GenInput
GenInput
I am still structurating the app.
I still not reached the main goal (run in InputWindow) but at least is something runnable.
One of most impressive is the ComboBox in the first Grid (first column) for HotKeys definitions.
I hope you enjoy it ! :)
<Source code and executable files were removed because there is a updated version ahead of this topic>
Steed
Re: GenInput
Post by Steed »
Thanks, for your efford and for sharing,
GenInput
Thank you Ed !
Re: GenInput
Pablo,
Many years ago I tried to do about the same in old Clipper87. The first thing i did was expanding the DBF files with the information to auto-build default input-browse-report functions. So a real "Datadictionary" was needed. This could then tell me exactly what every database-field should contain or not.
Example:
- picture/mask of a field
- is it a key / indexed field
- is it mandatory
- is it a code from another DBF
- is input a range
- is it updatable
- short and long description
- initial value
- etc. etc
Then build the "Datadictionary Application" to maintain the data stored (this is in fact a large Modify Structure Application).
Next thing was the default application generator. This app could then generate the default functions.
This worked fine for small and simple app's.
Regretfully most applications are very complex and so specific that I abandoned this idea but it still is a good idea!
Regards, Serge
Re: GenInput
serge_girard wrote: This worked fine for small and simple app's.
Regards, Serge
I agree with you, Serge - in my opinion, app generators are for small applications.
But, It's interesting what are you doing Pablo!
GenInput
Thank you Serge and Marek for your interest. :D
I am also thinking that generators it's for simple and small apps. It was for this reason I made for InputWindow proposes. To give for user understanding and make it easy to prepare a function.
This app will one generate a function which will be prepare to InputWindow and some UDFs could be added too.
I wish to have some more EditBox resources as for example to auto-complete or at worst to make ContextMenu giving option to insert into the text some previous functions ready. Because to construct the My_UDF() function, will be done in text editor (EditBox).
Regarding this matter, have you seen this scintilla Dynamic-link library for text editor ?
You will se at this post: Auto-completion for Text controls (this is my dream... to have it at HMG)
But I am expanding my time now caring of the condition of resources among the various options which are part of the structure, validation and deployment of controls. Then I'll go straight after the project recording and execution functions.
One interesting new features, will be when I'll be started to make the "Adjust Controls" module that defines the sizes of controls at run-time. The idea I have is to present visually all controls and scale it each in the desired width. Of course, this phase is optional (not needed to start for InputWindow uses). This will help to get better the aesthetics of presentation and designing of inputwindow. This I expect to do with sliders beside each control, as you already presented to us Marek.
But source generator for applications, is out of my mind and wish with this to help InputWindow usage, only.
B.Rgds
Re: GenInput
Go on Pablo !
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: GenInput
Post by dragancesu »
And what you are afraid to make a generator?
Long ago I met oracle and then for keeps three tools: sql*forms, sql*reports and sql*repot menu. I thought it was a little fellow but he reassured me, it's enough to make an application. Forms created screens to enter / change, report generate reports and menu all connects.
Forms is complex enough to make several types of forms: one record to the screen, the more (something like BROWSE), each part is called a block and has much to have them, so it is easy to make master-detail form
Each form at the top has the standard functions, motion, search, insert, delete, commit
Report to the list, so the sum of the change in the fields, and the sum at the end and More
Menu is used to integrate it into the application
For users as well as forms similar and have the same function, of course you can add actions
Oracle database is excellent and keeps data very efficiently, but not free (some expess version is free, but tools not free)
All this can make for a clipper, I made 20 years ago
Similar programs are good for users, facilitate their
HMG adds the right graphics programs, that's great, but again have to sit and write programs, when I watched the examples were about 300 lines long, much that is written from the beginning every time
My intention is not to advertise, but I made it for the HMG
They say that the developers want to destroy your business use shall generator program
When he appeared MS Access idle officials have begun to write programs. Do you still have the programmers? Yes, of corse
But on the other hand I think that itself should be facilitated by using (we say) geneatora programs. I do so, and you?
Re: GenInput
dragancesu wrote:And what you are afraid to make a generator?
That aggressiveness that good start to the year!
I hope you do to HMG and thus be able to enjoy your programming!
dragancesu
Re: GenInput
Do not worry, I'm not aggressive but the mood to write
See link https://www.youtube.com/watch?v=Z4nr05w ... E96CFC7AC1
So simple yet so powerful
HMG is made HMG IDE, a good tool but a bit incompleteness, take for example the control grid, what make? blank box and then everything should be added
I expected a little better, to ask that table and fill in the information you have, the field name, header, width
Something has been done for report
But a great tool, a real visual, it's making a master, and when I tried to do something I have no idea how to start, so I stayed at a lower variant serves me
