquivo,LINEBUFF) )
      Aadd(aGrid, { "" , cline }  )
      if len(alltrim(cline)) > maxline
         maxline= len(alltrim(cline))
   Enddo
Endif
FClose(nArquivo)
   Readme_Form_1.Readme_Grid_1.DeleteAllItems()
   FOR i = 1 to LEN(aGrid)
        Readme_Form_1.Readme_Grid_1.AddItem(aGrid[i])
Return aLine
Static Function ReadLine(nHandle,nBuffSize)
Local cRet:= cBuff:='', nPos:= nEol:= nRead:=0
cBuff := Space(nBuffSize)
nPos := FSeek(nHandle,0,1)
If ( nRead:=FRead(nHandle,@cBuff,nBuffSize) ) > 0
   If ( nEol:=At(CRLF,SubStr(cBuff,1,nRead)) ) == 0
      cRet:=SubStr(cBuff,1)+Chr(26)
      lEof:=.T.
   Else
      cRet:=SubStr(cBuff,1,nEol-1)
      FSeek(nHandle,nPos+nEol+1,0)
   Endif
Else
   lEof:=.T.
Endif
Return cRet
Procedure PrintText()
Local i
Local lSuccess
	SELECT PRINTER DIALOG TO lSuccess
	If lSuccess == .T.
		PrintDoc()
		MsgInfo('Print Finished')
	EndIf
Procedure PrintDoc
Local i
Local x
local l:=1
local ej:=chr(12)
local f:=7  // font
local h:=4  // height
If maxline > 80
  f=7
  h=4
 //msgbox("small font")
Else
//msgbox("large font")
  f=12
  h=4.5
Endif
	// Measure Units Are Millimeters
	START PRINTDOC
			START PRINTPAGE
            for i = 1 to len(aGrid)
              x=aGrid[i,2]
              @ l*h, 7 Print x  FONT "Courier New" Size f
              l++
              if l> 60 .or. ej $ x
                  END PRINTPAGE
                  l=1
                  START PRINTPAGE
				Next i
			END PRINTPAGE
	END PRINTDOC
func procargin()  // process argument in
for n=1 to HB_Argc()
  argin=upper(HB_Argv(n))
  _readmefile:=argin
next n
return
function printtextlpt1( cFileName )
   if PRINTREADY( 1 )
      copy file (cFileName) to lpt1
      msgstop( 'Printer is not ready at LPT1 Port!','Dot Matrix Printer Error' )
return nil
RussBaker
Post by RussBaker »
Rathinagiri wrote:Hi,
Oh please, make suggestions and comments.
1) I also thought the dbcloseall was out of place as no dbf files are used. It probably doesn't do anything other than waste code.
2) Virtual grid? I will need to learn more about grids.
3) I am in my infancy with HMG. I've been a Clip5x programmer for decades, but the HB_ functions are new to me. I will learn more of them going forward.
Dragan might appreciate the LPT support. Most of my installations no longer use LPT printers.
The clients that do, use them for printing barcode labels on pin feed forms. That's on my todo list. Learn how to produce 3 of 9 barcode labels. Although sheet feed laser labels are superior to ribbon printed labels. So much to learn, however I'm really enjoying HMG.
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
I'm glad I could help, HMG use for nearly two years and since then has improved a lot, harbour and HMG
Clipper and dot-matrix printer is fine combination
Clipper and laser problematic
HMG and laser ok
but there are users who still have satisfied the Epson dot matrix printers and there is Clipper is slightly ahead, and there are plenty of such programs in the past, it took me only view and print, it works
And I think should be seeking in text and sending the mail, but that's what I have already written
RussBaker
Post by RussBaker »
In retrospect. I think the search function is probably very valuable and may put it back in.
I have clip code that prints to simple laser printers and barcodes. Modern lasers have more dependency on windows drivers and plain text doesn't work.
I do have one client with an Epson dot matrix. They print bar code labels with a 3 of 9 print function. I need to make HMG do this in native windows.
Thanks again Dragan. Very helpful
--rRuss
