RichEditBox handling of Unicode text files now fixed
Re: RichEditBox handling of Unicode text files now fixed
kcarmody wrote: I will put together a posting like this with my changes. There are several dozen changes, so it will be a big posting and will take a while to put together.
Thanks Kevin.
kcarmody
Post by kcarmody »
RichEditBox changes by Kevin Carmody, November 2014
I'm submitting the following changes, all relating to the RichEditBox control. I've developed a patch, based on Claudio's current patch (patch 3), which incorporates these changes. This patch should be installed on top of Claudio's patch.
Individual modified source files are at http://kevincarmody.com/hmg/, and a zip of files in the patch is at http://kevincarmody.com/hmg/HMG.zip.
This patch also includes an overhauled Rich Edit demo, which uses all the source code changes (except for the SelPasteSpecial method). The new Rich Edit demo is at http://kevincarmody.com/hmg/SAMPLES/Con ... chEditBox/.
New manifest constants RTFTXTFILE_ANSI etc.
These constants are RTF and TXT file types returned by the new function GetRtfTxtFileType() and can be used by the RtfTxtLoadFile and RtfTxtSaveFile methods of the RichEditBox control.
http://kevincarmody.com/hmg/INCLUDE/i_richeditbox.ch - lines 159-169
// Following 5 #defines added by Kevin Carmody, November 2014
*   File type   *
#define RTFTXTFILE_ANSI      1   // ANSI text file
#define RTFTXTFILE_UTF8      2   // UTF-8 text file
#define RTFTXTFILE_UTF16LE   3   // UTF-16 LE (little endian) text file
#define RTFTXTFILE_RTF       4   // RTF file
#define RTFTXTFILE_UTF16BE   5   // UTF-16 BE (big endian) text file
These constants are also used in the Rich Edit demo - http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - lines 882-903 and lines 975-991.
New function GetRtfTxtFileType( cFile, lUtf8Test ) --> nFileType
This function returns a file type (RTF, ANSI, UTF-16, UTF-8) which can be used in RtfTxtLoadFile and RtfTxtSaveFile methods of RichEditBox control.
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 508-576
// Following function added by Kevin Carmody, November 2014
FUNCTION GetRtfTxtFileType ( cFile, lUtf8Test )
LOCAL hFile    := FOPEN( cFile, FO_READ )
LOCAL cBuffer  := SPACE( 5 )
LOCAL nBufRead := 0
LOCAL nType    := 0
  The following code block tests for the presence of non-ASCII characters in
  an unmarked text file.  It assumes that such characters may be ANSI or
  parts of UTF-8 sequences.  In UTF-8 mode, Windows reads bytes which are not
  part of a valid UTF-8 sequence as ANSI.  It would be better to know if the
  file contained UTF-8 sequences for non-ANSI characters, but since some ANSI
  characters are not in the Latin-1 Supplement, testing for non-ANSI UTF-8
  sequences is inefficient for large files.
LOCAL bHasUnicodeChars := {||
   LOCAL lHasUnicode := .N.
   LOCAL cChar, cStr
   cBuffer  := SPACE( 0x400 )
   nBufRead := 1
   BEGIN SEQUENCE
      WHILE nBufRead > 0
         nBufRead := FREAD( hFile, @cBuffer, 0x400 )
         IF nBufRead > 0
            cStr := LEFT( cBuffer, nBufRead )
            FOR EACH cChar IN cStr
               IF cChar >= CHR(0x80)
                  lHasUnicode := .Y.
                  BREAK
      ENDDO
   END SEQUENCE
   RETURN lHasUnicode
BEGIN SEQUENCE
   IF hFile < 0
      BREAK
   nBufRead := FREAD( hFile, @cBuffer, 5 )
   DO CASE
   CASE nBufRead >= 5 .AND. LEFT( cBuffer, 5 ) == "{\rtf"
      nType := RTFTXTFILE_RTF
   CASE nBufRead >= 3 .AND. LEFT( cBuffer, 3 ) == E"\xEF\xBB\xBF"
      nType := RTFTXTFILE_UTF8
   CASE nBufRead >= 2 .AND. LEFT( cBuffer, 2 ) == E"\xFF\xFE"
      nType := RTFTXTFILE_UTF16LE
   CASE nBufRead >= 2 .AND. LEFT( cBuffer, 2 ) == E"\xFE\xFF"
      nType := RTFTXTFILE_UTF16BE
   CASE ! EMPTY( lUtf8Test ) .AND. bHasUnicodeChars:EVAL( )
   OTHERWISE
      nType := RTFTXTFILE_ANSI
   ENDCASE
END SEQUENCE
FCLOSE( hFile )
RETURN nType
This function is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - line 879
   LOCAL nFormat        := GETRTFTXTFILETYPE( cFileName, .Y. )
New function Utf16ByteSwap( cInFile, cOutFile )
This function supports the UTF-16 BE (big endian) file type for the RtfTxtLoadFile and RtfTxtSaveFile methods of RichEditBox control.
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 579-621
FUNCTION Utf16ByteSwap( cInFile, cOutFile )
LOCAL hInFile   := FOPEN( cInFile , FO_READ )
LOCAL hOutFile  := FCREATE( cOutFile )
LOCAL cInBuffer := SPACE( 0x400 )
LOCAL nBufRead  := 1
LOCAL lSuccess  := .N.
LOCAL cOutBuffer, cBytePair, nBufWrite, nByte
BEGIN SEQUENCE
   IF hInFile < 0
      BREAK
   IF hOutFile < 0
      BREAK
   WHILE nBufRead > 0
      cOutBuffer := ""
      nBufRead   := FREAD( hInFile, @cInBuffer, 0x400 )
      IF nBufRead > 0
         FOR nByte := 1 TO nBufRead STEP 2
            cBytePair  := SUBSTR( cInBuffer, nByte, 2 )
            cOutBuffer += RIGHT( cBytePair, 1 ) + LEFT( cBytePair, 1 )
         nBufWrite := FWRITE( hOutFile, cOutBuffer )
         IF nBufWrite < nBufRead
            BREAK
   ENDDO
   lSuccess := .Y.
END SEQUENCE
FCLOSE( hInFile )
FCLOSE( hOutFile )
RETURN lSuccess
This function is used in RichEditBox_RtfTxtLoadFile() and RichEditBox_RtfTxtSaveFile() - see below.
Fixed RichEditBox_StreamIn( hWndControl, cFileName, lSelection, nDataFormat ) --> lSuccess
This function now skips over a byte order mark (BOM) in a Unicode text file if one is present.
http://kevincarmody.com/hmg/SOURCE/c_richeditbox.c - lines 226-291
//        RichEditBox_StreamIn ( hWndControl, cFileName, lSelection, nDataFormat ) --> return lSuccess
HB_FUNC ( RICHEDITBOX_STREAMIN )
   HWND       hWndControl = (HWND)   HMG_parnl (1);
   TCHAR     *cFileName   = (TCHAR*) HMG_parc (2);
   BOOL       lSelection  = (BOOL)   hb_parl  (3);
   LONG       nDataFormat = (LONG)   hb_parnl (4);
   HANDLE     hFile;
   // Following 3 lines added by Kevin Carmody, November 2014
   BYTE       bUtf8Bom[3];
   BYTE       bUtf16Bom[2];
   DWORD      dwRead;
   EDITSTREAM es;
   LONG       Format;
   switch( nDataFormat )
   // Comments in this switch block modified by Kevin Carmody, November 2014
      case 1:   Format = SF_TEXT; break; // ANSI or UTF-8 with BOM or mixed (UTF-8 BOM removed, overlong UTF-8 accepted, invalid UTF-8 read as ANSI)
      case 2:   Format = ( CP_UTF8 << 16 ) | SF_USECODEPAGE | SF_TEXT; break; // UTF-8 without BOM (BOM not removed)
      case 3:   Format = SF_TEXT | SF_UNICODE; break; // UTF-16 LE without BOM (BOM not removed)
      case 4:   Format = SF_RTF;  break;
      // case 5, UTF-8 RTF, removed by Kevin Carmody, November 2014, because it can never occur
      default:  Format = SF_RTF; break;
   if ( lSelection )
        Format = Format | SFF_SELECTION;
   if( ( hFile = CreateFile (cFileName, GENERIC_READ, FILE_SHARE_READ, NULL, OPEN_EXISTING, FILE_FLAG_SEQUENTIAL_SCAN, NULL )) == INVALID_HANDLE_VALUE )
   {   hb_retl (FALSE);
       return;
   // Following switch block added by Kevin Carmody, November 2014
      case 1:   break;
      case 2:
         if ( ! ReadFile (hFile, bUtf8Bom, 3, &dwRead, NULL) ) // read past BOM if present
            hb_retl (FALSE);
         if ( ! ( dwRead == 3 && bUtf8Bom[0] == 0xEF && bUtf8Bom[1] == 0xBB && bUtf8Bom[2] == 0xBF ) )
            SetFilePointer (hFile, 0, 0, FILE_BEGIN);
         break;
      case 3:
         if ( ! ReadFile (hFile, bUtf16Bom, 2, &dwRead, NULL) ) // read past BOM if present
            hb_retl (FALSE);
         if ( ! ( dwRead == 2 && bUtf16Bom[0] == 0xFF && bUtf16Bom[1] == 0xFE ) )
         break;
      case 4:   break;
      default:  break;
   es.pfnCallback = EditStreamCallbackRead;
   es.dwCookie    = (DWORD_PTR) hFile;
   es.dwError     = 0;
   SendMessage ( hWndControl, EM_STREAMIN, (WPARAM) Format, (LPARAM) &es );
   CloseHandle (hFile);
   if( es.dwError )
      hb_retl (FALSE);
      hb_retl (TRUE);
This function is called by RichEditBox_RtfTxtLoadFile() - see below.
Fixed RichEditBox_StreamOut( hWndControl, cFileName, lSelection, nDataFormat ) --> lSuccess
This function now writes a byte order mark (BOM) to a Unicode text file.
http://kevincarmody.com/hmg/SOURCE/c_richeditbox.c - lines 305-360
//        RichEditBox_StreamOut ( hWndControl, cFileName, lSelection, nDataFormat ) --> return lSuccess
HB_FUNC ( RICHEDITBOX_STREAMOUT )
   HANDLE     hFile;
   BYTE       bUtf8Bom[3]  = {0xEF, 0xBB, 0xBF};
   BYTE       bUtf16Bom[2] = {0xFF, 0xFE};
   DWORD      dwWritten;
   EDITSTREAM es;
   LONG       Format;
      case 1:   Format = SF_TEXT; break; // ANSI (non-ANSI characters converted to question marks)
   if ( lSelection )
   if( ( hFile = CreateFile (cFileName, GENERIC_WRITE, FILE_SHARE_WRITE, NULL, CREATE_ALWAYS, FILE_ATTRIBUTE_NORMAL, NULL )) == INVALID_HANDLE_VALUE )
   {   hb_retl (FALSE);
       return;
      case 1:   break;
      case 2:   WriteFile( hFile, bUtf8Bom, 3, &dwWritten, NULL ); break; // write UTF-8 BOM at head of file
      case 3:   WriteFile( hFile, bUtf16Bom, 2, &dwWritten, NULL ); break; // write UTF-16 LE BOM at head of file
      case 4:   break;
      default:  break;
   es.pfnCallback = EditStreamCallbackWrite;
   es.dwError     = 0;
   SendMessage ( hWndControl, EM_STREAMOUT, (WPARAM) Format, (LPARAM) &es );
   if( es.dwError )
      hb_retl (FALSE);
      hb_retl (TRUE);
This function is used in RichEditBox_RtfTxtSaveFile() - see below.
New RichEditBox property HasUnicodeChars (read only)
This property detects whether a rich edit control contains non-ASCII Unicode characters.
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 9293-9296, at end of _RichEditBox_GetProperty()
   // Following case added by Kevin Carmody, November 2014
   CASE Arg3 == "HASUNICODECHARS"
        xData  := RichEditBox_HasUnicodeChars ( hWndControl )
        RetVal := .T.
http://kevincarmody.com/hmg/INCLUDE/i_window.ch - lines 153-154
;; // Following line modified by Kevin Carmody, November 2014
#xtranslate <w>. \<c\> . \<p:RTFTextMode,AutoURLDetect,Zoom,SelectRange,CaretPos,Value,GetSelectText,GetTextLength,ViewRect,HasUnicodeChars\> => GetProperty ( <"w">, \<"c"\> , \<"p"\> ) ;;
  The following function tests for the presence of non-ASCII characters in
  a rich edit control.  It would be better to know if the control contained
  non-ANSI characters, but since some ANSI characters are not in the Latin-1
  Supplement, testing for non-ANSI characters is inefficient for large
  documents.
FUNCTION RichEditBox_HasUnicodeChars( hWndControl )
LOCAL cBuffer     := RichEditBox_GetText( hWndControl , .N. )
LOCAL cChar
FOR EACH cChar IN cBuffer
      lHasUnicode := .Y.
RETURN lHasUnicode
This function is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - line 944
   LOCAL lUnicode := wMain.ebDoc.HASUNICODECHARS
New RichEditBox method RtfTxtLoadFile( cFile, lSelection, nType ) --> lSuccess
This method is a synonym for the RtfLoadFile method. It now uses the file type returned by GetRtfTxtFileType(). It skips over a byte order mark in a Unicode text file, and it supports UTF-16 BE (big endian Unicode text file).
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 9467-9470
   // Following case modified by Kevin Carmody, November 2014
   CASE Arg3 == "RTFLOADFILE" .OR. Arg3 == "RTFTXTLOADFILE"
        xData := RichEditBox_RtfTxtLoadFile ( hWndControl, Arg4, Arg5, Arg6 )   // by default save in SF_RTF format
        RetVal := .T.
http://kevincarmody.com/hmg/INCLUDE/i_window.ch - lines 161-165
;; // Following 2 lines modified by Kevin Carmody, November 2014
#xtranslate <w>. \<c\> . \<p:RTFLoadFile,RTFSaveFile,RtfTxtLoadFile,RtfTxtSaveFile\> (\<arg1\>,\<arg2\>,\<arg3\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\>, \<arg3\> ) ;;
#xtranslate <w>. \<c\> . \<p:RTFLoadFile,RTFSaveFile,RtfTxtLoadFile,RtfTxtSaveFile\> (\<arg1\>,\<arg2\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\> ) ;;
;; // Following line added by Kevin Carmody, November 2014
#xtranslate <w>. \<c\> . \<p:RTFLoadFile,RTFSaveFile,RtfTxtLoadFile,RtfTxtSaveFile\> (\<arg1\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> ) ;;
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 441-475
FUNCTION RichEditBox_RtfTxtLoadFile( hWndControl, cFile, lSelection, nType )
LOCAL cTempFile
IF ! HB_ISLOGICAL( lSelection )
   lSelection := .N.
IF ! HB_ISNUMERIC( nType )
IF lSelection
   RichEditBox_UnSelectAll( hWndControl )
IF RichEditBox_RTFLoadResourceFile( hWndControl, cFile, lSelection )
   lSuccess := .T.
   IF nType == RTFTXTFILE_UTF16BE
      cTempFile := GETTEMPFOLDER() + "_RtfTxtLoadFile.txt"
      lSuccess  := Utf16ByteSwap( cFile, cTempFile )
      IF lSuccess
         lSuccess := RichEditBox_StreamIn( hWndControl, cTempFile, lSelection, RTFTXTFILE_UTF16LE )
      DELETE FILE ( cTempFile )
      lSuccess := RichEditBox_StreamIn( hWndControl, cFile, lSelection, nType )
RETURN lSuccess
This method is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - line 905
      IF ! wMain.ebDoc.RTFTXTLOADFILE( cFileName, .N., nFormat )
New RichEditBox method RtfTxtSaveFile( cFile, lSelection, nType ) --> lSuccess
This method is a synonym for the RtfSaveFile method. It now uses the file type returned by GetRtfTxtFileType(), writes a byte order mark to a Unicode text file, and supports UTF-16 BE (big endian Unicode text file).
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 9472-9475
   CASE Arg3 == "RTFSAVEFILE" .OR. Arg3 == "RTFTXTSAVEFILE"
        xData := RichEditBox_RtfTxtSaveFile ( hWndControl, Arg4, Arg5, Arg6 )   // by default save in SF_RTF format
        RetVal := .T.
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 478-505
FUNCTION RichEditBox_RtfTxtSaveFile( hWndControl, cFile, lSelection, nType )
LOCAL cTempFile
   lSelection := .N.
   lSuccess := RichEditBox_StreamOut( hWndControl, cTempFile, lSelection, RTFTXTFILE_UTF16LE )
   IF lSuccess
      lSuccess  := Utf16ByteSwap( cTempFile, cFile )
   lSuccess := RichEditBox_StreamOut( hWndControl, cFile, lSelection, nType )
RETURN lSuccess
This method is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - line 992
      IF ! wMain.ebDoc.RTFTXTSAVEFILE( cFileName, .N., nFormat )
New RichEditBox method SelPasteSpecial
Paste special - needs documentation of clipboard format argument.
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 9485-9488
   CASE Arg3 == HMG_UPPER ("SelPasteSpecial")
        RichEditBox_PasteSpecial ( hWndControl, Arg4 )
        RetVal := .T.
http://kevincarmody.com/hmg/INCLUDE/i_window.ch - lines 168-169
#xtranslate <w>. \<c\> . \<p:SelPasteSpecial\> (\<arg1\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> ) ;;
This method is not used in the Rich Edit demo.
Enhanced RichEditBox method RtfLoadFile( cFile, lSelection, nType ) --> lSuccess
This method is a synonym for the RtfTxtLoadFile method described above.
        RetVal := .T.
Enhanced RichEditBox method RtfSaveFile( cFile, lSelection, nType ) --> lSuccess
This method is a synonym for the RtfTxtSaveFile method described above.
        RetVal := .T.
Enhanced function GetFile( [aFilter], [cTitle], [cIniFolder], [lMultiSelect], [lNoChangeDir], [nFilterIndex] ) --> cFileName | aFileNames
Added nFilterInddex argument to control the default file filter. See viewtopic.php?f=8&t=4009
http://kevincarmody.com/hmg/SOURCE/c_dialogs.c - lines 173-174, 188-190, 221-222
HB_FUNC ( C_GETFILE )
   #define _MAXMULTISELECTFILE   1024
   OPENFILENAME ofn;
   TCHAR buffer    [ _MAXMULTISELECTFILE  *  MAX_PATH ];
   TCHAR cFullName [ _MAXMULTISELECTFILE ] [ MAX_PATH ];
   TCHAR cCurDir   [ MAX_PATH ];
   TCHAR cFileName [ MAX_PATH ];
   int iFilterIndex = 1;
   int iPosition    = 0;
   int iNumSelected = 0;
   int flags = OFN_FILEMUSTEXIST | OFN_EXPLORER;
   memset ((void*)&buffer, 0, sizeof(buffer));
   if ( hb_parl(4) )
      flags = flags | OFN_ALLOWMULTISELECT ;
   if ( hb_parl(5) )
      flags = flags | OFN_NOCHANGEDIR ;
   // Following if statement added by Kevin Carmody, November 2014
   if ( hb_parni(6) )
     iFilterIndex = hb_parni(6) ;
// ofn.lpstrFilter = A buffer containing pairs of null-terminated filter strings.
//                   The last string in the buffer must be terminated by two NULL characters.
// The following code converts a ANSI (CHAR) filter string into a UNICODE (UNSIGNED INT) filter string
   #define _MAX_FILTER 5*1024
   INT i, j=0, cont=0;
   CHAR *p = (CHAR*) hb_parc(1);
   TCHAR Filter [ _MAX_FILTER ];
   memset((void*) &Filter, 0, sizeof(Filter));
   for (i=0; *p != '\0'; i++)
   {  cont = cont + strlen (p) + 1;
      if (cont < _MAX_FILTER)
      {   lstrcpy ( &Filter[j], HMG_CHAR_TO_WCHAR(p) );
          j = j + lstrlen ( HMG_CHAR_TO_WCHAR (p) ) + 1;
          p = p + strlen (p) + 1;
         break;
   memset( (void*) &ofn, 0, sizeof( OPENFILENAME ) );
   ofn.lStructSize      = sizeof(OPENFILENAME);
   ofn.hwndOwner        = GetActiveWindow();
   ofn.lpstrFilter      = (LPCTSTR) &Filter;
   // Following statement modified by Kevin Carmody, November 2014
   ofn.nFilterIndex     = (DWORD) iFilterIndex;
   ofn.lpstrFile        = (LPTSTR) &buffer;
   ofn.nMaxFile         = sizeof(buffer) / sizeof(TCHAR);
   ofn.lpstrInitialDir  = (LPCTSTR) HMG_parc(3);
   ofn.lpstrTitle       = (LPCTSTR) HMG_parc(2);
   ofn.Flags            = flags;
   if( GetOpenFileName (&ofn) )
      if ( ofn.nFileExtension !=0 )
         HMG_retc (ofn.lpstrFile);
         wsprintf ( cCurDir, _TEXT("%s"), &buffer [iPosition] );
         iPosition = iPosition + lstrlen (cCurDir) + 1;
         do
            iNumSelected ++;
            wsprintf ( cFileName, _TEXT("%s"), &buffer [iPosition] );
            iPosition = iPosition + lstrlen (cFileName) + 1;
            wsprintf ( cFullName [iNumSelected], _TEXT("%s\\%s"), cCurDir, cFileName);
         while (( lstrlen(cFileName) !=0 ) && ( iNumSelected < _MAXMULTISELECTFILE ));
         if (iNumSelected > 1)
            hb_reta (iNumSelected - 1);
            for (i = 1; i < iNumSelected; i++)
               HMG_storvc (cFullName[i], -1, i );
            HMG_retc( &buffer[0] );
      HMG_retc( _TEXT("") );
http://kevincarmody.com/hmg/SOURCE/h_dialogs.prg - lines 93-94, 123-126, 129-130, 132-133
Function GetFile( aFilter, title, cIniFolder, multiselect, nochangedir, nFilterIndex )
local c := ''
local cfiles := ''
local fileslist := {}
local n
Local i
  IF aFilter == Nil
    aFilter := {}
  EndIf
   IF title == NIL
      title := ""
   IF cIniFolder == NIL
      cIniFolder := ""
  FOR n:=1 TO HMG_LEN(aFilter)
      c :=  c + aFilter[n][1] + CHR(0) + aFilter[n][2] + CHR(0)
   c :=  c + CHR(0)
  if valtype(multiselect) == 'U'
    multiselect := .f.
  // Following if block added by Kevin Carmody, November 2014
  if nFilterIndex == NIL
    nFilterIndex := 1
  if .not. multiselect
    Return ( C_GetFile ( c , title, cIniFolder, multiselect, nochangedir, nFilterIndex ) )
    cfiles := C_GetFile ( c , title, cIniFolder, multiselect, nochangedir, nFilterIndex )
    if HMG_LEN( cfiles ) > 0
      if valtype( cfiles ) == "A"
        fileslist := aclone( cfiles )
        aadd( fileslist, cfiles )
    For i := 1 To HMG_LEN ( FilesList)
      FilesList [i] := HB_UTF8STRTRAN ( FilesList [i] , "\\" , "\" )
    Next i
    Return ( FilesList )
This enhancement is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - line 864
     cAuxFileName := GETFILE( aReadFilter, 'Open', cFileFolder, NIL, NIL, nReadFilter )
Enhanced function Putfile( [aFilter], [cTitle], [cIniFolder], [lNoChangeDir], [cDefaultFileName], [cExtFile], [nFilterIndex] ) --> cFileName
Added nFilterInddex argument to control the default file filter. If passed by reference, nFilterIndex returns the index of file filter selected by user. See viewtopic.php?f=8&t=4009
http://kevincarmody.com/hmg/SOURCE/c_dialogs.c - lines 268-269, 276-280, 311-312, 327-331
HB_FUNC ( C_PUTFILE )
 OPENFILENAME ofn;
 TCHAR buffer[1024];
 int flags = OFN_OVERWRITEPROMPT | OFN_EXPLORER ;
 if ( hb_parl(4) )
 if ( hb_parni(7) )
  iFilterIndex = hb_parni(7) ;
   INT i, j=0, cont=0;
   TCHAR Filter [_MAX_FILTER];
      {   lstrcpy ( &Filter[j], HMG_CHAR_TO_WCHAR (p) );
         break;
 lstrcpy (buffer, HMG_parc(5));
 ofn.hwndOwner = GetActiveWindow() ;
 ofn.Flags = flags;
 ofn.lpstrDefExt = (LPCTSTR) HMG_parc(6);
 if ( GetSaveFileName (&ofn) )
 {   if (HB_ISBYREF(6))
     {  if (ofn.nFileExtension > ofn.nFileOffset)
            HMG_storc (&ofn.lpstrFile [ofn.nFileExtension], 6);
            HMG_storc (_TEXT(""), 6);
     if (HB_ISBYREF(7))
        hb_stornl ((LONG) ofn.nFilterIndex, 7);
     HMG_retc(ofn.lpstrFile);
http://kevincarmody.com/hmg/SOURCE/h_dialogs.prg - lines 154-155, 175-178, 185-186
Function Putfile ( aFilter, cTitle, cIniFolder, lNoChangeDir, cDefaultFileName, cExtFile, nFilterIndex )
LOCAL cFilter:='' , n, cFileName
   IF aFilter == Nil
      aFilter:={}
   EndIf
   IF cTitle == NIL
      cTitle := ""
      cIniFolder := ""
   IF cDefaultFileName == NIL
      cDefaultFileName := ""
   IF nFilterIndex == NIL
      nFilterIndex := 1
   FOR n := 1 TO HMG_LEN ( aFilter )
      cFilter = cFilter + aFilter [n] [1] + CHR(0) + aFilter [n] [2] + CHR(0)
   cFilter :=  cFilter + CHR(0)
   cFileName := C_PutFile ( cFilter, cTitle, cIniFolder, lNoChangeDir, cDefaultFileName, @cExtFile, @nFilterIndex )
Return cFileName
This enhancement is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - lines 957-958
   cAuxFileName := PUTFILE( aWriteFilter, 'Save As', cFileFolder, ;
      NIL, cFileName, @cFileExt, @nWriteFilter )
Enhanced function DoMethod ( Arg1 , Arg2 , Arg3 , Arg4 , Arg5 , Arg6 , Arg7 , Arg8 , Arg9 )
Enabled this function to return a value from a RichEditBox method.
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 7943-7944
Function DoMethod ( Arg1 , Arg2 , Arg3 , Arg4 , Arg5 , Arg6 , Arg7 , Arg8 , Arg9 )
Local xData, i, hWnd
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 7955-7957
IF _RichEditBox_DoMethod ( @xData, Arg1 , Arg2 , Arg3 , Arg4 , Arg5 , Arg6 , Arg7 , Arg8 , Arg9 ) == .T.
   Return xData
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 9444-9445
Function _RichEditBox_DoMethod ( xData, Arg1 , Arg2 , Arg3 , Arg4 , Arg5 , Arg6 , Arg7 , Arg8 , Arg9 )
The return value is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - lines 905
The return value is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - lines 992
Kevin
Thanks Kevin.
Many of these changes will be for the next version because HMG.3.3.2 now is ready.
srvet_claudio wrote:Thanks Kevin.
Eagerly waiting for new version
Great work done by Mr. Kevin in a very short period, Thank you for your contribution
Thanks Kevin and Claudio,
Question: any idea about a function for converting to HTML...?
That would be so great!
kcarmody
Post by kcarmody »
serge_girard wrote:Question: any idea about a function for converting to HTML...?
Some years ago I wrote a Harbour library called UnicodeLib that has functions for converting between ANSI, Unicode, RTF, and HTML. Some of these functions now have equivalents in Harbour, but I don't think the HTML conversions do. You can download UnicodeLib from http://kevincarmody.com/software/akshar ... unicodelib.
Kevin
Thanks Kevin !
