WINDOW ON A SECOND MONITOR ?
Re: WINDOW ON A SECOND MONITOR ?
I've made little test with:
GetDesktopHeight() and GetDesktopWidth()
These functions always return parameters of first monitor - witdh=1280 and height=1024.
When I drag application to second monitor, these functions still return parameters of first monitor.
I've defined main window at 0,1281 and app runs on second screen. But - it still reports parameters (desktop width and heigth) from first - smaller display.
Hola Mol
Como es tu configuracion para la salida de los monitores ?, porque siempre me lo despliega en el primero.
Solo aparece si yo lo muevo manualmente.
Hello Mol
As your output settings for the monitors?, Because I always displays it in the first.
Displayed only when I move it manually.
Function Main()
	nAnch := GetDesktopWidth()
	nAlto := GetDesktopHeight()
	DEFINE WINDOW FORM_1 AT 0,1370 WIDTH 1024 HEIGHT 500 MAIN TITLE "PANTALLA 1" BACKCOLOR WHITE
		@ 10,10 LABEL L1 VALUE STR( nAnch ) + " / " + STR( nAlto ) WIDTH 200 HEIGHT 20 FONT "Verdana" SIZE 12
		@ 50,10 BUTTON B1 CAPTION '&Mon2' WIDTH 060 HEIGHT 25 FONT "Arial" SIZE 09 ACTION Monitor2() TOOLTIP "Despliga Monitor 2"
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
Function Monitor2()
		DEFINE WINDOW FORM_2 AT 0,1500 WIDTH 1024 HEIGHT 500 TITLE "PANTALLA 2"  BACKCOLOR BLUE
			@ 10,10 LABEL L2 VALUE STR( nAnch ) + " / " + STR( nAlto ) WIDTH 200 HEIGHT 20 FONT "Verdana" SIZE 12
		CENTER WINDOW Form_2
		ACTIVATE WINDOW Form_2
Quitando la siguiente linea, lo despliega en el segundo monitor...
By removing the following line is displayed on the second monitor ...
YES !
See:
#define SM_XVIRTUALSCREEN    76   // The coordinates for the left side of the virtual screen. The virtual screen is the bounding rectangle of all display monitors.
#define SM_YVIRTUALSCREEN    77   // The coordinates for the top of the virtual screen. The virtual screen is the bounding rectangle of all display monitors.
#define SM_CXVIRTUALSCREEN   78   // The width of the virtual screen, in pixels. The virtual screen is the bounding rectangle of all display monitors.
#define SM_CYVIRTUALSCREEN   79   // The height of the virtual screen, in pixels. The virtual screen is the bounding rectangle of all display monitors.
#define SM_CMONITORS         80   // The number of display monitors on a desktop.
nValue := GetSystemMetrics ( nIndex )
Gracias por la info Dr. Claudio
Que bueno !
Quien sabe: SABE !
Gracias Claudio por tus aportes !
