Status of source code changes suggested in November 2014
kcarmody
Re: Status of source code changes suggested in November 2014
Post by kcarmody »
srvet_claudio wrote:
kcarmody wrote:
srvet_claudio wrote:I think these suggestions not missing because I never implemented in HMG.
Someone implemented them in HMG for a while. All the changes marked 3.4.1a were part of the 3.4.1 release in July, but were removed from the release version some time after that, and those are marked 3.4.1b.
You did not mention the rich edit demo. As I said, my version of the rich edit demo (version 3.3.1k) was modified and put into HMG in July (version 3.4.1a), but this version was buggy and unusable for text files. After that (version 3.4.1b), the rich edit demo was reset to the form it was in 3.3.1.
Maybe I copied your files into the source folder of HMG and not checked, honestly I don't remember, I think I'm getting old.
OK, maybe so. If you did do this, then you copied only the .prg and .c files and did not copy the .ch files.
But the rich edit demo was not simply copied. It was modified by someone, and the modifications introduced bugs that were not present in my version. Did you perhaps try to compile my version of the rich edit demo, find that it would not compile (due to missing modifications in the .ch files), and then modify the demo so that it would compile?
I don't actually need to know whether you did this or not. We just need to find a way to get these features into the current version. Would you like me to develop a new proposal for the current version?
kcarmody wrote:Would you like me to develop a new proposal for the current version?
Ok, go on.
Carlos Britos
Post by Carlos Britos »
kcarmody wrote:
Carlos Britos wrote:Maybe is a false positive, but Avast report infection DRep and the file Demo.exe is deleted
I think it must be a false positive. I have run this demo since last November. AVG has never reported a problem with it, and I have never seen any symptoms of any problems. It is constructed from a modified version of HMG, with all modified source code in the folders around it.
My antivirus Symantec found risk Quarined Demo.exe
The executable I posted is made from a lightly modified version of HMG. If it has a virus, then other HMG executables may also have viruses. Have you tried running this antivirus program on other HMG executables? I have AVG, which has protected me well against viruses in the past, and it has never complained about this executable.
Hi
My first try downloading the file, was via Firefox downloader, then Avast show an alert.
My second try downloading the file was via app Downloader Express, and the Avast say all is ok.
So now I just have to say :shock: :shock:
Did the antivirus detect a problem with UPX.exe or with demo.exe?
with demo.exe.
kcarmody
Post by kcarmody »
Ok, go on.
Ok, I will do this. Is there any patch to the current version other than patch 1 mentioned at viewtopic.php?p=42140#p42140?
kcarmody
Post by kcarmody »
with demo.exe.
I can't understand how this could be an actual virus. I built this with a lightly modified version of HMG. I built it last November. I have AVG antivirus, which has protected me well in the past. AVG has never raised an alarm about demo.exe, and I have not seen any problem that indicates that a virus is present. If demo.exe does have a virus, then other HMG executables would probably also have the same virus. I can't see how HMG could have a virus in it, since it is open source, unless there is some library HMG uses that is not open source, or unless someone did not notice some virus code in the source.
There is an interesting discussion of false antivirus positives at How To Geek -- http://www.howtogeek.com/180162/how-to- ... -positive/ -- If an antivirus raises an alert that you think might be false, this page recommends that you upload it to VirusTotal -- https://www.virustotal.com/ -- which runs the file through 56 different antivirus programs, including Avira. I just ran demo.exe through VirusTotal, and it came up with a score of 0/56 -- out of the 56 antivirus programs in VirusTotal, none of them found a virus in demo.exe.
AV-Comparatives has done a comparison report on antivirus programs -- http://www.av-comparatives.org/wp-conte ... 503_en.pdf -- Avira has one of the highest rates of detecting true viruses (page 6) but also a high rate of false positives (page 8).
Ok, go on.
This is the last patch: viewtopic.php?f=43&t=4400&start=160#p42442
kcarmody
Post by kcarmody »
Following my discussion with Claudio earlier in this thread, I'm resubmitting the following changes, all relating to the RichEditBox control. I've developed a patch, based on Claudio's current patch (patch 6), which incorporates these changes. My patch should be installed on top of Claudio's patch.
Individual modified source files are at http://kevincarmody.com/hmg/, and a zip of files in the patch is at http://kevincarmody.com/hmg/HmgChangeProposal.zip.
This patch includes an overhauled Rich Edit demo, which uses all the source code changes (except for the SelPasteSpecial method). The new Rich Edit demo is at http://kevincarmody.com/hmg/SAMPLES/Con ... chEditBox/.
New manifest constants RTFTXTFILE_ANSI etc.
These constants are RTF and TXT file types returned by the new function GetRtfTxtFileType() and can be used by the RtfTxtLoadFile and RtfTxtSaveFile methods of the RichEditBox control.
http://kevincarmody.com/hmg/INCLUDE/i_richeditbox.ch - lines 161-169
// Following 5 #defines added by Kevin Carmody, September 2015
*   File type   *
#define RTFTXTFILE_ANSI      1   // ANSI text file
#define RTFTXTFILE_UTF8      2   // UTF-8 text file
#define RTFTXTFILE_UTF16LE   3   // UTF-16 LE (little endian) text file
#define RTFTXTFILE_RTF       4   // RTF file
#define RTFTXTFILE_UTF16BE   5   // UTF-16 BE (big endian) text file
These constants are also used in the Rich Edit demo - http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - lines 883-904 and lines 976-992.
New function GetRtfTxtFileType( cFile, lUtf8Test ) --> nFileType
This function returns a file type (RTF, ANSI, UTF-16, UTF-8) which can be used in RtfTxtLoadFile and RtfTxtSaveFile methods of RichEditBox control.
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 52, 512-578
// Following line added by Kevin Carmody, September 2015
#include "fileio.ch"
// Following function added by Kevin Carmody, September 2015
FUNCTION GetRtfTxtFileType ( cFile, lUtf8Test )
LOCAL hFile    := FOPEN( cFile, FO_READ )
LOCAL cBuffer  := SPACE( 5 )
LOCAL nBufRead := 0
LOCAL nType    := 0
  The following code block tests for the presence of non-ASCII characters in
  an unmarked text file.  It assumes that such characters may be ANSI or
  parts of UTF-8 sequences.  In UTF-8 mode, Windows reads bytes which are not
  part of a valid UTF-8 sequence as ANSI.  It would be better to know if the
  file contained UTF-8 sequences for non-ANSI characters, but since some ANSI
  characters are not in the Latin-1 Supplement, testing for non-ANSI UTF-8
  sequences is inefficient for large files.
LOCAL bHasUnicodeChars := {||
   LOCAL lHasUnicode := .N.
   LOCAL cChar, cStr
   cBuffer  := SPACE( 0x400 )
   nBufRead := 1
   BEGIN SEQUENCE
      WHILE nBufRead > 0
         nBufRead := FREAD( hFile, @cBuffer, 0x400 )
         IF nBufRead > 0
            cStr := LEFT( cBuffer, nBufRead )
            FOR EACH cChar IN cStr
               IF cChar >= CHR(0x80)
                  lHasUnicode := .Y.
                  BREAK
      ENDDO
   END SEQUENCE
   RETURN lHasUnicode
BEGIN SEQUENCE
   IF hFile < 0
      BREAK
   nBufRead := FREAD( hFile, @cBuffer, 5 )
   DO CASE
   CASE nBufRead >= 5 .AND. LEFT( cBuffer, 5 ) == "{\rtf"
      nType := RTFTXTFILE_RTF
   CASE nBufRead >= 3 .AND. LEFT( cBuffer, 3 ) == E"\xEF\xBB\xBF"
      nType := RTFTXTFILE_UTF8
   CASE nBufRead >= 2 .AND. LEFT( cBuffer, 2 ) == E"\xFF\xFE"
      nType := RTFTXTFILE_UTF16LE
   CASE nBufRead >= 2 .AND. LEFT( cBuffer, 2 ) == E"\xFE\xFF"
      nType := RTFTXTFILE_UTF16BE
   CASE ! EMPTY( lUtf8Test ) .AND. bHasUnicodeChars:EVAL( )
   OTHERWISE
      nType := RTFTXTFILE_ANSI
   ENDCASE
END SEQUENCE
FCLOSE( hFile )
RETURN nType
This function is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - line 880
   LOCAL nFormat        := GETRTFTXTFILETYPE(cFileName, .Y.)
New function Utf16ByteSwap( cInFile, cOutFile )
This function supports the UTF-16 BE (big endian) file type for the RtfTxtLoadFile and RtfTxtSaveFile methods of RichEditBox control.
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 52, 583-623
FUNCTION Utf16ByteSwap( cInFile, cOutFile )
LOCAL hInFile   := FOPEN( cInFile , FO_READ )
LOCAL hOutFile  := FCREATE( cOutFile )
LOCAL cInBuffer := SPACE( 0x400 )
LOCAL nBufRead  := 1
LOCAL lSuccess  := .N.
LOCAL cOutBuffer, cBytePair, nBufWrite, nByte
BEGIN SEQUENCE
   IF hInFile < 0
      BREAK
   IF hOutFile < 0
      BREAK
   WHILE nBufRead > 0
      cOutBuffer := ""
      nBufRead   := FREAD( hInFile, @cInBuffer, 0x400 )
      IF nBufRead > 0
         FOR nByte := 1 TO nBufRead STEP 2
            cBytePair  := SUBSTR( cInBuffer, nByte, 2 )
            cOutBuffer += RIGHT( cBytePair, 1 ) + LEFT( cBytePair, 1 )
         nBufWrite := FWRITE( hOutFile, cOutBuffer )
         IF nBufWrite < nBufRead
            BREAK
   ENDDO
   lSuccess := .Y.
END SEQUENCE
FCLOSE( hInFile )
FCLOSE( hOutFile )
RETURN lSuccess
This function is used in RichEditBox_RtfTxtLoadFile() and RichEditBox_RtfTxtSaveFile() - see below.
Fixed RichEditBox_StreamIn( hWndControl, cFileName, lSelection, nDataFormat ) --> lSuccess
This function now skips over a byte order mark (BOM) in a Unicode text file if one is present.
http://kevincarmody.com/hmg/SOURCE/c_richeditbox.c - lines 190-192, 199-203, 216-233
//        RichEditBox_StreamIn ( hWndControl, cFileName, lSelection, nDataFormat ) --> return lSuccess
HB_FUNC ( RICHEDITBOX_STREAMIN )
   HWND       hWndControl = (HWND)   HMG_parnl (1);
   TCHAR     *cFileName   = (TCHAR*) HMG_parc (2);
   BOOL       lSelection  = (BOOL)   hb_parl  (3);
   LONG       nDataFormat = (LONG)   hb_parnl (4);
   HANDLE     hFile;
   // Following 3 lines added by Kevin Carmody, September 2015
   BYTE       bUtf8Bom[3];
   BYTE       bUtf16Bom[2];
   DWORD      dwRead;
   EDITSTREAM es;
   LONG       Format;
   switch( nDataFormat )
   // Comments in this switch block modified by Kevin Carmody, September 2015
      case 1:   Format = SF_TEXT; break; // ANSI or UTF-8 with BOM or mixed (UTF-8 BOM removed, overlong UTF-8 accepted, invalid UTF-8 read as ANSI)
      case 2:   Format = ( CP_UTF8 << 16 ) | SF_USECODEPAGE | SF_TEXT; break; // UTF-8 without BOM (BOM not removed)
      case 3:   Format = SF_TEXT | SF_UNICODE; break; // UTF-16 LE without BOM (BOM not removed)
      case 4:   Format = SF_RTF;  break;
      // case 5, UTF-8 RTF, removed by Kevin Carmody, September 2015, because it can never occur
      default:  Format = SF_RTF; break;
   if ( lSelection )
        Format = Format | SFF_SELECTION;
   if( ( hFile = CreateFile (cFileName, GENERIC_READ, FILE_SHARE_READ, NULL, OPEN_EXISTING, FILE_FLAG_SEQUENTIAL_SCAN, NULL )) == INVALID_HANDLE_VALUE )
   {   hb_retl (FALSE);
       return;
   // Following switch block added by Kevin Carmody, September 2015
      case 1:   break;
      case 2:
         if ( ! ReadFile (hFile, bUtf8Bom, 3, &dwRead, NULL) ) // read past BOM if present
            hb_retl (FALSE);
         if ( ! ( dwRead == 3 && bUtf8Bom[0] == 0xEF && bUtf8Bom[1] == 0xBB && bUtf8Bom[2] == 0xBF ) )
            SetFilePointer (hFile, 0, 0, FILE_BEGIN);
         break;
      case 3:
         if ( ! ReadFile (hFile, bUtf16Bom, 2, &dwRead, NULL) ) // read past BOM if present
            hb_retl (FALSE);
         if ( ! ( dwRead == 2 && bUtf16Bom[0] == 0xFF && bUtf16Bom[1] == 0xFE ) )
         break;
      case 4:   break;
      default:  break;
   es.pfnCallback = EditStreamCallbackRead;
   es.dwCookie    = (DWORD_PTR) hFile;
   es.dwError     = 0;
   SendMessage ( hWndControl, EM_STREAMIN, (WPARAM) Format, (LPARAM) &es );
   CloseHandle (hFile);
   if( es.dwError )
      hb_retl (FALSE);
      hb_retl (TRUE);
This function is called by RichEditBox_RtfTxtLoadFile() - see below.
Fixed RichEditBox_StreamOut( hWndControl, cFileName, lSelection, nDataFormat ) --> lSuccess
This function now writes a byte order mark (BOM) to a Unicode text file.
http://kevincarmody.com/hmg/SOURCE/c_richeditbox.c - lines 269-271, 278-282, 295-302
//        RichEditBox_StreamOut ( hWndControl, cFileName, lSelection, nDataFormat ) --> return lSuccess
HB_FUNC ( RICHEDITBOX_STREAMOUT )
   HANDLE     hFile;
   BYTE       bUtf8Bom[3]  = {0xEF, 0xBB, 0xBF};
   BYTE       bUtf16Bom[2] = {0xFF, 0xFE};
   DWORD      dwWritten;
   EDITSTREAM es;
   LONG       Format;
      case 1:   Format = SF_TEXT; break; // ANSI (non-ANSI characters converted to question marks)
   if ( lSelection )
   if( ( hFile = CreateFile (cFileName, GENERIC_WRITE, FILE_SHARE_WRITE, NULL, CREATE_ALWAYS, FILE_ATTRIBUTE_NORMAL, NULL )) == INVALID_HANDLE_VALUE )
   {   hb_retl (FALSE);
       return;
      case 1:   break;
      case 2:   WriteFile( hFile, bUtf8Bom, 3, &dwWritten, NULL ); break; // write UTF-8 BOM at head of file
      case 3:   WriteFile( hFile, bUtf16Bom, 2, &dwWritten, NULL ); break; // write UTF-16 LE BOM at head of file
      case 4:   break;
      default:  break;
   es.pfnCallback = EditStreamCallbackWrite;
   es.dwError     = 0;
   SendMessage ( hWndControl, EM_STREAMOUT, (WPARAM) Format, (LPARAM) &es );
   if( es.dwError )
      hb_retl (FALSE);
      hb_retl (TRUE);
This function is used in RichEditBox_RtfTxtSaveFile() - see below.
New RichEditBox property HasUnicodeChars (read only)
This property detects whether a rich edit control contains non-ASCII Unicode characters.
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 10266-10268, at end of _RichEditBox_GetProperty()
   // Following case added by Kevin Carmody, September 2015
   CASE Arg3 == "HASUNICODECHARS"
        xData  := RichEditBox_HasUnicodeChars ( hWndControl )
        RetVal := .T.
http://kevincarmody.com/hmg/INCLUDE/i_window.ch - line 164
;; // Following line modified by Kevin Carmody, September 2015
#xtranslate <w>. \<c\> . \<p:RTFTextMode,AutoURLDetect,Zoom,SelectRange,CaretPos,Value,GetSelectText,GetTextLength,ViewRect,HasUnicodeChars\> => GetProperty ( <"w">, \<"c"\> , \<"p"\> ) ;;
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 418-440
  The following function tests for the presence of non-ASCII characters in
  a rich edit control.  It would be better to know if the control contained
  non-ANSI characters, but since some ANSI characters are not in the Latin-1
  Supplement, testing for non-ANSI characters is inefficient for large
  documents.
FUNCTION RichEditBox_HasUnicodeChars( hWndControl )
LOCAL cBuffer     := RichEditBox_GetText( hWndControl , .N. )
LOCAL cChar
FOR EACH cChar IN cBuffer
      lHasUnicode := .Y.
RETURN lHasUnicode
This function is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - line 945
   LOCAL lUnicode := wMain.ebDoc.HASUNICODECHARS
New RichEditBox method RtfTxtLoadFile( cFile, lSelection, nType ) --> lSuccess
This method is a synonym for the RtfLoadFile method. It now uses the file type returned by GetRtfTxtFileType(). It skips over a byte order mark in a Unicode text file, and it supports UTF-16 BE (big endian Unicode text file).
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 10440-10442
   // Following case modified by Kevin Carmody, September 2015
   CASE Arg3 == "RTFLOADFILE" .OR. Arg3 == "RTFTXTLOADFILE"
        xData := RichEditBox_RtfTxtLoadFile ( hWndControl, Arg4, Arg5, Arg6 )   // by default save in SF_RTF format
        RetVal := .T.
http://kevincarmody.com/hmg/INCLUDE/i_window.ch - lines 172-173, 175
;; // Following 2 lines modified by Kevin Carmody, September 2015
#xtranslate <w>. \<c\> . \<p:RTFLoadFile,RTFSaveFile,RtfTxtLoadFile,RtfTxtSaveFile\> (\<arg1\>,\<arg2\>,\<arg3\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\>, \<arg3\> ) ;;
#xtranslate <w>. \<c\> . \<p:RTFLoadFile,RTFSaveFile,RtfTxtLoadFile,RtfTxtSaveFile\> (\<arg1\>,\<arg2\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\> ) ;;
;; // Following line added by Kevin Carmody, September 2015
#xtranslate <w>. \<c\> . \<p:RTFLoadFile,RTFSaveFile,RtfTxtLoadFile,RtfTxtSaveFile\> (\<arg1\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> ) ;;
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 445-477
FUNCTION RichEditBox_RtfTxtLoadFile( hWndControl, cFile, lSelection, nType )
LOCAL cTempFile
IF ! HB_ISLOGICAL( lSelection )
   lSelection := .N.
IF ! HB_ISNUMERIC( nType )
IF lSelection
   RichEditBox_UnSelectAll( hWndControl )
IF RichEditBox_RTFLoadResourceFile( hWndControl, cFile, lSelection )
   lSuccess := .T.
   IF nType == RTFTXTFILE_UTF16BE
      cTempFile := GETTEMPFOLDER() + "_RtfTxtLoadFile.txt"
      lSuccess  := Utf16ByteSwap( cFile, cTempFile )
      IF lSuccess
         lSuccess := RichEditBox_StreamIn( hWndControl, cTempFile, lSelection, RTFTXTFILE_UTF16LE )
      DELETE FILE ( cTempFile )
      lSuccess := RichEditBox_StreamIn( hWndControl, cFile, lSelection, nType )
RETURN lSuccess
This method is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - line 906
      IF ! wMain.ebDoc.RTFTXTLOADFILE(cFileName, .N., nFormat)
New RichEditBox method RtfTxtSaveFile( cFile, lSelection, nType ) --> lSuccess
This method is a synonym for the RtfSaveFile method. It now uses the file type returned by GetRtfTxtFileType(), writes a byte order mark to a Unicode text file, and supports UTF-16 BE (big endian Unicode text file).
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 10445-10447
   CASE Arg3 == "RTFSAVEFILE" .OR. Arg3 == "RTFTXTSAVEFILE"
        xData := RichEditBox_RtfTxtSaveFile ( hWndControl, Arg4, Arg5, Arg6 )   // by default save in SF_RTF format
        RetVal := .T.
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 482-507
FUNCTION RichEditBox_RtfTxtSaveFile( hWndControl, cFile, lSelection, nType )
LOCAL cTempFile
   lSelection := .N.
   lSuccess := RichEditBox_StreamOut( hWndControl, cTempFile, lSelection, RTFTXTFILE_UTF16LE )
   IF lSuccess
      lSuccess  := Utf16ByteSwap( cTempFile, cFile )
   lSuccess := RichEditBox_StreamOut( hWndControl, cFile, lSelection, nType )
RETURN lSuccess
This method is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - line 993
      IF ! wMain.ebDoc.RTFTXTSAVEFILE(cFileName, .N., nFormat)
New RichEditBox method SelPasteSpecial
Paste special - needs documentation of clipboard format argument.
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 10458-10460
   CASE Arg3 == HMG_UPPER ("SelPasteSpecial")
        RichEditBox_PasteSpecial ( hWndControl, Arg4 )
        RetVal := .T.
http://kevincarmody.com/hmg/INCLUDE/i_window.ch - line 179
#xtranslate <w>. \<c\> . \<p:SelPasteSpecial\> (\<arg1\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> ) ;;
This method is not used in the Rich Edit demo.
Enhanced RichEditBox method RtfLoadFile( cFile, lSelection, nType ) --> lSuccess
This method is a synonym for the RtfTxtLoadFile method described above.
        RetVal := .T.
Enhanced RichEditBox method RtfSaveFile( cFile, lSelection, nType ) --> lSuccess
This method is a synonym for the RtfTxtSaveFile method described above.
        RetVal := .T.
Enhanced function DoMethod ( Arg1 , Arg2 , Arg3 , Arg4 , Arg5 , Arg6 , Arg7 , Arg8 , Arg9 )
Enabled this function to return a value from a RichEditBox method.
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - line 8869
Function DoMethod ( Arg1 , Arg2 , Arg3 , Arg4 , Arg5 , Arg6 , Arg7 , Arg8 , Arg9 )
Local xData, i, hWnd
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 8881-8882
IF _RichEditBox_DoMethod ( @xData, Arg1 , Arg2 , Arg3 , Arg4 , Arg5 , Arg6 , Arg7 , Arg8 , Arg9 ) == .T.
   Return xData
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - line 10416
Function _RichEditBox_DoMethod ( xData, Arg1 , Arg2 , Arg3 , Arg4 , Arg5 , Arg6 , Arg7 , Arg8 , Arg9 )
The return value is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - lines 906
The return value is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - lines 993
Thanks Kevin,
I will include this changes in the new release.
kcarmody
Post by kcarmody »
srvet_claudio wrote:Thanks Kevin,
Thanks Claudio :)
