Sending Mail
Re: Sending Mail
Wonderful! Thank you Grigory. I will also try!
Re: Sending Mail
I'm using hb_sendmail() in another solution and it's work OK.
Please point, which dll's we need to copy to app folder to work with SSL.
Regards, Marek
Re: Sending Mail
mol wrote:I'm using hb_sendmail() in another solution and it's work OK.
libeay32.dll and ssleay32.dll.
I've downloaded SSL from: http://slproweb.com/products/Win32OpenSSL.html
The test machine is Windows 7 Starter 32 bits.
I'm testing with a console app.
I've built using hbmk2 and plain Harbour.
@echo off
cls
set path=c:\hmg.3.4.1\harbour\bin;c:\hmg.3.4.1\mingw\bin
hbmk2 test.prg hbssl.hbc hbtip.hbc
pause
This is the code:
REQUEST __HBEXTERN__HBSSL__
	SETMODE(25,80)
	SETCURSOR(0)
	SETCOLOR('W+/B')
	CLS
	@ 0  , 0 SAY REPLICATE( '-', 80 )
	@ 1  , 1 SAY 'MAIL TEST'
	@ 2  , 0 SAY REPLICATE( '-', 80 )
	@ 22 , 0 SAY REPLICATE( '-', 80 )
	@ 23 , 1 SAY 'STATUS: WAITING'
	@ 24 , 0 SAY REPLICATE( '-', 80 )
	@ 06, 22 SAY 'OPTIONS'
	@ 08, 22 SAY '1. SEND'
	@ 12, 22 SAY 'ESC. EXIT'
	DO WHILE .T.
		K := INKEY(0.9)
		IF	K == 49
			cTO	:= 'mail.box.hmg@gmail.com'
			cBody	:= 'Body!'
			cSubject:= 'Subject!'
			SEND ( cTO , cSubject , cBody )
		ELSEIF	K == 27
			QUIT
	ENDDO
PROCEDURE SEND ( cTO , cSubject , cBody )
	IF ! tip_SSL()
		ALERT ( "ERROR SSL" )
	@ 23 , 1 SAY 'STATUS: STARTING ' + DTOC(DATE()) + ' ' + TIME()
	cFrom		:= "your.user.id@gmail.com"
	cPassword	:= "your.password"
	R := hb_SendMail(  "smtp.gmail.com",  465,	;
		cFrom,					;
		cTo,					;
		NIL /* CC */,				;
		{} /* BCC */,				;
		cBody,					;
		cSubject,				;
		NIL /* attachment */,			;
		cFrom,					;
		cPassword,				;
		NIL /* nPriority */,			;
		NIL /* lRead */,			;
		.T. /* lTrace */,			;
		.F.,					;
		NIL /* lNoAuth */,			;
		NIL /* nTimeOut */,			;
		NIL /* cReplyTo */,			;
		.T. )
	IF R
		@ 23 , 1 SAY 'STATUS: SEND OK    ' + DTOC(DATE()) + ' ' + TIME() + SPACE(40)
		@ 23 , 1 SAY 'STATUS: SEND ERROR ' + DTOC(DATE()) + ' ' + TIME() + SPACE(40)
I've not tested with HMG yet (I've not investigated about how to include the additional hbc files required in the current version or if it is needed at all)
Re: Sending Mail
I've used ssl without installing openssl (not gmail account)
It works, strange? (or I'm not learned enough :-) most possible :-D )
Re: Sending Mail
Roberto Lopez wrote: I've not tested with HMG yet (I've not investigated about how to include the additional hbc files required in the current version or if it is needed at all)
Well... I've tried to build with HMG.3.4.1 (from IDE) but I was unable to do it.
How could this be done?
TIA.
Re: Sending Mail
mol wrote:I've used ssl without installing openssl (not gmail account)
Maybe the account you used not required SSL auth or SSL dlls are already in your Windows system folder...
