HMG 3.4.1
Re: HMG 3.4.1
Post by EduardoLuis »
Hi Friends:
Downloading succesfully.-
Today i'll begin testing new version.-
Thanks Rathi and Dr. Claudio for your efforts and also thanks for share with us.-
With Regards, Eduardo
dhaine_adp
Re: HMG 3.4.1
Post by dhaine_adp »
Hi Pablo,
Also there is not BuildLib64.bat, It's missing.
Danny are you trying with build64.bat to build LIBs ???
The lib wont compile on build64.bat because hbmk can't be found on the path. As I have said harbour-64 folder is missing as defined on _BuildAllLib64.bat. BuildAllLib.bat works fine. _BuildLib64.bat gives the error message below:
 Build Library:         UNICODE (64 bits)
'hbmk2' is not recognized as an internal or external command,
operable program or batch file.
Press any key to continue . . .
The harbour/bin folder contains the 32-bit version while mingw\bin seems to be fine because it both contains the 64 and 32 bit version. Anyway I'll see if I can rebuild Harbour from the coremaster at github.
Danny
Manila, Philippines
Re: HMG 3.4.1
Many thanks Mr. Rathinagiri and Dr. Soto
Successfully downloaded, Speed of download is also fast
Installed Successfully
Re: HMG 3.4.1
dhaine_adp wrote:The lib wont compile on build64.bat because hbmk can't be found on the path. As I have said harbour-64 folder is missing as defined on _BuildAllLib64.bat. BuildAllLib.bat works fine.
Yes I know. But probably you should follows this Claudio's instructions. And I guess we still follows this tructure.
dhaine_adp
Re: HMG 3.4.1
Hi Pablo,
Thanks for pointing that out. I'm done with compiling in 64 bit. So far my apps compiles and links without a problem.
Danny
Manila, Philippines
Re: HMG 3.4.1
Hola amigos para 64 bits
he copiado dentro de c:\hmg.3.4.1_64
HARBOUR-64
LIB-64
MinGW-64
y luego he ejecutado
_BuildAllLib64.bat
_BuildLib64.bat
no se si es correcto pero parece que funciona
y me he preparado un fichero bat build.3.4.1_64.bat
@ECHO OFF
call c:\hmg.3.4.1_64\build64.bat main %*
main seria el nombre del prg que queremos compilar
ejemplo main.prg
Un Saludo
Hello friends for 64-bit
I copied in c:\hmg.3.4.1_64
HARBOUR-64
LIB-64
MinGW-64
and I then executed
_BuildAllLib64.bat
_BuildLib64.bat
not whether it is right but it seems to work
and I have prepared a batch file build.3.4.1_64.bat
@ECHO OFF
call c:\hmg.3.4.1_64\build64.bat main% *
main prg name would we want to compile
example main.prg
a Greeting
Re: HMG 3.4.1
Hi Mustafa + Danny,
Thank you to report your experiences in 64 bits.
Would be interesting to describe where have you have taken Harbour-64 ? Which link ?
Rgds
Re: HMG 3.4.1
HMG 3.4.1
Gracias Mustafa por esclarecer. Pero mismo asi lo que me preocupa es utilizar la version Harbour más actual para las actualizaciones. :?
Re: HMG 3.4.1
1) Download Harbour and MinGW in 64-bit from Here
2) Unzip file in folder: c:\hmg.3.4.1
3) exec c:\hmg.3.4.1\_BuildAllLib64.bat
Build app with build64.bat
